Question about Sharper Image The 8149SI Stainless-Steel 5-Quart Pressure Cooker
Steam leaking from pressure regulator not comeing up to pressure
The cooker will not come up to pressure
Looking for an instruction manual for my pressure cooker: Tfal Clipso Easy
T-Fal has a number of their pressure cooker manuals on the support page: http://www.t-falusa.com/instructions-for-use/Products/Non-electric-pressure-cooker/csc/NonElectricPressureCooker . None are labeled the Clipso Easy. There are the Clipso, Clipso America and the Clipso Induction Compatible Pressure Cookers. On web sites advertising these models, they are all "Easy" pressure cookers with one-handed operation.
Please check the pressure cooker for a product number to find the correct manual. The different Clipso pressure cookers are very similar. The direct link to the Clipso manual is http://www.t-falusa.com/medias/?context=bWFzdGVyfHJvb3R8MTUyMTE3M3xhcHBsaWNhdGlvbi9wZGZ8aGZjL2hlZC85NDY0ODMyMzkzMjQ2LnBkZnxhMWU4NWQwODhiZWUwZGI4YmY1ZDE2MzA4YWNmN2E2YTUyMGM0YmFkOGRjZTQzNzIyODBjZTBkMGY2NTZhZTVi .
I hope this helps.
Apr 20, 2017 | Crock Pots & Slow Cookers
Paula deen pressure cooker. Can I use it for slow cooking? What is temp of keep warm? Could put lid on loose. Also, timing notches are mixed into keep warm button. I overcooked my first batch
A pressure cooker is NOT anything close to a slow cooker. The cooking philosophy are practically totally opposites. A pressure cooker basically cooks your food in a fraction of time because it is under pressure. A slow cooker takes hours.
The whole idea of using a pressure cooker is that it is sealed and applies pressure to cook the food faster. The lid needs to be sealed for the pressure cooker to operate properly. It is frequently referred to as "infusion" cooking now days.
You need to read the instruction book that came with the pressure cooker. Pressure cookers usually cook for less than an hour--my homemade pressure cooker spaghetti sauce is cooked in less than 30 minutes. They are nice and were very popular long before anyone thought of microwaves and slow cookers. However, there are some precautions to be taken. There must be water or liquid in a pressure cooker. The rubber seal needs to be cleaned frequently and, when the rubber seal warps/stretches and no longer seals, it needs to be replaced. There are also certain foods that CANNOT be cooked in a pressure cooker like rice, dry beans, etc. The pressure control valve operates to regulate the amount of pressure and releases extra pressure otherwise the unit would blow up (very dangerous!). Most pressure cookers (required on all new ones) have a small rubber emergency stopper that will "blow off" in case the pressure is too high. I've seen this happen and my mother cleaning potatoes & meat from the ceiling!
Mar 03, 2017 | Crock Pots & Slow Cookers
Looking for manual for the Farberware 7 in one programmable pressure cooker
pressure cooker manual & recipe booklet library ' hip ...
www.hippressurecooking.com/pressure-cooker-manual-library/
Free downloadable copies of pressure cooker instruction manuals for stove top pressure cookers, ... Farberware Quick Cuisine Pressure Cooker Recipe Booklet.
FARBERWARE FCP412 USE & CARE INSTRUCTIONS ...
www.manualslib.com > Brands > Farberware Manuals > Coffee Maker
View and Download Farberware FCP412 use & care instructions manual online. ...Salton use & care instruction programmable coffeemaker fcm12ss (12 pages) ... TOLL FREE: 1-888-881-8101, Monday - Friday, 7:30 a.m. - 6 p.m. CST Please ...
Farberware 6-Qt Digital Pressure Cooker - Walmart.com
Jan 01, 2016 | Crock Pots & Slow Cookers
Manual for Mirro pressure cooker Model M- 0536-1
go google and type in -- user manual for mirro pressure cooker model m-0536-1-- and if there is one it will be a pdf version down load
make sure that the lid seal went in without any twists
put something under the seal and go around the lid several time to allow the seal to untwist
Oct 26, 2015 | Crock Pots & Slow Cookers
I need a harvest pro pressure cooker manual
I couldn't find a manual for you but I found the manufacturer's website so that you can contact them for a replacement.
https://www.getpressurepro.com/
BTW, I noticed that the informercial and website says that you can pressure can in that pressure cooker. That is actually not safe to do, there are no USDA-approved pressure canning processing times for electric pressure cookers. Here is a comsumer alert with details:
http://www.hippressurecooking.com/consumer-alert-no-pressure-canning-in-un-tested-multi-cookers/
Sep 08, 2015 | Nesco Crock Pots & Slow Cookers
Why is steam and water coming out of the safety valve of the Russel Hobbs preasure cooker
When a pressure cooker is working normally, some steam and a little water is supposed to come out of the valve, that's how you know it's up to pressure.
Aug 29, 2014 | Crock Pots & Slow Cookers
Pressure cooker manuals
You can find a pretty good collection of pressure cooker manuals here. You didn't mention the manufacturer, so just find them on the list and then click to see all of the pressure cooker manuals available for that pressure cooker:
http://www.hippressurecooking.com/pressure-cooker-manual-library/
Aug 23, 2014 | Crock Pots & Slow Cookers
TONGTEL PRESSURE COOKER
Take a look here for pressure cooker instruction manuals:
Mar 25, 2014 | Nesco 6qt Electric Pressure Cooker Pc6-25...
One of the handles on our S-9898 pressure cooker broke. Where can we get a replacement handle?
Here is a site that has parts for 106 different pressure cookers http://www.appliancefactoryparts.com/pressurecookers/mirro?gclid=CP769LDwl7oCFWfhQgodvyIA4g
However, you will need the model number of the pressure cooker which might be on the bottom of the pan. The number you listed is the pressure regulator, not the pressure cooker.
Oct 15, 2013 | Mirro S-9898 Pressure Cooker Pressure...
Sharper Image The 8149SI Stainless-Steel 5-Quart Pressure Cooker Logo
Top Sharper Image Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Sharper Image Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
