Question about HP LASERJET PRO M1132 MFP
Hp logo and attention lights all on on my hp laserjet m1132mfp
It starts to initialise and stucks to Hp logo and attention lights are all on
ctf1800
  • 4402 Answers
SOURCE: How to refill HP Laserjet C4127x Cartridge
http://base0.net/archives/207-Refilling-Laser-Printer-Cartridges.html
http://www.wisegeek.com/how-do-i-refill-toner-cartridges.htm
Posted on Jan 09, 2008
nitinbabbar
  • 55 Answers
SOURCE: HP Laserjet 1022
on the back side thers are two papers sensors inside the printer,they get stucked,normally they should come back
Posted on Jan 23, 2008
Nubar
  • 51 Answers
SOURCE: hp laserjet 1320 problem
This is an error state that is not described at HP site.
Try to do a hard reset:
1) Turn off the printer
2) Press and hold down the green GO button
3) Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
4) Release the GO button.NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
5) The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
Hope it will help you
Posted on Jan 24, 2008
techguru005
  • 28 Answers
SOURCE: HP Laserjet 1320 Printer doesn't respond
Manual Feed or Continuable
Error
This state can be reached in
the following circumstances:
● Manual feed
● Out of paper for the
specified tray
● General continuable error
● Memory configuration error
● Personality/Job related
error
Solution
To recover from the error and
print whatever data is possible,
press the GO button.
If the recovery is successful,
the printer goes to the
Processing Data state and
completes the job.
If the recovery is unsuccessful,
Continuable Error state.
Posted on Feb 22, 2008
713printech
  • 32 Answers
SOURCE: HP color LaserJet 2600n stucked on Initialzing
Well we can check and see if the printer is able to run an engine test. This is how you can run this test;
  1. Turn the printer around so the back of the machine is facing you.
  2. Remove the Engine etest button acess door. This is located in the bottom center of the back.
  3. Push the botton once while the printer is on. The printer should print a page with colored horizontal lines.
If the printer is able to print this page there is a very good indication the problem revolves around the PCA formatter board.
The Firmware might be outdated and causing this problem. Worst case scenario the board might be faulty, in that case your better off buying a new machine, since the cost to replace the board will be higher than that to replace this machine.
Posted on Nov 19, 2008
How do I fix a LaserJet HP2015 printer? The triangle is flashing amber and the Go button light is green.
Don't you just love HP? Since your machine is no longer under warranty they will not help you.
Best bet is to replace or jump the cartridge door switch and see what happens. My guess is that it is stuck.
Nov 10, 2015 | HP LaserJet P2015 Laser Printer
Hp laserjet p4015n attention light is on.
Usually attention error indicates paper jam or cartridge missing, but in this series error message displays on display.. Go through that..
Aug 31, 2012 | HP LaserJet P4015N Printer
HP Laserjet 4345MFP Backlight on printer display does not light. Counts up the 256MB memory then HP logo (3 sizes) appears (just visible) The 3 lights keep cycling on the display. Thats it, does nothing...
HP Laserjet 4345MFP
The 3 lights keep cycling on the display. Thats it, does nothing else.
It has been left overnight and continues to display the logo and cycling 3 lights.
Rear DC Cont Fan is turning. No other fans or activity with machine.
When ADF/scanner/mfp or hard disk are disconnected it does recognise this and throws an error and asks for reboot.
I have tried cold reset, nvram init. and hard disk init. but no difference.
Your thoughts?
Aug 27, 2010 | HP LaserJet 4345mfp Printer
My hp 1150 printer is having a problem
I just bought a Kodax 5300 Easyshare the test page is fine, however when I print a document from a word doument the first print you can barely see the few lines then it does not print at all. What can I do to solve this problem?
Feb 17, 2009 | HP LaserJet 1150 Printer
HP Laserjet 2200 Keeps Spewing Out Blank Paper
sounds like it has a solinoid that is stuck open.
Dec 16, 2008 | HP LaserJet 2200D Printer
Attention Light Flashing
Unfortunately, HP didn't make this indicator very descriptive. Their product specification page for this printer states that the blinking Attention light, "indicates that the printer media input trays are empty, the print cartridge door is open, the print cartridge is missing, or other errors".
You've already changed the print cartridge and the light is still blinking, so you should take a look at the other conditions described such as an empty paper tray, open door, and so forth. You also will want to look for a paper jam or carriage jam. These are two very common errors that will result in a blinking Attention light.
HP.com does provide a web page that describes a specific problem associated with a blinking Attention light:
Job Stuck in Queue
See if any of these suggestions work out for you. If not, post back your results along with anything else that you've learned about the problem. Good luck.
Oct 08, 2008 | HP LaserJet 1020 Printer
Hp laserjet 1320 problem
Jan 24, 2008 | HP LaserJet 1320 Printer
HP LASERJET PRO M1132 MFP Logo
57 people viewed this question
Seeker5211
Seeker5211
