Question about Dynex DX-L22-10A 22 in. LCD TV
Power supply 32 volts missimg
No 32 volts
  • Conrad Kimbrough
    Conrad Kimbrough Mar 19, 2014
    When turning on the picture quickly flashes red then goes black, sound is
  • Dynex Master
  • 1,525 Answers
Hi the volts are 3.3v 5v 12v 15.5 24v hope it helps
regards
shaun
Posted on Mar 19, 2014
Sylvania HDTV Model LC370SS8 won't turn on.
u should check std-by volt .when u press power on , the power on volt must not b drop
Oct 09, 2012 | Sylvania LC320SS8 32 in. LCD Television
Were can i purchase protron ac/dc power supply for protron pltv-32 pltv32 lcd tv
Check this link below:
http://www.lcdpayless.com/productpage.php?productId=5441
Specification of Protron pltv-32 lcd ac adapter:
Output Voltage: 24V and 12V Volts DC
Amperage: 6 A and 3 A Amps
May 15, 2011 | Protron Ac / Dc Power Supply For Protron...
I have a dynex 32 lcd and in the screen has all of a sudden turned white with no picture. I still have sound but no picture and nothing is working.
open the back cover of you tv you can see the power supply there.using a multitester measure the output of the power supply wether there is 5 volts output...check the connectors specially the RGB fit them to the terminals...the power supply outputs are 5v,12v,and 24 volts if one of them is missing replace the power supply..
good luck!!hope this help you..
your rate is important to this help.tnx..
May 21, 2010 | Dynex DX-LCD32-09 LCD TV
Insignia IS LCDTV32 Will not power up. Geek squad said it was a problem with the power supply and they don't make the part anymore. Have you heard of this and where would I find the part.
Convert it. Use alternative WEIYA power supply with 5V, 12V and 24V output. 24 volts is for the backlight, the 5 volts is for the main computer board and the 12 volts for the sound card.
Dec 14, 2009 | Insignia IS-LCDTV32 32 in. Television
Power ligh starts yellow goes green but no sound or video
your inverter board is failing try shop jimmy.com for parts
Sep 18, 2009 | Vizio L32 32 in. LCD HDTV
Hyundai HLT-3210 POWER SUPPLY FAULT LOW OUTPUT FROM SUPPLY PCB
Hello! My name is Ivica,and I am from Croatia.I have same LCD which have problem with motherboard.Try to disconect power supply from inverters and then measure all volt line.Maybe failure is on inverters board!Write me if you solve the problem,and maybe you know where can I find new motherboard for my LCD.Thanks.
Jan 18, 2009 | Hyundai ImageQuest HQL320WR 32 in....
The power supply in my DYLT032D Soyo 32" is missing the 12 volts. Need a power supply or a fix for mine.
Is very hard to find these parts for servicing. The only option will be to DIY, by replacing some of the capacitors that become defective. Try to trace where the 12 volts are coming from and replace the capacitors or the 12 volts regulator if you find one in the circuitry.
Good Luck.
Mar 23, 2008 | Soyo DYLT032D 32 in. LCD Television
RCA 32" 1996 COLOR TRAC PLUS
Hello neall,
It sounds like you may have a power supply problem- (HV Power supply). I must ask if you have sound or not? If you have sound it is the HV supply only if you do not have sound the Low Volt power supply and possibly the HV power supply/Horizontal section has a problem. I would suggest that you take the TV to a qualified TV repair shop.
I hope this helps,
Thank You,
Shuttle83
Mar 18, 2008 | RCA F32632SB 32" TV
Low voltage power supply fuses blown
If the convergence power supply fuses blew you can bet that the convergence ICs need to be changed. The blue connector will be pressed down on the rear of the connector to release or pulled up on the back end of the socket. Ps dont forget to rate this.
Oct 11, 2006 | Toshiba 57H81 57" Rear Projection...
Dynex DX-L22-10A 22 in. LCD TV Logo
54 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
