Question about Garden
Twm engines needing gasket ring for water pump section
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
What is your model #
Posted on Jun 11, 2014
Replace water pump 1995 aurora
Water Pump REMOVAL & INSTALLATION 3.5L Engine
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Partially drain the cooling system.
  3. Remove or disconnect the following:
    • Water pump pulley bolts, loosen but do not remove at this time
    • Drive belt
    • Idler pulley
    • Water pump pulley
    NOTE: The water pump is attached to the engine with both long and short bolts, be sure to note their locations.
    • Water pump and discard the gasket
    NOTE: Note the locations of the 5 long bolts.
  4. Clean the water pump mounting surface. Fig. 1: Be sure to install the 5 long water pump bolts in the correct locations - 3.5L engine 9300z502.gif
    Fig. 2: Water pump mounting - 3.5L engine 9300z503.gif
    To install: NOTE: Be sure to install the 5 long bolts in the proper locations.
  5. Install or connect the following:
    • Water pump using a new gasket. Torque the bolts to 124 inch lbs. (14 Nm).
    • Water pump pulley
    • Idler pulley. Torque the bolt to 37 ft. lbs. (50 Nm).
    • Drive belt
  6. Refill the cooling system.
  7. Start the engine and check for leaks.
3.8L Engines
  2. Disconnect the negative battery cable.
  3. Drain the cooling system.
  4. Remove or disconnect the following:
    • Serpentine belt
    • Heater and bypass hoses from the water pump
    • Water pump pulley
    NOTE: The long bolt can be removed by aligning the bolt head with the frame rail hole.
  5. Install an engine support fixture.
  6. Remove or disconnect the following:
    • Torque axis mount
    To install: Fig. 3: Exploded view of the water pump and mounting bolt locations - 3.8L engines 7922xg01.gif
  7. Thoroughly clean all the sealing surfaces.
  8. Apply a thin bead of sealer around the outside edge of the water pump
  9. Install or connect the following:
    • New gasket
    • Water pump. Torque the inlet and outlet side bolts to 29 ft. lbs. (39 Nm) and the remaining bolts to 97 inch lbs. (11 Nm).
    • Torque axis mount
  10. Remove the support fixture.
  11. Install or connect the following:
    • Water pump pulley
    • Water pump hoses
    • Serpentine belt
    • Water pump pulley bolts. Torque the bolts to 115 inch lbs. (13 Nm).
    • Negative battery cable
  12. Refill the cooling system.
  13. Start the vehicle and check for proper operation.
4.0L Engine
    • Air inlet duct
    • Water pump drive belt cover
    • Lower radiator hose and bypass hose
    • Thermostat housing from the water pump housing
    • Water pump from the water pump housing, by turning the locking ring with a Water Pump Remover/Installer tool J-38816
    To install: Fig. 4: Exploded view of the water pump housing and water pump - 4.0L engine 7922xg02.gif
    • Water pump, seat the locking ring
    • Thermostat housing to the water pump housing
    • Lower radiator hose and coolant bypass hose
    • Drive belt and drive belt cover
    • Air inlet duct
  6. Refill and bleed the cooling system.
Jan 24, 2011 | 1995 Oldsmobile Aurora
Change water pump 1995 Honda accord/ V6
Please don't forget to rate! Thanks!
Removal & Installation
  1. Note the radio security code and station presets.
  3. Drain the coolant from the radiator, into a suitable container.
  4. Remove the timing belt. Refer to the Timing Belt replacement in this section for specific details.
  5. On Odyssey models with the V6 engine, remove the timing belt tensioner. Refer to the Timing Belt replacement in this section for specific details.
  6. Remove the bolts that attach the pump to the cylinder block.
  7. If available, locate the two 6.0 mm x 1.0 mm threaded holes opposite from one another on the outer perimeter of the water pump.
    • Install by hand, two 6.0mm x 1.0mm bolts at least 1 in. (25mm) long, until resistance is felt.
    • Simultaneously turn each bolt one turn at a time until the water pump can be released from the engine block.
  8. Remove the water pump.
Exploded view of the water pump mounting-be sure to replace the O-ring during assembly
If available, use the two 6.0 mm x 1.0 mm threaded holes on the water pump to release the pump from the engine block
Make sure the water pump O-ring is fully seated in the water pump. Using a non hardening gasket sealant will help to hold the seal in place during assembly
To install:
  1. Inspect and clean the O-ring mating surface on cylinder block.
  2. Install a new O-ring on the water pump. Apply a non-hardening gasket sealant between the water pump O-ring and the pump to hold the O-ring in place during assembly.
  3. Install the water pump onto the cylinder block and tighten the bolts to 106 inch lbs. (12 Nm).
  4. On Odyssey models with the V6 engine, install the automatic timing belt tensioner, with the tensioner fully retracted using the special tool 14540-P8A-A01 or equivalent. Refer to the Timing Belt replacement in this section for specific details.
  5. Install the timing belt.
  6. On 4-cylinder Odyssey models, open the cooling system bleed bolt located on the thermostat housing.
  7. Set the heater to the full hot position.
  8. Refill the radiator with a coolant mixture containing 50% antifreeze. Use only antifreeze formulated to prevent the corrosion of aluminum parts. Fill the radiator with the coolant solution.
  9. On 4-cylinder Odyssey models, fill with coolant until the bleed bolt is free of air bubbles. Then, tighten the bleed bolt to 88 inch lbs. (10 Nm).
  10. Install the radiator cap loosely.
  11. Reconnect the negative battery cable.
  12. Run the engine until the cooling fans cycle two times.
  13. Turn the engine OFF and top off the cooling system as necessary.
  14. Install the radiator cap and check for coolant leaks. Be sure the cooling fan turns on.
  15. Recheck the coolant level and add more if necessary.
  16. Enter the radio security code.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 24; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
Dec 09, 2010 | 1999 Honda Odyssey
How to replace the water pump
Water Pump
CAUTION
Never open, service or drain the radiator or
cooling system when hot; serious burns can occur from the steam and hot coolant.
Also, when draining engine coolant, keep in mind that cats and dogs are
attracted to ethylene glycol antifreeze and could drink any that is left in an
uncovered container or in puddles on the ground. This will prove fatal in
sufficient quantities. Always drain coolant into a sealable container. Coolant
should be reused unless it is contaminated or is several years old.
2S-ELC Engines
  1. Drain the cooling system.
  2. Remove the timing belt as described in this section.
  3. Remove the alternator adjusting bar.
  4. Disconnect the lower radiator hose from the water inlet housing.
    Fig. 1: Exploded view of the water pump mounting
  5. Disconnect the water temperature switch from the water inlet housing.
  6. Disconnect the water by-pass hose from the water pump.
  7. Remove the two heater pipe clamp bolt. Remove the two nuts and heater pipe
    with gasket. Replace the gasket.
  8. Loosen the three water pump mounting bolts in the indicated sequence.
    Fig. 2: Water pump bolt loosening sequence for 2S-ELC and 3S-FE
    engines
  9. Remove the water pump and O-ring. If the water pump is stubborn, tap it a
    few times with a rubber mallet.
  10. Installation is the reverse of removal. Make sure all the water pump and
    engine contact surfaces are clean and install the new O-ring into the pump cover
    groove.
  11. Install the water pump with the three bolts. Tighten the bolts in sequence
    to 82 inch lbs. (9 Nm).
  12. Fill the cooling system to the proper level with a good brand of ethylene
    glycol based coolant. Start the engine and inspect for leaks.
3S-FE Engines
  2. Disconnect the water temperature switch connector from the water inlet
    housing.
  3. Disconnect the lower radiator hose from the water inlet housing.
  4. Remove the timing belt and timing belt pulleys as described in this section.
  5. Remove the two nuts attaching the water by-pass pipe to the water pump
    cover.
  6. Remove the three water pump-to-engine attaching bolts.
  7. Pull the water pump and the water pump cover out from the engine.
  8. Remove the two O-rings and gasket. Discard them and replace with new.
  9. Installation is the reverse of removal. Secure the water pump onto the
    engine and install the three bolts. Tighten the bolts in an alternate pattern to
    82 inch lbs. (9 Nm). Install the by-pass pipe attaching nuts and tighten them to
    82 inch lbs. (9 Nm) also.
  10. Fill the cooling system to the proper level with coolant.
  11. Start the engine and check for leaks.
5S-FE Engine
  1. Drain the engine coolant.
  2. Remove the timing belt.
  3. Remove the No. 1 idler pulley and tension spring. Remove the No. 2 idler
    pulley.
  4. Disconnect the lower radiator hose at the water inlet.
  5. Remove the alternator belt adjusting bar.
  6. Loosen the two nuts and disconnect the water by-pass pipe.
  7. Remove the three pump mounting bolts in sequence (middle, top, bottom) and
    then pull out the water pump and cover. Remove the gasket and two O-rings.
    Fig. 3: Bolt removal sequence for 5S-FE engines
    To install:
  8. Replace the two O-rings and gasket with new ones, coat the by-pass O-ring
    with soapy water and then connect the pump cover to the by-pass pipe. Do not
    install the nuts yet!
  9. With the pump loosely connected to the pipe, install the pump and tighten
    the three bolts to 82 inch lbs. (9 Nm), in sequence (top, bottom, middle).
    Install the two by-pass pipe nuts and tighten them to 78 inch lbs. (9 Nm).
  10. The remainder of installation is the reverse of removal. Tighten each
    component to specifications.
2VZ-FE and 3VZ-FE Engines
  2. Disconnect the lower radiator hose at the water inlet.
  3. Disconnect the timing belt from the water pump pulley.
  4. Remove the bolt holding the inlet pipe to the alternator belt adjusting bar
    and then remove the inlet pipe and O-ring.
  5. Remove the water inlet and thermostat.
  6. Remove the seven bolts and then pry off the water pump.
    To install:
  7. Scrape any remaining gasket material off the pump mating surface. Apply a
    0.08-0.12 inch (2-3mm) bead of sealant to the groove in the pump and then
    install the pump. Tighten the bolts to 14 ft. lbs. (20 Nm).
    Fig. 4: Apply sealant on the surface of the water pump as shown
  8. The remainder of installation is the reverse of removal. Tighten each
    component to specifications. Connect the radiator hose and fill the engine with
    coolant.
1MZ-FE Engine
  3. Mark the left and right camshaft pulleys with a touch of paint. Using a
    spanner wrench, remove the bolts to the right and left camshaft pulleys.
    Separate the pulleys from the engine. Be sure not to mix up the pulleys.
  4. Remove the No. 2 idler pulley by removing the bolt.
  5. Disconnect the three clamps and engine wire from the rear timing belt cover.
  6. Remove the six bolts holding the No. 3 timing belt cover to the engine
    block.
    Fig. 5: Unbolt the No. 3 timing belt cover from the engine
  7. Remove the bolts and nuts to the extract the water pump.
    Fig. 6: Water pump mounting bolt and nut locations
  8. Raise the engine slightly and remove the water pump and the gasket from the
    engine.
    Fig. 7: Pull the water pump from the engine and remove it from
    the vehicle
    Fig. 8: Always discard the old gasket
    To install:
  9. Check that the water pump turns smoothly. Also check the air hole for
    coolant leakage.
  10. Using a new gasket, apply liquid sealer to the gasket, water pump and engine
    block.
  11. Install the gasket and pump to the engine and install the four bolts and two
    nuts. Tighten the nuts and bolts to 53 inch lbs. (6 Nm).
  12. The remainder of installation is the reverse of removal. Tighten each
    • Rear timing belt cover - 74 inch lbs. (9 Nm).
    • No. 2 idler pulley - 32 ft. lbs. (43 Nm)
  13. Fill the engine coolant. Connect the negative battery cable to the battery
    and start the engine.
  14. Top off the engine coolant and check for leaks.
Oct 31, 2010 | 1990 Toyota Camry
Just need to know were the water pump on montero sport 1998 3.0 Ls engine????
It's under the timing cover on the front of the engine. I have pasted autozone.com instructions to replace the water pump below.
3.0L & 3.5L Engines
  1. Before servicing the vehicle, refer to the Precautions section.
  2. If necessary, properly release the fuel pressure.
CAUTION Wait at least 90 seconds after the negative battery cable is disconnected to prevent possible deployment of the air bag.
Upper radiator shroud Accessory belts Air conditioning compressor tensioner pulley, if equipped Cooling fan and clutch assembly and the water pump pulley Thermostat and housing on 3.0L, 3.5L engines Water outlet, gasket and houses Radiator hoses from the water pump Crankshaft pulley(s) Timing belt covers. If the same timing belt will be reused, mark the direction of the timing belt's rotation, for installation in the same direction. Be sure the engine is positioned so the No. 1 cylinder is at the TDC of its compression stroke and the sprockets timing marks are aligned with the engine's timing mark indicators. Timing belt Water pump bolts are different lengths, note their positions before removing. Water pump from the block Water pipe connection and O-ring
To install:
  1. Clean and dry the mating surfaces of the block and water pump
  2. Install or connect the following:
    New O-ring on the water pipe connection, wet the new O-ring with water to aid in installation Water pump, with a new gasket, Torque the bolts to 17 ft. lbs. (23 Nm) on 3.0L and 3.5L engines Alternator bracket bolt to 17 ft. lbs. (23 Nm) Timing belt(s) and covers Crankshaft pulley(s) Thermostat and housing on 3.0L, 3.5L engines. Torque the bolts to 12-14 ft. lbs. (17-20 Nm). Radiator hose to the water pump Water outlet, new gasket and houses. Torque the bolts to 12-14 ft. lbs. (17-20 Nm). Water pump pulley Cooling fan and clutch assembly Air conditioning compressor tensioner pulley, if equipped Accessory belts Upper radiator shroud Thermostat and housing on 3.0L, 3.5L engines Negative battery cable
  3. Refill the radiator with coolant. This cooling system has a self-bleeding thermostat, so system bleeding is not required.
  4. Run the vehicle until the thermostat opens and fill the overflow tank. Check for leaks.
  5. Once the vehicle has cooled, recheck the coolant level.
Oct 26, 2010 | 1998 Mitsubishi Montero Sport
When turning pump on sand shoots into pool app. two seconds.replaced diverter and lateral coponents. still does the same thing. twm 19 inch p/n 520-1910
If you don't have a manual you can download one here:
http://www.waterwayplastics.com/manuals/810-0092H.0209.pdf
Are you sure you didn't damage laterals when adding sand. Best to have 1/4 water in filter as you add sand. Be sure o ring is in place in multiport valve that fits on downtube.Be sure down pipe is not too low to enter multiport valve. The pipe should fit snugly into the multiport valve o ring. Be sure you have correct sand (pool filter sand only) IF all this is ok, try backwashing till glass is clear. Run on rinse position for a few min. THen go back to filter and see if it still pumps in sand.
Aug 16, 2010 | Waterway Twm Above Ground Pool Pump and...
I need to replace the water pump on a 1990 2.5 dodge caravan.
WATER PUMP - 3.3/3.8L ENGINE
REMOVAL
Drain Cooling System. Refer to procedure in this section.
Remove accessory drive belt. Refer to procedure in this section.
Remove right front lower fender shield.
Remove water pump pulley bolts and remove pulley.
Remove water pump mounting screws Water Pump - 3.3/3.8L Engine Remove water pump.
Remove and discard O-ring seal.
Clean O-ring groove and O-ring surfaces on pump and chain case cover. Take care not to scratch or gouge sealing surface.
INSTALLATION
Install new O-ring into groove Water Pump Body
Install water pump to chain case cover. Tighten screws to 12 N·m (105 in. lbs.)
Rotate pump by hand to check for freedom of movement.
Position pulley on pump. Install screws and tighten to 30 N·m (250 in. lbs.)
Install accessory drive belt. Refer to procedure in this section.
Install right front lower fender shield.
Refill Cooling System. Refer to procedure in this section.
Aug 14, 2010 | 1990 Dodge Caravan
I need to know the procedure to replace a water pump on a 2002 Mitsubishi Galant. Thanks
Fig. Water pump and related components-3.0L DOHC shown (click for zoom).
  1. Disconnect the negative battery cable.
  2. Drain the cooling system.
CAUTION Never open, service or drain the radiator or cooling system when hot; serious burns can occur from the steam and hot coolant. Also, when draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantities. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
  1. Remove the engine undercover.
  2. Disconnect the clamp bolt from the power steering hose.
  3. Support the engine with the appropriate equipment and remove the engine mount bracket.
  4. Remove the timing belt. Refer to the timing belt procedure in this section.
  5. Disconnect the coolant hoses from the pump, if equipped.
  6. Remove the alternator brace.
NOTE The water pump bolts are different in size. Note their locations for installation.
  1. Remove the water pump, gasket and O-ring where the water inlet pipe joins the pump.
To install:
  1. Thoroughly clean both gasket surfaces of the water pump and block.
  2. Install a new O-ring into the groove on the front end of the water inlet pipe. Do not apply oils or grease to the O-ring. Wet with water only.
  3. Using a new gasket, install the water pump assembly to the engine block. Torque the mounting bolts to 17 ft. lbs. (24 Nm).
  4. Connect the hoses to the pump.
  5. Install the timing belt. Refer to the timing belt procedure in this section.
  6. Install the engine drive belts.
  7. Fill the system with coolant.
  8. Connect the negative battery cable, run the vehicle until the thermostat opens and fill the radiator completely.
  9. Once the vehicle has cooled, recheck the coolant level.
Hope helps (remember rated this).
Aug 10, 2010 | Mitsubishi Galant Cars & Trucks
I need to know how to replace a water pump on a 2002 hyundai gx 350.
2002 Hyundai XG350 3.5L MFI DOHC 6cylWater Pump - Removal & Installation
    Negative battery cable Accessory drive belts Water pump pulley Timing belt, tensioner and idler pulley Water pump
    Fig. Water pump assembly-XG 300 and XG 350 (click over pic for zoom)
To install:
  1. Clean all mating surfaces of any residual gasket material.
    Water pump with a new gasket and torque the bolts to 16 ft. lbs. (22 Nm) Tensioner and timing belt and idler pulley Water pump pulley and drive belts Negative battery cable
  3. Fill the cooling system to the proper level.
  4. Start the vehicle, check for leaks and repair if necessary.
To install:
Fig. Water pump bolt lengths-3.5L engine
Install the water pump with new gaskets and O-rings. Tighten the bolts to the following specifications:
  1. 1.5L SOHC engine: 105-132 inch lbs. (12-15 Nm).
  2. 1.5L DOHC engine: 14-20 ft. lbs. (20-27 Nm).
  3. 1.6L DOHC engine: 14-20 ft. lbs. (20-27 Nm).
  4. 1.8L, 2.0L, and 2.4L engines: 14-20 ft. lbs. (20-27 Nm).
  5. 2.5L engine: 11-16 ft. lbs. (15-22 Nm).
Jun 18, 2010 | 2002 Hyundai XG350
Need to change the water pump.
Mitsubishi Galant/Mirage/Diamante 1990-2000
Water Pump - REMOVAL & INSTALLATION
1.5L and 1.8L Engine
Fig. Water pump and related components-Mirage with 1.5L (4G15) engine
Fig. Water pump and related components-Mirage with 1.8L (4G93) engines
  3. Remove the engine drive belts.
  4. Support the engine with the appropriate equipment and remove the engine mount bracket.
  5. Remove the timing belt. Refer to the timing belt procedure in this section.
  6. Remove the power steering pump bracket.
  7. Remove the alternator brace.
NOTE The water pump mounting bolts are different in length, note their positioning for reassembly.
  1. Remove the water pump, gasket and O-ring where the water inlet pipe(s) joins the pump.
To install:
  2. For 1.5L engines, install a new O-ring into the groove on the front end of the water inlet pipe. Do not apply oils or grease to the O-ring. Wet the O-ring with water only.
  3. For 1.8L engines, apply a 0.09-0.12 in. (2.5-3.0mm) continuous bead of sealant to water pump and install the pump assembly. Install the water pump within 15 minutes of the application of the sealant. Wait 1 hour after installation of the water pump to refill the cooling system or start the engine.
  4. Install the gasket and pump assembly and tighten the bolts to 17 ft. lbs. (24 Nm). Use care when aligning the water pump with the water inlet pipe.
  5. Install the remaining components in the reverse order of removal.
  6. Fill the system with coolant.
  7. Connect the negative battery cable, run the vehicle until the thermostat opens and fill the radiator completely.
  8. Once the vehicle has cooled, recheck the coolant level.
1.6L and 2.0L (SOHC and DOHC) Engines
Fig. Water pump mounting-2.0L DOHC engine shown
  2. Drain the engine coolant.
  1. Remove the timing belt. Refer to the timing belt procedure in this section.
  2. If necessary, remove the alternator brace from the water pump.
  3. If necessary, remove the timing belt rear cover.
  4. Remove the water pump mounting bolts.
  5. Remove the water pump, gasket and O-ring.
To install:
  1. Install a new O-ring on the water inlet pipe. Coat the O-ring with water or coolant. Do not allow oil or other grease to contact the O-ring.
  2. Use a new gasket and install the water pump to the engine block. Torque the mounting bolts to 8.7-11 ft. lbs. (12-15 Nm). Install the alternator brace on the water pump. Torque the brace pivot bolt to 17 ft. lbs. (24 Nm).
  3. If removed, install the timing belt rear cover.
  4. Install the timing belt. Refer to the timing belt procedure in this section.
  5. Install the remaining components.
  6. Refill the engine with coolant.
  7. Connect the negative battery cable, start the engine and check for leaks.
I really hope this help (remember rated this help).
Mar 26, 2010 | Mitsubishi Diamante Cars & Trucks
I have a 1999 Ford SHO that needs a new waterpump. I need to know how to replace it and where I can get a schematic of it. Do I need a special tool kit to do it? I'd also like to know where I can get the...
www.autozone.com
They can get all the parts. They also provide haynes repair manuals, any special tools (probably not required for this vehicle) and any special disassembly instructions.
I hope this helps.
Mar 11, 2010 | 2001 Ford Taurus
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
