I have philips powervision tv lost my remote plz tell me how tune channels from tv buttons.
Slinteriors
  • 8617 Answers
SOURCE: I have a philips tv
here is a link to the phillips universal remote page that has all the codes for any brand tv including phillips and it will explain how to program the remote try the codes for phillips one of the codes should work.
http://www.universal-remote.net/philipsmagnavox.html
Posted on Apr 08, 2008
  • 319 Answers
SOURCE: tune in an older (1996/1997) model Philips tvwithout a remote
Most TVs have features that cannot be accessed w/out remote. Make sure you copy exact model number on TV then go online to seach replacement remotes
Posted on Apr 21, 2008
SOURCE: Philips tv Model 24RF50S141. I
I have solve the problem myself by going to channel install on the menu and advancing the channels with the right key on the channel line rather than using the channel up/down buttons. Which is partly my stupidity and the Tech at Philips failed to tell me. I was just racking my head and stated trying different things until I discovered the real solution. Besides at my age I have forgotten more things than ever learned!
Thanks for you interest!
John
Posted on May 31, 2008
  • 8 Answers
SOURCE: Tuning SD-M1407
use the button's on the front of your tv or buy a universal remote it will help with some function's $5.00 anywhere or you can buy a refurb remote for $135.00 on the internet rocky
Posted on Jan 24, 2009
  • 150 Answers
SOURCE: Unable to tune the channels into the tv.
send me a picture of the front panel I will tell you how.
Posted on Apr 28, 2009
I got this Philips Powervision old Projection TVbut without remote; how can I tune the channels since the buttons are not applicable.
Check online for universal remotes.
Most will have downloadable instruction to see
if your model is listed and has a code.
If so problem solved.
Mar 09, 2015 | Philips Televison & Video
Sony bravia v series 32"
hi,
IT normally happens after factory reset is done. You need to reprogram the channels. Try the auto program (AUTO TUNING) Process.
  1. On your remote commander " Press HOME or MENU button"
  2. Scroll down to " SETTINGS or SET-UP"
  3. Then to "CHANNEL SET-UP"
  4. Select " AUTO PROGRAM " To Auto program your LCD TV and it's done..
Jan 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Instructions to tune Philips tv 54cm colour TV. Search & store channelss
Hello
You haven't mentioned about the model number of your Philips TV. Different models have different type of tuning procedures. Any way I hereby send a procedure to set it autotuned. If it Doesn't work, please inform me through Fixya, stating your TVs model number also. ok
Press "Menu" on the remote control handset, and select the installation language.
Select a language and confirm it by pressing "OK" button on the remote control.
Press ' button to return to 'Instalation' menu.
Press "Menu" on the remote control handset and select Installtion > Preferences > Location.
Select 'Home" and press "ok" to confirm.
Press ' to come to the Installation menu.
TO TUNE CHANNELS AUTOMATICLY AND TO STORE
Press "Menu" on the remote control, "Select Installation" '>' Channels '>' Autoprogram '>' Start now.
Press "OK" and allow the start installation automatically.
If you run autoprogram when you have locked channels, a messege appears asking to enter your PIN code in order to complete instllation.
Try this, if doesn't work inform me with TVs model number. OK.
Nov 04, 2010 | Philips Televison & Video
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
PHILIPS 32PF7331/12 LCD TV
Press tv on sky remote then press help ,channel list appears . goto tv set use onset channel change button to scroll to hd channel .press volume up button onset to select.
Sep 28, 2008 | Philips 26PF5320 26 in. LCD Television
I have a philips powervision TV - Have lost the Manual aqnd I want to tune it into new channels. Cheers! Mike
I found a NTSC 3.58/4.43 in the street my friends and I don't know how to connect it to the antenna without a remote control is there anyway you can without a remote
Jul 20, 2008 | Televison & Video
I lost my remote codes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 23, 2008 | Philips Magnavox Learning Universal Remote
Philips Matchline
Under the flap on the remote control, there are two buttons with a line and two arrows drawn between them, press both of these buttons together and the instalation menu will appear, choose automatic installation and in about 5 minutes the TV will set istelf up.
Jun 20, 2008 | Philips 30PW633R 32" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
