Question about Garden
Does not spray fluid
The air comes thro but no paint
  • 20 Answers
Still clogged or you need to wd40 to clean all pieces. make sure the diaphragm is clean also .....check the mixing thickness instruction
Posted on Apr 16, 2014
    Scholar:
  • 136 Answers
It is always a good idea to prime the line until you see paint coming out effortlessly. If that is not the case the tip or line is possibly clogged.
Posted on Apr 21, 2014
Getting sprayer to spray something other than air
Is the tube connected to the nozzle going into the paint or fluid?
Aug 23, 2017 | Air Tools & Compressors
Will not suck the paint just air is coming out
Hello I just saw this in my inbox, let me see if I can help you-
NOTE: Whenever you are going to spray with any HVLP or cup-gun
strain paint through either a strainer bag or an Automotive strainer cone to remove any kind of debris from the paint that can clog the delivery tube that sucks the paint up from the "cup" and into the fluid needle.
yes even though "Wagner" says the Flexio will spray un-thinned Latex-
However by thinning your paint 10% to 15% you will get better coverage and the paint will move through the gun better
If you have no paint coming out try adjusting the fluid material knob on top-
Also try holding a piece of card in front of the the Tip and try all your Adjustments and you should start seeing the paint spraying onto the piece of cardboard or wall.
Thanks,
Perry Tradesman @ Tradesman Painting & Decorating
Feb 15, 2015 | Wagner SprayTech Paint Sprayer. Flexio 590...
Trying to prime my 395 air assisted finish pro and I have fluid coming out of air holes in gun
I had the same problem. turned out I was using the rubber gasket on the tip saddle instead of the hard plastic one.
Aug 30, 2013 | GRACO INC FinishPro 395 Air-Assisted...
In trying to spray oil base paint, I get very low fluid flow (if any) from the cup to the gun. I've cleaned the gun and insured the hoses weren't clogged. Changing the adjustment valves...
How does it spray if you dump the paint out and put paint thinner in the cup? If it sprays paint thinnner, but not the paint, your paint is too thick. Thin it down by 25% and try a little. Keep adding thinner until the paint sprays out of the gun in an acceptable manner. Your gun probably has a 1.1,or 1.4 fluid tip. this is for spraying lacquers or automotive paints that are very thin. to spray oil based paint, your would need a 2.0 or 2.5 or bigger. not really what this gun was made to spray.
Jul 20, 2011 | Binks Hvlp Spray Gravity Gun With 1 Liter...
I am using DeVILBISS JGA_510 cinventional spray gun. The pressure pot system is showing constant pressure , but the gun is sputtering and not getting an even paint flow. I have changed paint lines, put on...
First start with the basics, whats the paint VISCOCITY ON A FORD 4 CUP ??
Or Does it run nicely off the stick you stirred it with??
If its thin enough to go up the tube and lines, whats the fluid tip and air cap combo your using?? maybe start with a EX fluid tip (1.8mm) and 30b air cap (cos that sprays everything!!) and reduce from there.
Whats the pot pressure?? Is it a KBII pot? cos they suffered with the air inlet blocking, so IT SHOWS GOOD PRESSURE, but doesnt have it in the pot!
Does it spray anything?? thinners?
Mar 07, 2011 | Air Tools & Compressors
How to used the gravity type
Depends on what you want to do with a spray gun realy.
Gravity is good for easy flowing paints which can be used on things which dont require the gun angle to change much.
SOLVENT BASED PAINTS:
Thin your paint to a bit thicker than milk, fully open the fluid needle travel and without air pull the trigger and see if the paint kind of falls gracefully out of the front, if it just dribbles and rund all over the gun, its either TOO THICK or the fluid tip IS TOO SMALL.
If that works OK try introducing some air gradually and spraying test patterns, even atomisation, (regular paint particles) and a pattern of about 1.5 inches by 6 - 9 inches with every thing set to full on should look like a cigar, if its all one ended your air cap hasa blocked hole, no paint in the middle too much air.
Good luck
Jan 28, 2011 | Air Tools & Compressors
My paint gun is pulsating instead of spraying evenly
It looks like you have a Devilbiss SRI.
Probaby the hole in the lid is blocked, The gun sprays, paint gets sucked out, no air can get back in through the little hole in the lid to replace so it stops spraying, pressures even up it sprays abit more, and so on.
Either that or you have a damaged fluid tip.
regards
Sep 18, 2010 | HVLP New PROFESSIONAL AUTOMOTIVE AIR...
Bought anCampbell Hausfeld airless paint sprayer,
no fluid gets to nozzle or comes from nozzle.
sounds like your fluid line is pluged or the gun is pluged at or before the tip
Dec 28, 2009 | Air Tools & Compressors
Problem spray painting water based paint
I spoke to a friend who was a spraypainter in his last job, apparently due to the thickness of the paint, I needed a larger nozzle on the gun. I couldnt get a nozzle to suit this gun so I purchased another gun with a cuple of different size nozzles. All seems to be working fine now.
Nov 19, 2008 | Air Tools & Compressors
Thiner how to
Paint to thinner ratio is 60:40, that is 60% paint and 40% thinner. Sometimes it can be 50:50 depending on different occasion. Remember to MIX IT WELL.
Aug 27, 2008 | Viking Spray Gun: Hvlp Siphon Feed Spray...
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
