Just got an oil changei in my 1978 chevy nova coupe but i dont know how to reset my oil light. also my speedometer doesnt work, how do i get it to start working
the light came on and i checked the oil but it was full. I got the oil changed the next day of course but the light still hasnt went off. any suggestions?the light came on and i checked the oil but it was full. I got the oil changed the next day of course but the light still hasnt went off. any suggestions?
You can't post conmments that contain an email address.
Sounds like you need to drain all the oil out and check for particles in the oil. Some of the new oils have a "cleaner" in them and will loosen debris in an older tranny which will block ports in the tranny. If so... try flushing the tranny with a cleaner availble at most Auto stores. Ask the dealer (preferable a older one who knows about older cars if this will work)!
This is the wiring diagram for a 72 Chevy Nova. Everything that's needed to get the engine electrical up and running.<br />Eng. is the engine bay wiring.<br />B - battery<br />S - starter<br />C - coil<br />D - distributor<br />R - regulator<br />A - Alternator<br />H - horn relay<br />T - temperature switch<br />O - oil pressure switch<br /><img src="suzman_4.JPG" /><br /><br />Int. is the interior wiring for the engine.<br />Ign. - Ignition<br />N - Clutch/Neutral safety switch<br />T - Temperature guage<br />O - Oil light<br />C - Charge light<br /><br /><img src="suzman_5.JPG" /><br />
Hi looks like your head gasket is gone, check if oil in water or water in oil, oil will go grey in colour, and open rad, when cold, check for signs of oil. But not good symptoms, sorry!
It would be the cable. You can try pouring some oil down the cable cover. That should clear up the noise and may smooth out the jumping. If it doesn't smooth it out then the cable will need to be replaced because the ends are getting worn.
If you are having trouble finding a new cable then call your local cab companies. Taxi meters used to run on a cable and the place they got those cables done at likely still has the tool to make cables with. Hope this helps.
press and hold the reset and info button at the same time and the oil rest light should display and press and hold reset then it should say a confirmed
The CHANGE OIL LIGHT can be rest by putting on the key with engine off, and pumping the gas pedal up and down completely 3X in 5 seconds. Sould clear then, if nec. repeat.
