Question about Roland GX-24 Vinyl Cutter
Repair usb port roland gx 24
Broken usb connector can it be replaced
How to get out of dpics mode on a roland camm-1 pro gx400
Please help us the error code comes "dpics mode" in roland gx-500
Jul 29, 2012 | Roland GX-400 CAMM-1 Pro Vinyl Cutter
The usb port is broken. It does not activate or power the interface. How Do would you go about having it repaired?
All USB ports have four leads attached. Tthe outside rails contain the positive and negative voltage of 5V and the two inside rails is the transmit and receive. I would take the interface apart and replace the USB connector. Maybe Radio Shack or another electronic shop would have the same USB connector. See:
http://69.84.140.50/content/Article.aspx?Type=L&ID=468
Jan 05, 2011 | M-Audio Fast Track Ultra 8R 8 x 8 USB 2.0...
Need to replace usb port,
Try a local computer shop that does repairs. You will have to unsolder the old port and take it with you to get a match.Also a good electronics parts dealer should have one or be able to order one for you.
Sep 01, 2009 | Tascam 2488mkii 24 Track Recording...
USB Connector broken
Not easily - the USB port is soldered to the main transceiver board and although it's pretty simple to replace with the right tools, it's not the sort of job you can readily do at home.
Jun 30, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Broken USB connector
it depends if the port has come off with out damaging the board if its damaged the board its more harder to replace the port. sometimes you are luck and its just broken the slider as its tin base. and it can rip, but you cannot tell until its been opened and looked at.
Jul 03, 2017 | Logitech Harmony 676 LCD Remote Control
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
Roland GX-24 Vinyl Cutter Logo
250 people viewed this question
Top Roland Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Roland Craft and Hobby Expert? Answer questions, earn points and help others
