Hoover oph714d Hi- washer stopped in mid-programme. Now has no sign of life at all - no display. Have checked that the main switch on the front supplies the main board. Any ideas?
  • 42 Answers
Hi! If it won't drain out then check the drain hose. Maybe it's blocked or kinked. Then check the pump impeller, there may be blocking impeller. Anyway, here are washing machine manuals where you may find solution of your problem Washing machine service manual repair scheme download pdf free
Posted on Mar 19, 2014
  • 1003 Answers
SOURCE: Hoover washer Time 1600 H160E UK stops mid cycle with flashing lights
REPLACE TIMER OR POWER CONTROL BOARD
Posted on Feb 02, 2008
Mykel_N
  • 315 Answers
SOURCE: front loader wm2277hs washer with OE error sign
The LG error code OE simply means “the pump is blocked”.
Presumably the water isn’t being emptied properly.
As with all error codes it is possible that there is a cause other than the exact description in the error code explanation.
And from your original post, I see that you have checked the drain pipe and the pump filter..
Those are the only 2 things I would of asked you to check aswell.
As for the price, I cannot answer that as most manufacturers wont publish their prices unfortunatly.
Sorry I couldnt of offered more help.
Mike
Posted on Jun 10, 2009
localwonder
  • 6784 Answers
SOURCE: LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Posted on Jun 21, 2009
BIKER T
  • 909 Answers
SOURCE: Hoover oph714d - error code e16. What does it mean
Where in the program is this happening?
Posted on Sep 20, 2009
SOURCE: hoover optima oph714ds error code
hoover optima oph 7d14 working ok but at end of wash cycle error e14 comes up what does this mean
Posted on Jan 28, 2011
Affinity stops in the middle of a cycle a just shuts off no signal or anything?
use the following steps. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
May 23, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer heavy duty cycle issue
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
God bless youcb4af627-0171-42f5-ad0a-5f8e85e72ae0.gif6634bf88-8eca-4d0f-b59c-0e8829e5d59d.gif419f93c3-fea0-4d93-af85-2e59d98d88e0.gif
May 23, 2013 | Whirlpool AWG320 Front Load Washer / Dryer
My maytag epicz will run water and then just stop it lock and later get code f33
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Oct 05, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Does not spin out clothes, keeps running in water as long as spin is enabled and does not follow cycle selected.
Sep 30, 2012 | Haier XQG50-QF802 Front Load Washer
Whirlpool 1000 w100 stops after filling with water
Sep 30, 2012 | Creda W100FW Front Load Washer
Hoover six 1100 stops at certain points during the cycle until i turn the dial to skip to next part of cycle?
Sep 25, 2012 | Washing Machines
Hoover ultracare 1300 large load stopping mid cycle at a variety of different points and having to be manually stopped and started again at another point to complete the wash
Checkout your filter at the bottom of the machine, undo the bottom flap below the door, front. Plug off the wall mains socket. Be prepared for a lot of water so keep plastic bag, towels ready. Unscrew the plug you see to make water flow into bag; when all water has been disposed off, clean this filter & inside, refit carefully.
Feb 13, 2010 | Hoover UltraCare HC6 130M Front Load...
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Maching stopped mid cycle & now has no power, it will not turn on, all fuses are ok
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 02, 2010 | Hoover Washing Machines
Maytag Neptune - died with clothes inside and door locked
hi there,
sounds like you may have had a power outage or tripped the breaker on the main electrical panel on your house. can you have a look for me please?
if not it's the main control board that is defective.
can you tell me the full model # & serial # (these will be located on your bill of sale, since you can't open the door).
i will check the warranty info and let you know if the board has warranty.
thanks.
Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
