Where is the refresh on my computer?
I use to be able to click on "Refresh" but now it's gone.
  • 41 Answers
Refreshing a website is as simple as hitting "F5" on your keyboard, most times. Alternatively you can right click within the header of your browser and you should see something like "view"... Inside are all the different configurations that browser accepts. It's possible that the last update has toggled something removing the visual button for refresh.
Posted on Mar 19, 2014
Tip
How to Update or Refresh the WEI (Windows Experience Index) Score in Windows 7
Information:
This will show you how to update or refresh the Windows Experience Index (WEI) base score in Windows 7 to help measure the capability of your computer.
1. Open the Start Menu.
2. Right click on the Computer button, and click on Properties.
Note: You could also just press the Windows Key + Pause/Break key to open System Properties.
3. Click on the System rating is not available, Windows Experience Index, or Your Windows Experience Index needs to be refreshed link.
4. Click on Windows Exoerience Index
5. Click on Your Windows Experience Index needs to ber refreshed
6 Click on the Rate this computer button, Re-run the assessment link, or Refresh Now button.
7. Finaly Click on Update My Score.
You will now see this status window.
on Mar 27, 2010 | Computers & Internet
Refresh brower
Then you can simply refresh it, you can click on the refresh simbol or click F5
Feb 23, 2012 | Google Chrome
The mouse on my computer is not responding, it is like it is frozen. i have tried to reboot but nothing is happening.
if you are using an optical USB mouse, then check if the LED sensor lights up, if the light sensor is off, then your mouse is probably defective.
If the mouse still lights up when your computer is on, then try to refresh the usb driver for this. go to CONTROL PANEL, select SYSTEM. Go the HARDWARE and select DEVICE MANAGER.
Look for MICE and OTHER POINT DEVICES, select your mouse driver, right-click and the UNINSTALL driver. Once mouse icon is gone, you can click REFRESH or simply restart your PC again and wait for windows to redetect your usb mouse.
Oct 18, 2010 | Computers & Internet
My monitor has started clicking at about 120 times a minute and has gone blank. What is causing that and what is the fix?
This is most likely a refresh rate issue.
Reboot your computer and hit F8 before windows starts to load safe mode.
In safe mode, go to control panel, display and then settings.
Change you monitor refresh rate to 60Hz and reboot.
Depending on your windows version it may be under advanced in settings.
If this doesn't help it may be a hardware issue.
Sep 10, 2010 | Xerox Computers & Internet
How to troubleshoot flickering, jittering, shaking, or wave-like images on a LCD monitor. 1) Connect the display to the computer. 2) Turn on the computer.
Any monitor has something called a screen refresh rate. If you are replacing your old monitor with a newer one, there is sth called a screen refresh rate that you need to configure. Older monitors (size also matter) have a lower screen refresh rate than the newer ones. If that happens to be your case, find the refresh rate of your new LCD on its manual and adjust it like this.
  1. Right click on an icon free area on your desktop.
  2. Click Properties
  3. On the Property dialog click on the Settings Tab
  4. At the bottom of the form click on Advanced
  5. On the coming property dialog click on the monitors tab
  6. Under Monitor Settings you will find the screen refresh rate combo box, here select the rate that suits you screen and click apply.
  7. confirm your actions in the confirmation window.
Note: Be sure to select a screen refresh rate that matches your screen. If you select a rate bigger than the LCD's capacity you will end up with a black screen on your monitor and won't be able to see the desktop unless you boot in safe mode.
Nov 25, 2009 | Sony VAIO VGN-CS220J/W Notebook
I have waves on my screen, what do I need to do to get rid of them?
you don't say whether your monitor is crt/tft....
either type the problem is likely to be refresh rate of the monitor...
try this... (xp pro sp2)
  1. Open Display in Control Panel.
  2. On the Settings tab, click Advanced.
  3. On the Monitor tab, in the Refresh Frequency list, click a new refresh rate
  • To open Display, click Start, click Control Panel, click Appearance and Themes, and then click Display.
  • The default refresh frequency setting is 100 Hertz, although your monitor may support a higher setting. Check your manufacturer's documentation for information regarding the settings your monitor supports.
  • A higher refresh frequency reduces any flicker on your screen, but choosing a setting that is too high for your monitor can make your display unusable and cause damage to your hardware.
  • Changes to the refresh frequency affect all users that log on to the computer.
good luck, rate if useful please
Oct 27, 2009 | Computers & Internet
Compaq presario 2127AD
Flickering may b due 2 ur Display configurations so u may also use some Display software or u may manually correct it.
Properties>Settings>
1. adjust ur screen resolution
Change the refresh frequency for your monitor To change the refresh frequency for your monitor
  1. Open shortcutcold.gifDisplay in Control Panel.
  3. On the Monitor tab, in the Refresh Frequency list, click a new refresh rate.
note.gif Notes
  • To open Display, click Start, point to Settings, click Control Panel, and then double-click Display.
Jun 03, 2009 | HP Compaq Presario V3000T Notebook
Monitor flickers when you click a hyperlink
It sound like the video refresh rate is to low. To change the video refresh rate consult your monitors user guide and if you are running WIN XP operating system you can try the following:
How to Change the Screen Refresh Rate of Your Monitor
loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
Let me know if this helps and thank you, Binary Bob
Sep 25, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Computers & Internet Logo
David Payne
David Payne
