Question about Smeg DF612SI Dishwasher
Replaced door handle and can't get panel back in
Replaced door handle now can't get panel back in
How do you fix a passenger door handle on a Ford Explorer 1999
inside or outside????????. either way remove the door panel. the rest is easy
Apr 24, 2015 | 1999 Ford Explorer
Driver side door will not open when pulling door handle from interior. How can I fix?
IF THE LOCKS ARE NOT ON THEN THE HANDLE NEEDS TO BE REPLACED
Jan 05, 2015 | Cars & Trucks
I have broken handle on the GE Spacemaker Model JVM130H. Can this be replaced and how?
The door handle can easily be replaced on most microwave ovens. You just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The cost usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. However, price and configuration of your oven also depends upon the MODEL NUMBER. If the model number is correct, the part number(s) for a replacement door handle is WB15X10119 and WB15X10120. The door handle on this model has two pieces.
If you have any questions, please post back with your model number and let me know. I hope this helps you
Jan 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How to remove the door panel on my Volvo V70 (1999) in order to plug in the wires from the door electric mirror (replaced with a 2nd hand one, old one broken!).
On the inside trim, you can remove screws (these screws may be covered by filler pieces or may be visible, or they may require you pry a plastic piece off that covers the screws) that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls.
Nov 11, 2009 | 1998 Volvo V70
Door handle of 94 Lumina broken on the inside .... need info on how to get at it
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge.
Sep 16, 2009 | 1994 Chevrolet Lumina APV
How do i replace the door handle.
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions about this repair, please let me know. I hope this helps you.
Aug 10, 2009 | Microwave Ovens
How to replace door handle?
The door handle can easily be replaced. This is a common problem with microwave oven doors.
This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
Jul 30, 2009 | Microwave Ovens
Door handle broken away from microwave unit.
The door handle can easily be replaced. This is a common problem with microwave oven doors. You would think the manufacturer's would make them a bit more durable.
Jul 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
2003 Dodge Durango - How do I take off door panel
After you have removed the screws (one behind the door handle, you will see a little tab, pull it back to expose the screw) lift the panel and look behind it, there you will see (2) rods going to the door handle and lock. Use a small screw driver to pry the keepers away very gently. Pull the rods away from the keepers. Also, you may want to remove the panels from the arm rest and disconnect the wires from the control panel. I just replaced the window regulator for the second time.
Jun 11, 2009 | 2003 Dodge Durango
Kitchenaid model KHHS179LSS Microwave oven handle replacement
There is a pin holding the door on upper right hand corner of the door. Holding the door in the open position, lift up on the door a little and remove the pin. The door will come off. There are two screws on the edges of the door on the end where the handle is located. Remove the screws. Now, Take a slim screw driver, and carefully pry between the inside door panel and the ourside door panel starting at the end where the door handle is. Lift the inside of the door out. The opposite end of the inside door panel will come out last. Believe me, this works. Getting it back together is a little bit different, but it snaps back together without using tools. Just put the inside of the door back by laying it down with the handle side down after you have replaced the handle of course. Now, pushing in on the inside of the door panel starting on the handle side, start with lining up the panel and push gently. It will go back into place much much easier than it comes out.
Jan 27, 2008 | Microwave Ovens
Smeg DF612SI Dishwasher Logo
18 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
paul
paul
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
