I am getting a service light and general fault message on my rs4.Apure1400. My salt reading is 3100. the Apure is showing 90% and then 121( not sure what that is). The serial nubmer is a07gk1484. The system will not stop running ( Pump) because it states that it is in freeze protection. We moved into this house a few months ago and aren't sure what needs to be done.
Your air temperature sensor may be broken. Does the display show the correct current air temperature? You can go outside and put the system in service mode. That will shut the pump off. Then you can disconnect the air sensor and see if the pump acts right after putting it back into auto mode.
Testimonial: "The temperature is definitely wrong! IT's way off. The pool temp is right. I had the water tested and there was NO chlorine in it! If the sensor is bad then I am guessing it can't tell the system to make the chlorine? SHould I leave the sensor disconnected or plug it back in before I put the system back into auto mode. Do you know where I can order a new sensor? Most cost effective place. What should they cost?"
SOURCE: usig/overriding freeze protection on a pol/spa filtering system
Any entry into SERVICE mode from the outside panel will override a freeze protect. Be sure to put it back to AUTO in order to resume freeze.
SOURCE: Can't shut down the main
The relay is probably bad. If you open up the main outdoor panel, you can watch the bottom of the relay for the pump, ususally on the upper left of the relay cluster (black). Watch for a small tab popping out when turning on/off. If you don't see it, the relay is bad. This assumes you hear a click when doing this.
SOURCE: Understanding how to use spa with freeze protection on
freeze protection will always be on. when you're done using the spa just push the heater/spa button. it will turn off. when ever the air temp drops below 37-39 degrees the air sensor will tell the system the it's getting cold and it will kick on the pump. you can change the it under settings menu if you want other pumps to come besides the filter pump
SOURCE: We just moved into our home and there is no manual
Here is a link for the Manual and trouble shooting guide. Aqualink
