Question about Konica Minolta Office Equipment & Supplies
Bypass tray It gives me an error that correct paper size is not available. The paper is there and the right size. It just keeps beeping at me
    New Friend:
    Problem Solver:
  • 10 Answers
Remove it clear and if dont works set the size manualy
Posted on Apr 21, 2014
jqsababa967
  • 145 Answers
SOURCE: There are no matching paper size. Place paper in first tray.
A4 is n earupean size .change to 8 1/2 by 11 in both the copier and you printer setting..
Posted on Apr 26, 2009
SOURCE: paper mismatch
Hi kingwa55,
I have an hp photosmart c4480 and was having the same problem printing wedding invitations. Same size 5.5"x8.5'. Im not sure if this will work on your printer, but this is what I had to do.
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print, properties,features, click the drop down box under sizing options.
Click more and scroll to the bottom and it should be there.
If your options are different then mine, I'm sorry for wasting your time.
Posted on May 13, 2009
  • 7 Answers
SOURCE: Our Konica Minolta C351 won't pull from any tray but 1
you may have to under configure in your print driver go to acquire settings and that should update the driver so you can use all 4 trays
Posted on Mar 04, 2010
  • 4 Answers
SOURCE: FUJI XEROX DOCUPRINT C1110 WRONG PAPER SIZE MESSAGE
This printer have a sensor to remind the user when using a wrong paper size.
If you still using a paper that not the same with your software settings, it's still reminds you.
I solve this promblem by after print my works I just press "Cancel Jobs" button to clear a data.
Good luck.
Posted on Mar 23, 2010
SOURCE: Hp P4515n - Paper Handling for tray-2 only, gives
I just ran into this same issue with an HP LaserJet P4015n. Worked with HP and the resolution ended up being the following.
Hopefully this will work with the P4515n printer as well.
1. Open EWS page (printer page) in Internet Explorer.
2. Log into printer as administrator
2. Click on Settings tab, Configure device, System Setup
3. You will find Tray Behavior
4. Change tray 2 model to Standard Tray.
This should give you the standard options for the Tray 2 size or default to the size detected.
Posted on Jul 29, 2010
Bypass tray has correct paper size but gives error message to add correct paper size. Won't print
Once you have the message, try removing the paper from the bypass tray, then introducing it again. Alternatively, leave the tray empty then send the data, when it asks for paper, introduce your 11 x 7, and it should work.
Mar 19, 2014 | Konica Minolta Di3510 Copier
When i try printing with my sharp ar-m205, it automatically reselect bypass tray and gives error "check bypass tray: out of paper or missfeed". But the tray i originally selected is tray 1.
Size mismatch between your print request and the size specifed for the paper in the tray. these trays do not auto-read, you have to tell the copier what size is in the tray
Nov 01, 2013 | Sharp AR-M205 Copier
Any time i try to print with my sharp ar-m205, it automatically reselect bypass tray and give error Check bypass tray: out of paper or misfeed. But the original tray i selected is tray 1 and there is paper...
Make absolutely certain the correct size is specified for the paper in your tray, otherwise your print driver may be locked on selecting from the bypass tray and not set to 'auto select'
Manual feed tray bypass
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Jul 25, 2012 | HP LaserJet 4250n Printer
Bizhub c200 giving message put paper in bypass tray
Check your default paper settings in your setup menu. Also, check the paper size is set correctly on you paper trays for the type of paper that is in them. Make sure that the documents that you are printing are set to proper paper size that is in your printer. All the issues, will cause this condition plus some. But those are the easiest, let me know if it continues. Good Luck
Jun 04, 2012 | Minolta bizhub 200 All-In-One Printer
When trying to print, get error message to load paper into bypass tray. All printing preferences have the input tray as tray 1?
if all the other trays are empty
or the bypass is set as default
or the bypass has the correct tray size and no one else has it
then the bypass will be default...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 09, 2009 | Sharp AR-BC260 Color Copier
Hp laserjet 8150. i have a problem, tray 3 empty, always but have paper in tray 3
CAUSE: This error message indicates the paper present sensor flag in one of the trays does not detect paper in the tray. This could be caused by one of the following:
  • A broken sensor flag
  • The tray paper guides being set too close and restricting the paper from being pulled
  • The tray is not lifting
SOLUTION: Follow the steps below to determine the cause of a false TRAY X EMPTY message. Tray 2 empty
  1. Verify there is paper in the tray.
  2. Open the duplex unit access door just above Tray 2 on the front of the printer.
  3. Check the black-paper present flag by looking in through the duplex access door.
  4. Open and close Tray 2 and observe the tray lifting looking through the duplex unit access door.
The tray lifts but the error is still present
  1. Inspect the paper present flag on the PIU located just behind the pickup rollers. Ensure the flags are present and not damaged.
  2. Remove the tray guides from the tray and reseat them. Ensure the guides are seated correctly and are in the correct slot for the size paper in the tray. Add paper to the tray and try printing again.
  3. Try another known good tray, if available.
The tray does not lift and the error is still present
  1. Remove the tray, remove the paper in the tray, and inspect the lifting plate in the tray for damage. Ensure it will lift freely by hand.
  2. Try another known good tray if available.
Tray 3 empty
  2. Remove Tray 2.
  3. Open and close Tray 3 and verify it lifts by observing through the Tray 2 cavity.
  3. Try another known good tray if available.
Tray 4 empty
  2. Open Tray 4 and check for an extra **** of paper stored on the left side of the tray. This can cause the tray to stall while lifting and result in a tray empty message.
  3. Defeat the interlock in the vertical transfer unit (VTU). Open and close Tray 4 and watch the tray lift through the VTU door on the lower-right side of the printer.
    NOTE: Follow troubleshooting steps for Trays 2 and 3 when working with the 2 X 500 sheet-input tray.
  1. Check the tray guides to ensure the guides are seated corrected and are in the correct slots for the paper size in the tray.
  2. Inspect the paper present sensor for damage.
  3. Check for any broken plastic pieces in the tray that may be a broken sensor flag.
The tray does not lift and the error is still present Defeat the VTU interlock on the right side of Tray 4. Open and close Tray 4 and observe the tray lifting.
Nov 25, 2009 | HP LaserJet 8150n Printer
H2 error when printing from pdf to A3 in multipurpose tray
H2 error code means that the paper size you are feeding into the machine does not match the paper size programmed into the machine. Minolta's are picky about these 2 size matching. So if you trying to print onto A3 then when you select the multipurpose tray it must read as A3.
Here is the info from the factory service manual:
H2 The length of the paper set does not
match that of the paper actually taken
up and fed in.
• Load paper of the correct size again
according to the set paper size.
• Turn OFF and ON the Power Switch.
• For copier tray: Slide out and in the
paper tray in which the size error has
occurred.
• For Manual Bypass Tray: Place paper
in the Manual Bypass Tray.
• For Multiple Bypass Tray: Unload
paper from the Multiple Bypass Tray,
then reload it back again.
Nov 23, 2009 | Minolta Di152 Laser Printer
Will not print with giving an error message
on left side of tray are 3 fingers, for letter size paper bottom 2 are out, next one in. verify slider on bottom of tray is in place. Essentially paper not sensed correctly. print config page and see paper size
Jul 03, 2008 | Lexmark T640 Laser Printer
52 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
