Question about Konica Minolta Bizhub 500 Copier/scanner/printer/fax Network Finisher Stapler
How do l adjust ATDC gain on bizhub 500 - Konica Minolta Bizhub 500 Copier/scanner/printer/fax Network Finisher Stapler
    President:
  • Konica Minolta Expert
  • 347 Answers
You cannot manually adjust the ATDC gain in bizhub 500. Replace the developer and execute TCR sensor adjustment in service mode.
Posted on Mar 29, 2014
How do i fix the error code c2557?
in utility you have somthing like "check counter" try to get inside and then stop00stop01
Jan 20, 2015 | Konica Minolta Bizhub 222 Black and White...
Error COF33 in minolta di 1811
This is an imaging unit error, the developer may need to be changed
Nov 21, 2013 | Minolta Office Equipment & Supplies
Erreur cof 32
ATDC sensor malfunction.Try to change the ATDC sensor gain adjustment value,increase or decrease.If the error persist you must be change the developer and the perform the F8(developer and ATDC semsor initialization).To reset please tell me the copier model.
Apr 01, 2013 | Konica Minolta Office Equipment & Supplies
I have an error code C-2557 on this Biz 350 with the finisher, without the the finisher m/c works fine
C-2557 ATDC sensor malfunction.Enter in the service mode press following keys:
Utility-Metercount-Details-STOP-0-0-Stop-0-1-press 00000000 press Enter in Tech. mode select Printer than select ATDC gain and read the ATDC current value.If the value is situate 150-160 increase the value to 164-174 (to change the value press C and entering the new value)return in the copy mode turn OFF the copier open the rigy door than close and turn ON the copier and make a few copies.If the error persist discrease the ATDC value and make some copies.If the code persist change the developer .Before change the developer reset the special parts counter I/U counter,developer.After change the developer perform F8 and verify the new value to ATDC gain and notice.
Feb 19, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Error 2557
ATDC Gain abnormality.Automatic toner density control error.Go to tech rep mode and simply increase the sensor gain and restart the machine.
Aug 19, 2011 | Konica Minolta Bizhub C300 All-In-One...
Error c2557
you need to set the ATDC sensor gain from the tech rep mode. Remove the toner before you run the F8 function.
Jul 26, 2011 | Konica Minolta bizhub C250 All-In-One...
How to fix error c0f32 in konica minolta bizhub 180
C0F32 is relatd to Developer, enter in to programming............. utility, stop, 0, 0, stop, 0, 1
Adjust...... ATDC Gain if for example 142 ,make it 152 then see, if problem remain same then change Developer, as i had experience Konica 7115/7118/7120/ minolta di152 Drum , Developer are same,
Hope it wil help
Mar 24, 2010 | Konica Minolta bizhub 180 All-In-One...
Bizhub 350 error code c2557, how can i fix this?
This code happens if you replace drum without replacing developer. Both must be replaced at same time.
Sep 30, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Error F32
the error is COF32. You have to check the developing unit, to change the developer is needed and to run atdc auto adjust.
Apr 16, 2009 | Konica Minolta bizhub 180 All-In-One...
Our bizhub-250 receives a C2557, need help with service mode
Utility/Counter -> Details -> [STOP][0][0][STOP][0][1]
Go to counter and clear the life of the developer and drums and then run F8 from functions.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jan 11, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Bizhub 500 Copier/scanner/printer/fax Network Finisher Stapler Logo
402 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
