Question about Logitech Z523 2 Speakers
I connected them to power but when i'm turning it on nothing happens! Is that cable problem or my subwoofer is burned??
No power
  • Logitech Master
  • 3,320 Answers
The power transformer is toast.
Posted on Mar 30, 2014
Subwoofers Power Cable and Speaker Connecting Cables
Nothing special about the original Nakamichi cables. Brochure here:
Nakamichi Soundspace 12
Jul 14, 2016 | Nakamichi SoundSpace 12 System
Amc eagle problems
Sounds like he caused a wiring short and blew maybe a fusible link. This was I think before maxi-fuses, so fusible links were used to distribute power from the battery.
You get nothing by turning the key to ON? No warning lights on the dash, no gauges, no starter action? If so, follow your positive battery cable to find the location of these fusible links. Sometimes connected to the cable at the starter motor, sometimes off a pigtail from the positive cable. Could be 4 or 5 links, one for lights, one or two for ignition switch, one for wipers, etc. When a link blows out, you just cut it out and replace with the same rated fusible link. A bad fusible link will show signs of having blown. The wire my be burned looking, or may have a rough feel, like bubbles in the wire insulation. What happens is the smaller gauge wire in the link has burned through and saved the wiring harness from burning up.
Dec 12, 2017 | Cars & Trucks
I have a constant buzz tone coming from my subwoofer. I checked power connection, fuse and volume/crossover settings and nothing makes the tone go away. is there anything else I can do? Is it repairable?
Hello,if your subwoofer cable has gone bad this will introduce a hum(buzz) into your audio.I suggest replacing the subwoofer cable, a standard rca cable will do,and see if the audio cleans up.
Sep 11, 2010 | Snell PS.10mk2 Speaker
Jensen JPS12 growls at random...
Get rid of it and get a real sub!
Sep 27, 2009 | Jensen JPS12 Subwoofer
PS-212 Suddenly stopped working
I HAVE 4 PS212 AND FROM WHAT YOU ARE DISCRIBING SOUNDS SIMILIAR TO WHAT HAPPENED TO ME. PLAYING THE SUB AT FULL VOLUME AND CLIPPING OCCURED NOT KNOWING THAT THE FAINT SMELL WAS THE VOICE COIL BURNING AND CONTINUING TO PLAY UNTIL KNOW SOUND LESSON LEARNED BUY A BIGGER SUB SYSTEM OR REPLACE YOUR SUB WOOFER.
IN MY OPPINION THIS IS A VERY GOOD PRODUCT WHICH I HAVE BEEN ABUSEING FOR MONTHS . SO QUIT WHINEING AND PAY YOUR DUES.
May 30, 2009 | Infinity PS212 Subwoofer
HP Pavilion dv2500 no display when power lights not blinking
Hello
To get the display on the TV . Please press Fn + F4 after connected TV to the Notebook using Svideo cable and the cable should be connected to the Svideo port of the Notebook.
If there is not display on the Notebook after the Svideo cable burns.
Then please perform the following steps.
= Power Drain =
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and Battery.
5. Turn on the Notebook power.
If the issue persists then check whether the display is same on the external monitor.
I hope this will work.
Thanks
Aug 24, 2008 | HP Pavilion dv2500t Notebook
Help
can you tell me how your sub is hooked to your amp. is it via the speaker cables or using the amplifier source sub wooker rca connections.
i suppose you have checked all your power cables. if the sub is connected to the amplifier rca output then check the bass sub out level if high enough to drive the auto power switch of sub wfr input. subwoofers normally use an auto power cutoff when no signal. if sub vol level is too low it might not triegger the autopower on.
Jul 16, 2008 | Yamaha HTR-5840 Receiver
No power to control unit
Basically your service did not add anything I had not tried already. I had to send the product back.
I would like a refund.
Apr 10, 2008 | Audio Players & Recorders
My jensen js800 subwoofer keep burning fuses as soon as I turn on
:))))))) You can try to fix it or not to listen it on the max power all the time.You have to send more informations whats happening
Mar 19, 2008 | Audio Players & Recorders
Logitech Z523 2 Speakers Logo
258 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
