Question about Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool WW185 washer with a computer board. It occasionally works but usually just doesn't. All the lights flash on & off when I try to start it. I live near the beach and heard these t
This product was purchased in the Dominican Republic.
aborcass
  • 2651 Answers
SOURCE: Whirlpool Duet Washer Error Code F-11
yea id call them back and fight them to pay for the repair, at least the part , tell you saw it on the internet.. It was one of the trickiest ,wouldnt say common but def. an issue with this machine. In my own experience replacing the top ccu has done the trick at least 90 percent of time.F11 is communincation error between the top and bottom boards, butalso goes through the latch assy as well. and as far as the ccu goes there are 2 out there, check your model before ordering look closely cause a a ghw9150pw0 is a diffrent board then a ghw9150p1( and different by a bout $200 in board pricing)
Posted on Mar 15, 2008
fridgetech
  • 473 Answers
SOURCE: Code F1 @ Whirlpool Duet Sport Washer
An F1 is almost always a defective main control board. Could try unplugging the unit for a few minutes and see if it will reset. The part # for the board is W10110072. Sears sells it for $119.46 http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WFW8300SW01&productCategoryId=0153200&brandId=1198&modelName=RESIDENTIAL-WASHER&diagramPageId=00003&componentDescription=CONTROL%20PANEL%20PARTS&documentId=W0607261&backToLink=Return%20to%20Sub%20Components%20list.
Posted on Dec 12, 2008
  • 58 Answers
SOURCE: whirlpool AWM6100 front loading - door open when not!
it's probably the innerlock, is the door locked?? if not it could be the innerlock
Posted on Mar 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: After 12 months our new Whirlpool Cabrio washer
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
livewire874
  • 618 Answers
SOURCE: My whirlpool LHW0050PQ4 worked fine last week, but
Do you hear the door locking and unlocking?
Posted on Nov 22, 2010
I have a wtw5600xw0 Whirlpool washer. When I press the start button the sensing light and lid lock lights turn on. Then after a few seconds the lid lock light goes off and the sensing light stays...
Swich off the machine, try some WD40 on the door mechanism (on machine lock, not on the door) and open & shut for a minute or two. Then try the machine, spin only just to try.
Rate pl, if solved, or dont!
Source
Nov 27, 2012 | Whirlpool WTW5600X Washer
Replaced the whole top panel. now start lights only flash wont start washer
You might have blown a fuse on the circuit board or fried a transistor on the board
Oct 07, 2012 | Whirlpool Duet GHW9150P Front Load Washer
The machine appears to be stuck in a wash cycle. After unplugging the machine & plugging it back into an outlet you have no indicator lights. The only button that has a response when pressed is the...
this machine sounds to have a computer board problem I have a calypso washer also and i had the same problem so I ordered both computer boards and replaced them and everything was working like new , I haven't had any further problems since
Jul 31, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
When turned on machine, no lights came up, then all lights lit up and beeped and on panel E90 kept flashing
An E90 error indicates some sort of communication error between the two boards that control the washer. Usually it's a problem with the wiring. (At least for Electrolux and related washers, E90 is a communication error.)
You can try unplugging the washer overnight and then trying again. This resets the board. Otherwise, you need to open the washer and use an electrical contact cleaner. Check all the wiring for any corrosion or solder issues. This will be time consuming.
Alternatively, you could replace both control boards (usually comes a large fraction of the cost of a new washer when you add the repair man's time). You usually can't tell which of the two boards are bad so replacing just one frequently doesn't solve the problem.
I hope this helps.
(if you add a comment with the make and model of your washer, I'll check the parts cost/availability if they are at my usual sources.)
Jun 26, 2011 | Washing Machines
MY WHIRLPOOL FRONT LOADER WASHER JUST QUIT WORKING. IT HAS LOST ALL POWER. THE DOOR WILL NOT EVEN OPEN. PLEASE HELP?
I've worked on similar models with all manner of problems. Try unplugging the machine from the electrical outlet for about 30 seconds then, plug it back in. This will "re-boot" the control board. If it doesn't work, I'd say the control board is bad.
May 06, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
The light that displays the length of time for the cycle is flashing and saying F01 and the machine is not commencing
Try unplugging the machine for at least a few minutes - if this doesn't work it will be a engineer call out.
May 03, 2011 | Whirlpool Duet WFW9550 Washer
Whirlpool washer spin cycle works off and on
no the slowing down maybe caused by a sticking clutch and as before the lid switch may also be broken if when you depress it the reason i'll give is if you bump it it sometimes starts up replace the lid switch and once done the circiut will close properly then the delicate cyc should work
Aug 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Duet GHW9150P Front Load Washer Logo
29 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
