Question about Flotec 1 Hp Deep Well Pump
I have a deep water well, the water is brown & does not seem to clear itsself even after we let the water run for an extended period of time. The well has not been used in excess for the last few
Deep water well problem with water being brown
    Sergeant:
    Champion:
  • 266 Answers
Do you have a filter system..is this water going to be potable?
I would reccomend a water softener, and an iron filter for brown well water. We have used well water S Cal and Minnesota
Posted on Mar 21, 2014
What are the benefits of wearing travel socks during travel?
Travel socks are advised to take when traveling on a long-haul flight to reduce the risk of DVT(Deep Vein Thrombosis). Before you travel wears these socks to prevent DVT and formation of blood clots.For quality buying compression stockings,a leading stockists of Venosan compression stocking in Ireland
Venocare
Address: 1 Pearse St.
Clonakilty,
Co. Cork
Ireland
Dec 12, 2015 | Cars & Trucks
Tip
Water well cleanig
everybody living in the country with a water well, should and can clean their well with peroxide. A safe fashion is to use sodium percarbonate.Depending on the product and strenght, use apprx 4 litres of sodium percarbonate in well, run a garden hose back to well, then make water run for apprx 8 hours at 1/4 flow.Open all fawcets in the home , one at a time for a period of 5 minutes to alllow the well water contact your piping, thus cleaning these.Leave to sit overnight, with garden hoe removed.Reconnect hose in the morning, flush for an hour or so or until you run out of water. Do not let your pump run dry for any extended period of time otherwise you will burn the pump.You know the sodium percarbonate is gone when the water is free and clear of foggy looking airated water
on Nov 11, 2011 | Stainless Dishwashers
External unit on my walk-in cooler will not shut off. Seems to be due to the Ranco Pressure Sensor. How do I fix or adjust?
Diagnosing Walk-in Coolers & Freezers Problems
blog.uscooler.com/walk-in-cooler-freezer-problems/
Jun 7, 2013 - Diagnose Walk-in Cooler & Freezer Refrigeration Problems ... For many evaporator units, the ice isn't melted, or the water isn't .... It works for few days (2-3 days) and it stop and does not run until I shut off the power .... My walk in compressor seems to be running and not shutting off. .... outdoor ambient= 85
Maintaining & Cleaning Your Walk-in Cooler or Freezer
blog.uscooler.com/maintain-walk-in-cooler-freezer/
Jan 7, 2015 - Torn gaskets can let warm air infiltrate your walk-in cooler or freezer. Close the door when not in use. Do not block or prop the door open for extended periods of time. ... on suction lines between the condensing unit and evaporator coil. ... Make sure the lights are off when exiting the walk-in. ... clean walkin ...
[PDF]INSTALLATION & SERVICE MANUAL - Polar Leasing
Dec 10, 2015 | Refrigerators
I have had this iron (Norelco Ultima 50) for 20+ years and it is starting to periodically spurt out lite brown and staining my clothes. I love this iron and dont want to give it up....help!
Light brown sounds like rust. I would get some "CLR", and run that through the iron. Rinse out with clear water several times, so you get all the stuff out.
Jul 15, 2015 | Irons
I have a deep water well, it has not been used a lot in the last few years & the water is brown, can this problem be rectified
Hi Enslow, I can only guess that if the well hasn't been in use for some time then it's possible that if you run the pump and get brown water it may clear in time. My suggestion is simply continue to run the pump few a decent period of time that maybe a few days . As you do this take samples in say clear glass containers and see if there is improvement. So take samples every couple of hours and it will be apparent if the water is clearing or not. Make sure the pump is a decent distance from the bottom of the well.
Hope that helps
Regards
Steve
Mar 17, 2014 | Flotec 1 Hp Deep Well Pump
MY FRIGIDAIRE FRONT LOAD WASHER WONT FILL WITH WATER OR SPIN . HAVE TRIED CLEANING THE DOOR LOCK & UNPLUGGING IT FOR EXTENDED PERIODS OF TIME.
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
I accidently drove my 2000 Dodge Stratus through 1 foot of standing water. Will my engine be damaged
If your engine didn't die, it'll be fine. If the engine did die, it will probably start and run fine if it's allowed to sit for a time so that it can dry itself out. THAT is IF your engine simply got a little wet so as to cause the ignition system to fail. What can be pretty bad, though, is if the car is allowed to sit for an extended period of time in deep water.... or the water is deep enough or splashed hard enough that your air intake for your engine starts sucking in water. If it was only a foot of water, and you weren't going fast, things should be okay. If your air intake has sucked in quite a bit of water, your engine probably needs professional care.
Oct 31, 2013 | Cars & Trucks
I get brown stuff coming back into the pool when I turn on the pump in filter mode. This goes on for about 30 seconds and then clears off, but the water remains cloudy even after long period of running...
You have a multi-port valve? There is a 'rinse' mode on the handle. After you back-wash, move the control to 'rinse' and run for 30 seconds or so ... them return it to filter mode. Always shut the pump off enwh changing the valve settings - ALWAYS wait at least 10 seconds when switching the pump from off to on. Always move the handle in a clock-wise direction.
I suggest you run your filter for longer periods each day, maybe even 24 hours until it gets cleared up. Have you removed the metal from your water using a sequestering agent? Use according to package directions. Balance your water. Keep the CL around 5 ppm, the pH at 7.4, the calcuim around 250, the TA at 100. Cyanuric acid should be betrween 60 and 100 but no more. Use "super blue" in your pool according to package directions. Have you checked the Combied Clorine? (The difference between Free CL and Total CL = Combined CL)
Jul 24, 2010 | Hayward SAND FILTER, PRO SERIES
Twice in the last year, the floater of my toilet jammed causing the water to run all night long. After running for 12 hours the water kept running but turned brown and muddy. After a day or so, all returns...
the valve that controls water flow is sticking. replace the interior water stand pipe valve with a new one you got dirt in the valve and it is not clsoeing. It would be a good ideal to put a filter on the output side of the pump. Aslo the wll level is most likely low due to lack of rain causeing the brown water. If you need more help post and let me know. the Vlave assembly costs $15.00 for a good replacement. also check that the flush handle is notr cathcing on anything and the flapper valve does not have a hole or rust arounf the ring.
Sep 28, 2009 | Little Giant Pumps W8G-X Submersible Deep...
Brown water drips
This may be down to contaminants in your water supply, or any "ironing water" you may be using.
There will be a build up inside the hotplate where the water is vapourised.
To clear this, refer to your manual or simply put on high steam setting, rest on it's heel, and wait for the indicator light to go out, then unplug, and hold horizontal over the sink. Press any steam boost buttons you have untill the iron is cold - and you just get water flowing out.
The best and cheapest water to use I've found - is the condensate from condensing tumble dryers. Which most people just tip away! It is condensed steam - so contains no minerals to fur up irons. If you don't have one - ask a neighbour for a few gallons.
Jun 29, 2008 | Euro-Pro Shark GI490 Iron
Flotec 1 Hp Deep Well Pump Logo
90 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ryan Ross
Level 1 Expert
Are you a Flotec Garden Expert? Answer questions, earn points and help others
