Question about Buffalo Technology Computers & Internet
Buffalo hard drive connection cable has been jammed in and now wont fit
I've accidentally tried to plug in the chord totthe hard drive and now the chord wont fit into the hard drive
    Master:
  • 397 Answers
I would replace the outer shell or caddie the drive uses. It sounds like you have damaged the USB connection on it.
Posted on Mar 19, 2014
SOURCE: simpletech 500 gb external hard drive
There is a power consumption work-around untill a Y usb wire can be purchased; the main power cable must still be used at all times but this workaround should only remain temporary!!!
Simpletech should have included this so laptop users could use the drive as their capacity is better than the packaged slimmer simpletech portable backup drives for laptops, which does include the Y cable....
1) unplug usb while powered and unknown hardware is present on laptop...
2) turn power switch off from the external HDD...
3) return power switch to on from the external HDD...
4) plug in usb connection to laptop...
Autoplay should read from external HDD!!!
**** Save some $$$ and buy a Y shaped cable to provide sufficient amount of power from laptop usb
ports, cause it's necessary to use 2 of your ports to provide power in addition to the main power from HDD to wall****
ADONIS
Posted on Sep 06, 2008
Crankstart
  • 696 Answers
SOURCE: No access at all but power light is on
Using the work PC did you see the information bubble informing you that windows found new hardware?
If so, the problem is likely just a logical issue(damage to the information on the drive), if not then the buffalo enclosure may have failed.
Either way, please reply back with this information and I will be happy to give you the appropriate next steps.
Chris
Posted on May 26, 2009
  • 597 Answers
SOURCE: wont turn on when connected to my pc
Try plugging it into a different USB port.
Posted on Jun 01, 2009
  • 142 Answers
SOURCE: problem with WD 1.5TB external hard drive
This appears to be a common occurrence with the My Book. It may be a heat dissipation problem from leaving the unit on for longer than it takes to back up your data.
I think you might need technical support from Western Digital. Do you have an alternate backup?
Posted on Mar 21, 2010
  • 128 Answers
SOURCE: My buffalo portable drive 250g is not working!
it bcause of virues try it in another pc or laptop
Posted on Jun 02, 2010
My buffalo ministation 3.0 external hard drive wont be recognised by my comuter. to be honest i dropped it, but when i plug it into computer green light starts flashing, after a while fashing stops green...
My ministation was doing the same, beeping and flashing green light after a light drop on the floor. Soo... I took my ministation usb drive out of the plastic enclosure and smacked it on the table a few times. Plugged it in and it spun back up!! Now my computer recognizes it and everythings working smooth! I assume something with the drive became jammed and the couple smacks loosened the drive head.. Anyway, if all else fails... beat it!
Nov 05, 2012 | Buffalo Technology Buffalo MiniStation...
Buffalo ministation not auto-playing or showing in my computer
i have exactly the same problem with HD-PCU2 500gb ministation (Buffalo). i have also gone through the solution given by John Adams. i cannot find the device in disk management, therefore i cannot format the device...is it going to work again..please help
Sep 03, 2012 | Buffalo Technology Buffalo MiniStation...
Popular issues: problem with Buffalo Technology (HD-CE500IU2) 500 GB USB 2.0 Hard Drive My laptop is no longer recognizing the Buffalo External Hard Drive. When I plug in the USB to my laptop,
HI guys, I found a solution to a similar problem with the buffalo portable HDD that I brought from my friend. I just changed the HDD cable with the cable from Western Digital My Passport HDD and all problems were sorted out. Physically the WD cable is bit thicker than the Buffalo HDD cable. So suspect the cable is the problem. Please check if this is the problem with your Buffalo HDD before formatting. All the best
Indrajit Pande
Dec 27, 2011 | Computers & Internet
I accidentally kicked my 1tb buffalo external hard disk and it fell the usb connection has been remove and when i connect it again the hard disk start to beep and the computer doesnt recognize and detect...
First try a different usb cable. The cable or the cable connectors may have been damaged as a result of the fall.
If that doesn't work and you are certain that your PC does not recognize the drive, then It appears to me that the fall damaged the delicate mechanical devices inside the drive and you will have to replace it.
Hard drives cannot withstand rough handling. If a hard drive is only dropped about 1 or 2 feet and it lands on a soft surface such as a carpet it MAY survive the fall. But if one falls from a higher elevation, (say 6 feet) onto a hard surfaced floor, it's almost a sure bet that the drive's internal mechanisms are permanently damaged.
To find out for sure, take it to a PC technician and have it tested. It should only cost you a few dollars.
If you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Regards,
Yavacotech
Dec 09, 2010 | Buffalo Technology 1TB DRIVESTATION COMBO...
Please advice! I accidentally plug my Buffalo external drive of 100V to a 220V! Does this have an internal fuse? Kindly advice, my data stored are important. Thank you.
MY BUFFALO HARD DRIVE model hd-HC320U2-us WILL NOT LOAD WHEN CONNECTED TO MY LAP OR DESK TOP WILL I BE ABLE TO GET MY INFORMATION OFF THE HARD DRIVE, IS THE INFO GONE! WHAT COULD BE THE PROBLEM POWER LIGHT COMES ON BUT THE ACCESS LIGHT DOES NOT BLINK............ TO SHOW CONNECTION HAPPENING
Nov 30, 2010 | Buffalo Technology DriveStation ...
When I connect my buffalo driver the yellow light flashes and I am unable to locate the external drive on my computer.. HELP!!!!
Try to plug your External Drive to other usb port or to other computer, or change the cable.
let me know the result.
dm
Mar 21, 2010 | Buffalo Technology 250GB MINISTATION TURBO...
Can't access Buffalo HD-HB250U2-WR 250gb Ext. Hard
This might be problem with the cable. Try using another cable.
Sep 02, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
HDD is not dedected.
the first thing that pops up in my mind is a power problem. check if the hard disk starts making a 'spinning' noise when you plug in the power chord and turn the disk on. when you hear a ticking noise instead, it means the disk is broken. be sure it only makes the spinning noise. if it does, connect the usb-cable between the disk and the computer. if the disk is not recognised, replace the cable. if still not ok, post what you did as a comment, and please be as accurate as possible, because this problem may have several causes.
Jun 22, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
Computers & Internet Logo
27 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
