My computer takes more time or 10 to 20 minute to start.
In recent months, my computer doesn't work well. When I click the button start, the screen appears black and it takes more or sometimes 10, 15 and 20 minutes to ensure that the window is accessible.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
Restore previous good restore point
Posted on Apr 28, 2014
  • 263 Answers
SOURCE: presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Posted on Jan 05, 2008
iqbal_del
  • 655 Answers
SOURCE: Acer travelmate 2350 take time to start (5 t0 30 minutes some times)
This is not any problem. B.coz if u have installed Vista Home Premium its take time after loging to display sacreen as pe your loaded software and drivers.
Posted on Mar 04, 2008
  • 36 Answers
SOURCE: dell mini forced shut down, now runs slowly
go to start - accessories - system tools - system restore - choose a date when it was working fine, preferably the earliest date. then wait for it to shut down and restart. you will not lose any saved files or folders, you will only lose programs installed after the date you choose.
Posted on Jun 18, 2009
durtopian
  • 408 Answers
SOURCE: HP Pavilion dv5 laptop screen keeps blacking out.
You have either a broken wire in display ribbon or a loose connection at the motherboard.It probably developed from opening and closing the display.Sometimes the wires will get in a bind at some point and break a wire or pull it loose.You could try and take the front portion in front of the display apart(make sure it is unplugged for a bit)and check for that bad connection.
Posted on Aug 03, 2009
  • 477 Answers
SOURCE: I have a HP Pavilion tx 1000. Blank screen, LED lights on.
Hello, seems like your sleep mode doesent work as it should. Try to download all windows updates and look for a fix on microsoft sites.
But the best solution is to inactive the sleep mode setting and use the Hibernate options(if you want a fast start) but I suggest that you turn off windows with shutdown, its the safest and best way to have your computer to work properly.
To inactivate sleep mode.
windows xp
go control panel and power options
Change the system standby to never.
also choose power schemes battery, and change the system standby to never.
also the harddisk to never.
This should solve your problem.
To activate Hibernate you need to click on hibernate tab and bock the square.
hibernate= saves all your work to harddrive to restart your computer where you left off.
sleep mode= saves your work to RAM memory=takes a little bit energy.
Posted on Sep 04, 2009
Testimonial: "already, my computer is not freezing:) thanks for the tip."
How to reset time and date on omronhem790itcan
SETTING THE DATE AND TIME
RESETTING THE DATE AND TIME
To adjust the date or time after it has been setup when you first use
the unit.
Start with the monitor in the of f position.
1. Press and hold the SET button.
The TruRead
will appear on the display for the USER ID selected.
To change the on or oFF setting press the Memory button, then press
the SET button.
The interval time flashes on the display. Press the Memory button to
select the desired interval time, then press the SET button.
The year flashes on the display.
2. Refer to page 19, SETTING THE DATE AND TIME.
NOTE: If you need to change the Date and Time, always adjust the
Date and Time setting before taking the next measurement
Set the monitor to the current date and time before taking a
measurement for the first time. If the date and time are not set correctly ,
the measurement values stored in the memory and the average values
may not be correct.
The Blood Pressure Monitor automatically stores up to 84 individual
measurements values with the dates and times. The monitor also
calculates weekly averages for measurements in the morning and in the
evening. Morning and Evening averages are stored for this week and the
last seven weeks.
The monitor can also calculate an average reading based on the three
most recent measurements taken within 10 minutes of the last reading.
NOTE:
• If only two readings are stored in the memory for the 10-
minute period, the average is based on the two readings.
• If one reading is stored in the memory for the 10-minute
period, this reading is displayed as the average.
1. TO START THE SETTING
Press and hold the SET button to
adjust the date and time.
2. SETTING THE YEAR
The year can be set between 2007 and
2030. When the display reaches 2030,
it will return to 2007.
Press the Memory button (
advance by increments of one year.
Press the SET button to set the current
year.
The month flashes on the display.
NOTE: Press and hold the Memory button (
to advance the date and time values faster .
3. SETTING THE MONTH
month.
Press the SET button to set the current month.
The day flashes on the display.
4. SETTING THE DAY
Press the SET button to set the current day.
The hour flashes on the display.
5. SETTING THE HOUR
The time is set using AM or PM.
Press the SET button to set the current hour.
The minute flashes on the display.
6. SETTING THE MINUTE
one minute.
Press the SET button to set the minute setting.
7. TO TURN THE MONITOR OFF
Press the START/STOP button.
NOTE: The monitor will automatically turn of f after the minute has
been set after battery replacement
sourcehttps://www.manualslib.com/manual/759601/Omron-Hem-790itcan.html?page=20#manual
Feb 08, 2018 | Time Computers & Internet
Advice for when my coputer screen freezes and the esc button doesn't help
Hi Donna,
if everyting is frozen and you cannot do anything with your computer, you can wait a couple minutes to see if it is only working on something in the background that is taking up all its resources... if it does not start responding by itself, and you do not want to wait anymore... push the PC's start button that you use to turn your computer on (not the windows start button) for 8 seconds and it should turn off. NOTE: any changes to data that was open and and not saved will be lost.
Hope that helps
Jan 02, 2013 | Dell Computers & Internet
My browser is doing strange things. It won't bring in some pictures from news articles. It doesn't give the buttons on FB that it is supposed to. Newsletters don't come into my email in...
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Jul 30, 2011 | HP Computers & Internet
How do I install a printer driver for HP Deskjet 2460?
Hello and welcome to FixYa;
This is the HP support site where you will find your driver;
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4062&lc=en&cc=us&dlc=en&sw_lang=&product=2510767
click link, it is for your model;
then enter the version of windows you are using;
then click on drivers;
then click download; here are the instructions.
Internet Explorer:
1. Click the Download only button.
2. When a new pop-up window appears, click on the Run button.
Note: Depending on your connection speed, the file will take some time to transfer to your computer.
3. If an "User Account Control" pop-up windows appears, click the Continue button.
Note: The file is compressed and may take time to extract and run.
4. Follow the on-screen instructions.
Firefox:
2. When a new pop-up window appears, click on the Save File button.
3. When the download completes, double-click the most recent file to start the software installation.
4. If an "Open Executable File?" pop-up window appears, click the OK button.
5. If an "User Account Control" pop-up windows appears, click the Continue button.
6. Follow the on-screen instructions.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
May 31, 2011 | Office Equipment & Supplies
MY COMPUTER BOOTS UP THEN GOES TO A BLACK SCREEN THAT SAYS..................STOP: c0000221 {Bad Image Checksum) The image iertutil.dll is possiblyu corrupt. The header checksum does not match the computed...
Greetings,
When you boot your PC, press F8 during the boot sequence to bring up the alternate boot menu then choose the option to restore to your last known good configuration.
Did you uninstall Windows Internet Explorer? If not, I also think you may have malware on your PC. Download and install a malware cleaner like Normal Malware Cleaner (If it doesn't work from your computer after restarting) then you will have to download it from another computer onto a USB drive)
If you can boot into Windows normally, run Norman Malware Cleaner right away, it may take a few hours to scan your harddrive for malware. If you can't boot normally, try booting into windows safe-mode by pressing F8 during the boot sequence and chose Safe Mode (without networking) then run Norman Malware Cleaner.
When Norman is done running, click the button on the bottom of the windows to fix the problems then you will most likely need to reboot.
If you need help with this let me know I will be glad to work with you.
Apr 18, 2011 | Computers & Internet
Switched on my laptop this morning,and i noticed that it took unusually longer to start.Then the black and white screen appeared-it said: "WINDOWS ERROR RECOVERY windows failed to start.A recent...
Hi it may be virus issue. i suggest you to try with last known good configuration so that it will take your computer to last good working state. for that tab F9(Function key) continously immediately once you turn on your computer until you get the advanced option on your screen. highlight last known good configuration and hit enter and it will boot in that mode once you get the main sceen CLICK start - > all programs- > Accessories - > system tools -> system restore and wizard will open and select Restore my computer to an earlier time click next next finish to set your computer to last good working condition. If that doesnt work reinsatll the OS
Dec 26, 2010 | Acer Aspire 4730-4947 Notebook
My computer won't recognize my wacom when I plug it into the USB. I've had it for three months and have just recently been having this problem off and on.
Remove and reinstall all USB controllers To remove and reinstall all USB controllers, follow these steps: Click Start, click Run, type sysdm.cpl in the Open box, and then click OK. Click the Hardware tab. Click the Device Manager button. Expand Universal Serial Bus controllers. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time. Restart the computer, and then reinstall the USB controllers. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
Apr 04, 2010 | Wacom (PTZ930AC) Graphic Tablet
Office 2007 reconfigures every time I switch on my PC
This issue can be resolved if you try the following.
goto start->goto run-->type MSCONFIG->goto startup tab----->click the button disable all, which you can find at the bottom of hte screen ------>click apply---->then click close---->restart the computer.
Jun 13, 2009 | Microsoft Office Professional 2007 Full...
Screen not appearing straight away
It could be your LCD backlight giving you problems till it warms up. Turn you computer on and while the monitor is displaying black and the power LED is green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. A 15" LCD monitor is probably not an economically repairable problem unless you have access to really cheap parts and have the skills and tools to do the repair yourself.
Jul 29, 2007 | AOpen F55PS (Black, Silver) 15 in. Flat...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
