Question about Hoover Freespace Evo Pets TFV2015
Power switch doesn't work
Hoover started to only switch on by plugging it into the mains and not the power button. now won't switch on at all.
So replace the power switch you can get one at guarantee vacuum and sewing center
Posted on Mar 21, 2014
How can I get power switch to work on hoover spinscrub steam carpet cleaner?
Replace the switch.
http://www.ereplacementparts.com/hoover-f5914900-steamvac-with-clean-surge-parts-c-37315_37419_37425.html
Aug 28, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Vax zoom not staying on
It is likely that the button (switch) is defective and will have to be replaced
Jun 28, 2013 | VAX Appliances Vacuums
Hi, I have the Hoover d14194 bagless pet vacuum..when I switched it on it worked but kept cutting out, I emptied it and cleaned the filters but now it won't even switch on.is there something I can
You could check the motor brushes, if they are worn and check for loose wire connections.
Another possibility is that there may be a break in the lead, plug it in and shake the lead, if it starts and stops you have probably found your problem with a broken lead.
Jan 01, 2013 | Vacuums
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
Hoover Model SH80520 starts and won't quit
that's how it's supposed to operate, switch on turns the unit on. switch off turns the unit off. thier is a wire that is connected to the leads on each outlet that turns the unit on when the hose is inserted and the switch is in the off position.
Mar 30, 2012 | Vacuums
Hi, My Henry hoover has stopped working about 10
Check the motor brushes as well as the on/off switch.
Sep 20, 2017 | Hoover Vacuums
The hoover keeps switching on and off automatically.
Sounds to me like there is either a loose wiring in the pedal or mains power cord. Check that the plug is secure. Check both filters though - one behind the bag (usually square and slides out) as well as the main exhaust filter at the back between the power on and cord rewind button. I used to own many Telios models but they are known to have cheap shearing cords which can only be replaced by a Hoover repairer. Sometimes the On pedal can be affected as well particularly if it has been stamped on heavily.
Dont forget to rate, ty.
Mar 28, 2009 | Hoover S3330 / S3332 Straight Suction...
Hoover s3765 windtunnel power head does not run
I have the exact same problem as you have. Have you found a solution since you posted on Mar. 18, 2009? Thank you.
Mar 18, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hetty hoover not working. It was working ok until I opened it up to search the bag for a missing jigsaw piece and I put it all back and I hoovered the mess on the floor, then switched off and switched on...
Know cut off switch, its just not getting power ? 2 things its ether at the wall plug or in side the unit. I have never found a fuse in side them , so it may be just a lose wire did you try other plugs in the house . good luck DFD
Jan 22, 2009 | Henry Numatic "" Canister Vacuum
Hoover Freespace Evo Pets TFV2015 Logo
117 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
