Question about Alpine 97 98 99 00 01 02 03 Infiniti Qx4 Cd Changer
I cant find my ground wire for my driver side brake light
When i turn my headlights on my left brake light stops working
  • 356 Answers
Replace the bulb,it is a dual element bulb and is both the running light and brake light.
Posted on Mar 19, 2014
Brake light and license plate lights won't work
All lights rely on a good connection between the globe base and the metal body of the car.
This is the cause of your problem.
You'll probably find rust in the globe holder stopping the globe from making a good connection.
You may have to replace the globe holders, but it will be worth trying to clean the rust back to bright steel.
May 02, 2014 | Cars & Trucks
Taillight works when headlights are on, but does not shine brighter when braking or signaling
Change the bulb. When you press the pedal the brake switch changes the circuit to the 21w brighter circuit for the brake light.
Jan 02, 2018 | 2001 Ford F150 Styleside SuperCrew
Turn signal and brake light not working.
Change the bulb.The bulb has two lights.Running,and brake light turn signal.Its the bulb
Apr 14, 2013 | 2004 Chevrolet Silverado 1500
I have a 2000 Dodge Durango and I keep blowing the fuse for instrument lights and tailights
hello same pronlem with my 98 durango but right turn signal!
what it was is the 4 pin connector for the tow package had the insulationripped off them i guess whe backing out of a steep driveway it sxrapped! so the headlights, turn signals, and brake circuits where grounding out! quick fix!
just cut and capped that mess!
good luck
Mar 02, 2013 | 2000 Dodge Durango
When i turn on headlights my left brake light goes off. when i turn off headlights left brake lights work fine.
It could be a electrical short orbad ground. Also check the electrical connections for corrosions
Oct 26, 2012 | 1999 Mazda 626
Rear hazard flashers don't work 1994 Chevrolet Cavalier
Hazard flasher power comes from the 20A S/LP fuse in the fuse block. It is applied to the hazard flasher in the convenience center. Flasher output is applied to the turn/hazard/headlight SWITCH assembly where activation of the HAZARD switch causes flashing power to be applied to the turn indicators and the turn filaments of the front and rear dual park/turn lights. If replacing the fuse doesn't work, trace the power through the circuit. Check for misssing/disconnected ground wires.
Sep 16, 2012 | Chevrolet Vehicle Parts & Accessories
My 99 Jeep grand Cherokee Laredo 4x4 has some brake light problems. The brake lights work fine during the day, but when I need to have my headlights on, my left brake light and tail light competley shut...
If you have any extra fuses, try replacing the ones for the head lights and tail lights. Make sure the fuses you replace are the same color as the ones you replace them with, that way the voltages are the same. Another issue is that a flasher could be going out.
May 01, 2012 | 1999 Jeep Grand Cherokee
Rear lights wont turn on when headlights are on, rear door and window wont open
1st u have to take off the rear stop light & clean the jackfish after put it back 7 FOR TH E INSIDE LIGHT press the light before u open the door & contact me on eliezein@hotmail.com coz i have the same jeep & it was the same problem
Oct 24, 2008 | 2000 Jeep Grand Cherokee
Alpine 97 98 99 00 01 02 03 Infiniti Qx4 Cd Changer Logo
47 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
