Question about Juki TL-98Q
While trying to free motion quilt on my juki TL-98Q, it becomes very hard to move the quilt whenever I come to a seam. I have already turned the pressure foot dial to the lightest setting. I simply
The machine runs fine otherwise. I am using the freemotion foot and have dropped the feed dogs. Cleaned, oiled, new needle. Do not have this problem when using walking foot. Obviously, feed dogs help it along, but I need to be able to quilt without feed dogs doing the work.
  • Juki Master
  • 1,564 Answers
I have never used a machine to free motion quilt. That said, I have had issues sewing over thick seams. Since your machine runs smoothly otherwise... I think it is the thickness of the seamed area that is causing your problem. It may be too late but you could try trimming your seams so the layers fabric graduate to full thickness. Or you could use a chop stick or popcicle stick to press down on the thickness as you guide the machine over the seam. I also suggest that you Fan your seam allowances where your blocks come together. You can see how that is done here. http://www.allpeoplequilt.com/videos/v/62207505/machine-minute-bulky-intersections-fanning-seam-allowances.htm
Posted on Mar 19, 2014
3 Suggested Answers
RichSew
  • 194 Answers
SOURCE: Can't free motion quilt on Juki-T98QE
You need to be using a free motion foot or a darning foot, the regular presser foot is not for free motion.
Posted on Jun 03, 2010
SOURCE: needle thread breaks while quilting on machine frame
I posted question about top thread breaking when quilting (using walking foot). Finally solved my problem, my solution may help others. Decrease the presser foot tension to nearly 0. Had tried different threads, tension settings, needles. Nothing worked until I adjusted the presser foot tension. Quilting went like a dream, even through seams ect, also worked for attaching binding.
Posted on Feb 15, 2013
Speed control
I haven't sewn on this model in about 10 years, so I am rusty. I don't recall a slide or switch to set the range of stitch speeds, so one of the things you need to do is learn to feather the pedal instead of just stomping it. You can often figure out how to block the pedal travel with a couple thicknesses of cardboard cut to shape, or a piece of pencil eraser to mechanically block the highest pedal pressure, but usually it's just better to learn to control the pedal. Finally, the best free motion quilting is often done with high speed stitching but moderately slow fabric movement.
Feb 14, 2014 | Juki TL-98Q
I was recently given a TL-98Q Juki. I have it set up on a long arm quilting machine. I have put two sheets with cotton batting between on the machine. Everything is set up. I started the machine and...
Be sure you have installed a brand new needle. If it still does not pick up the bobbin thread, the machine may be out of time.
If the presser foot does not set firmly on the fabric, then that is what you want for free motion quilting. However, if you mean the presser foot is sloppy (wobbly), then the attachment may be loose or the presser foot is worn.
Jun 21, 2017 | Juki TL-98Q
When free motion quilting I get loops on top of the fabric and on the bottom when doing tight curves. I also get thread "puke" - tangles and snarls on the bottom when going through the quilt...
Check the height of the quilt under the machine-adjust the bars until the quilt is just barely over the bed of the machine, and level front to back and side to side. Also, level up the frame, using a long carpenter's level. You'd be surprised how much this can help with all sorts of thread problems.
Feb 23, 2011 | Juki TL-98Q
Thread breaks when free motion quilting...what tension should I be at?
Firsrt, try going slower, especially on curves. The Juki is so danged fast, it's easy to run faster than the thread can handle. As far as tension, the best approach is to experiment with a scrap quilt "sandwich" until you find the best tension settings. Also, could your problem be with the thread you're using? Different threads call for tension adjustments. Try using a bigger needle-smaller needles can "cut" the thread, as can defective needles, especialy on curves with free motion. Tension issues are, without a doubt, the biggest problem I've had, but patience and experimentation will usually solve whatever is going on.
Jan 16, 2011 | Juki TL-98Q
I am having problems with my Juki TL98E skipping stitches when I free-motion quilt. I have cleaned it well, put in a new needle but still having problems. When I stitch forward, it's ok, but when I try to...
It is a timing issue. I have a TL98E. The needle bends a bit when free motion quilting, moving the needle away from the hook, thus missing the thread. Try to put in a larger needle, or have the timing changed so that the hook "kisses" the size needle that you want to use. Tammy
Nov 18, 2010 | Juki TL-98Q
I use my JukiTL-98Q on a quilting frame to free motion quilt. I called in a sewing machine repairman to clean and time my machine. After he left, my machine is skipping stitches while it sews, sometimes...
hi there
i have service manual and parts list for this machine , if this catalog can help i can send to you just email me.
best regards
ashraf abozid
aabozid@hotmail.com
Sep 04, 2010 | Juki TL-98Q
May 29, 2010 | Juki TL-98Q
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Juki TL-98Q Logo
184 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
