Cant get replacement bulbs for flamerite omni fire log effect with flicker bulbs
The bulbs have stopped working but I can no longer find replacements as they do not make that kind of bulb anymore can you suggest an up to date replacement bulb and stockist. many thanks
    Problem Solver:
  • 15 Answers
Try LED they come in all sizes and available everywhere
Posted on Mar 19, 2014
4 Suggested Answers
  • 4736 Answers
SOURCE: How do I replace the
First, you will need to turn the unit OFF and unplug it. Then remove the front plexiglass front of the firebox. Lift off the plastic coal affect cover and this will give you access to the bulbs. Simply unscrew the faulty one and replace it with a like kind bulb (60 watt, small base chandelier bulb). It's a good idea to replace all the bulbs at the same time. Because if one just failed, the others will follow shortly.
Reassemble all the parts you removed in reverse order. Plug the unit back in and turn the unit ON.
I hope this helped you.
Posted on Jul 20, 2011
Testimonial: "Many thanks, I'll have a go."
  • 4736 Answers
SOURCE: replacing bulb in dimplex electric
To replace the bulbs, your will need to remove the plexiglass front, then remove the logs and set them off to side where they won't get stepped on. Then lift up the plastic simulated ember bed. You now have access to the light bulbs. The required bulbs are 60 watt small base chandelier bulbs.
Hope this helped you, Margo. Thanks for choosing FixYa.
Posted on Aug 18, 2011
  • 4736 Answers
SOURCE: THE FLICKER EFFECT HAS GONE.
Joyce if you could furnish the band, model number and whether it's an electric fireplace or stove, I may can help you. But, with out that information, we're shooting in the dark to suggest what you need to do.
Please advise and thanks for choosing FixYa.
Posted on Sep 19, 2011
I have a flamerite milan fire suite lights not coming on checked bulbs they are OK heating working also
No power to the fire: Check the wall socket, plug and fuse. No illumination: Make sure the fire is turned on. Check heater is working, if so change lamps. Illumination but no heat: The safety cut has operated see note on operating the Fire. Noise when illuminated: Due to moving parts, the electric fire will make a noise. Noise from the heater when in use: The sound of rushing air is normal. Logo
Jan 21, 2017 | Heating & Cooling
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Says you can turn it on and off? Did you knock the switch?
Can I operate the flame effect on the fire without the heat?
All our Optiflame and Opti-myst fires can be operated on a flame-effect only setting, as can the flickering flame effect on our freestanding bar fires.
Is the flame effect expensive to run?
No, to run the flame effect involves powering light bulbs and a small electric motor and in most cases costs no more than a couple of pence an hour. Some of our fires have LED lamps fitted which are even more energy efficient.
Some have bulbs, some have LED.
Example calculations:
Using UK standard average price of electricity of 14p/kWh (source: Energy Saving Trust Feb 2015)
Optiflame LED flame effect only (eg Danesbury) = 0.1p every hour
Optiflame conventional bulb, effect only (eg Cheriton) = 2p every hour
Opti-myst, flame effect only (eg Oakhurst) = 3p every hour
Opti-V single screen = 0.5p every hour
2kW fan heater, on constantly (no thermostat) = 28p every hour
Optiflame lightbulbs for sale. Remove the coals and check for bulbs.
https://store.gdcgroup.co.uk/dimplex/products/index.htm?product_code=FP03022
Dec 23, 2015 | Dimplex Heating & Cooling
I have a flame rite fire model number 172/180 will not work do you still have these fires
Maybe your circuit board is fried too? Circuit boards come up as issues more than a few.
Kind Regards,
Scott
Need circuit board flamerite 172 180 elect fire
How to fix flamerite fire
Feb 10, 2015 | Home
Flamerite fire spare parts
This is an issue to be resolved with Flamerite.
Oct 22, 2013 | Grilling
I have a flamerite mercia electric suite, just over 2 years old. The remote control does not now operate the heat function. I have replaced the battery but it still does not work. Any help for a...
I have the same problem phoned the makers Flamerite and they sent me some instructions that may solve the problem. Phone them on 01543251122 I did speak to the shop where I purchased the fire and they told me that this was a common problem with these fires. This did not fix my problem. I will be contacting them again tomorrow. Good luck
Oct 04, 2011 | Heating & Cooling
I have a Flamerite Odyssey Suite Electric Fire approx 5 yrs old. The thermostat no longer works and I cannot find anyone that sells a replacement. The thermostat only has the number 143211 256-C...
I have just tried to obtain a stat for this same fire Flamerite was no use at all.I have put a link in where the sta was to override, it's on full now, but theres heat now. Terry Risley Electrical Services 0788 4061406
Oct 24, 2010 | Universal Remote Control Heating & Cooling
I have a Flamerite fire, model is called Isis. The fire come with a remote control which you use to turn on the lights and the heat. The fire is not working, when you press the remote the bulbs on the fire...
Hi I have the same fire with almost the same problem, I even bought some new batteries for the remote thinking that may be the problem.
I bought my fire suite second hand ,(Vega suite with Isis inset) in almost new condition and absulutely love it, so am gutted it has stopped working , Someone said , ''It could be the hidden bulbs at the backof the isis inset that need changing, But on trying to find access to the bulbs I just cannot find a way to get to them, There is 4 screws on the near inside which previous owner has cross threaded and wondered if that is the only way to get to them, If you have any ideas I would really appreciate your help and will contact you also if I can find a solution, Take care have fun
Maureena
Dec 14, 2009 | Dryers
Hampton bay CFL lights flicker when they are turned off
I believe the flickering comes from the way the CFLs extinguish themselves after the remote turns them off. As the other poster said, turning them off with the wall switch as well after turning them off with the remote stops the flickering.
It is because the remotes are a dual mesh type of signal, which uses the RF as well as the electrical power to activate and turn them off.
Actually, this type bulb is not designed to work as well in dimmers or remote switches as is incandescent. You will find if you replace them with regular incandescent they will not flicker.
Sirwriter
Apr 13, 2009 | Hampton Bay 24750 Huntington III Ceiling...
My flamerite atlanta fire will not switch on. When i do turn the heat on the fire cuts out
Similar thing happened to mine at weekend after fitting a new hearth and fire surround (sods law) think its the heater unit £57.50 from flamerite
Sep 04, 2008 | Heating & Cooling
Heating & Cooling Logo
142 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
