Question about Samsung 30" 1.6 cu. ft. Over-the-Range Microwave Oven SMH8165
Keypad replacement how to change the touchpad
    Habit-Forming:
  • 144 Answers
Remove the front housing and diconnect the ribbon cable very slow.look to see how the key pad was installed and remove it and install the new one. it's not very hard just watch what you are doing and don't lose any small screws
Posted on Apr 13, 2014
Not all buttons work on touchpad
There will be a problem with the touchpad membrane, usually this is usually repaired by replacing the complete touchpad facia or front control panel.
Nov 10, 2013 | Goldstar MV-1515 Microwave Oven
HOW DO I CHANGE OUT THE TOUCHPAD FOR JNM1731DPBB
I'd suggest you contact Matt Fadorsen at eM-Ka Ventures in Chesterland, Ohio. He just repaired my GE keypad on a Model JVM2070CH02 microwave (GE doesn't make just the membrane keypad available--you have to purchase the entire control panel ($548.00 through a local parts distributor). Matt's turnaround from the time I removed the keypad to the time I re-installed it was only 8 days--and it only cost me $100, which included the return shipping. I'm sold on Matt!
Jun 29, 2013 | General Electric GE JNM1731DPBB 1.7 cu ft...
Change Motor but turn table does not turning?
test the following steps and fix it. God bless you
Turntable Motor
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Touchpad and Control Panel
If the microwave turntable doesn't turn the touchpad and control panel might be defective. This is not common. Test the turntable motor first.
Touchpad
If the microwave turntable doesn't turn and the touchpad has a button to turn the turntable on and off the touchpad might be defective. Check the turntable motor first, that is more likely.
User Control and Display Board
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace. If the motor is good, the user control and display board may be defective.
Main Control Board
If the microwave turntable doesn't turn the turntable motor is usually the problem. If the motor is good the main control board might be defective
Jun 16, 2013 | Microwave Ovens
In oven the start button is not working
see the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Nov 15, 2012 | Whirlpool Microwave Ovens
Maytag microwave keypad
see this causes and fix it. God bless you
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Microwave oven touch pad problem
The keypad very well could be worn from use and be working intermittently. Replacing the keypad (and the keypad face if it is a separate piece) is the most logical solution.
Aug 22, 2012 | GE Microwave Ovens
It stopped working what to do to start it
1. The touchpad and external mouse drivers should be able to work together. Just make sure that you have the touchpad enabled. To see if you have the touchpad enabled, hold the Fn key and press F9. The combination Fn-F9 locks and unlocks the touchpad. If pressing Fn-F9 once, twice, thrice does not seem to lock/unlock your touchpad.. then you might not have the Toshiba hotkeys working or enabled. So lets forget it and try step 2. If Fn-F9 solved your problem.. there you go !
Arrow The way it works is you have to keep holding Fn key and have to hit F9 once, that should lock the touchpad. Again if you keep holding Fn and hit F9 again, that should unlock it and so on..
2. Sometimes this solves the problem.. Do a power cycle of your computer.. i.e., unplug the AC.. take the battery out.. Plug the AC back in and try to turn computer ON with AC alone (i.e, leave the battery out and just start computer with AC power).. Once windows loads up and everything is fine, then turn system off. Unplug AC.. put battery back in.. Plug AC back in and restart computer.. All should be working now.. if not, keep reading..
3. Click on START>go to RUN>type devmgmt.msc
4. Now in the Device Manager, click on the + sign next to Mice and other pointing devices. Right click on each device listed under "Mice and other pointing devices" and Uninstall ALL the MOUSE Devices you see listed there..
attention Make sure you ONLY uninstall the Mouse devices and not ALL devices from Device Manager like your CD, Display etc.. Just uninstall the devices listed under Mice and Other pointing devices after you have clicked on the + sign to the left of it..
5.Install Drivers
6. In the page that came up saying Downloads ( All operating systems, All categories ), at the top drop the list Filter by Operating System and select Windows XP (I am assuming you have XP.. if you have another OS, select that instead).. then on the right of it, drop the list Filter by Category and select Touchpad.. then click on the button "Apply Filters"..
7. Now you just see two drivers listed..
09-30-2004 Toshiba Utility
Touchpad Toshiba Touchpad Enable/Disable Utility for Windows XP (v1.27.0.3; 09-24-2004; 5.34M)
06-15-2004 Driver
Touchpad Alps Touchpad Driver for Windows XP/2000 (v6.0.303.5; 05-26-2004; 2.43M)
Click on the Download link on the right.. Save them to your computer somewhere in a folder or desktop, where you can remember.. After the files are downloaded, double-click on the file.. Unzip.. then Run.. and it will install the driver..
8. Restart your computer.. Now the Touchpad should be working fine.. Try Fn-F9 combination.. i.e, keep holding Fn key and tap F9 once, twice to see if it locks/unlocks the touchpad..
Jun 29, 2011 | Microwave Ovens
Touchpad will not work after boiling water underneath it for 12 minutes without fan humidity cause touch pad to stop working , I have a GE mdv 2040 with green display touch pad
you can change the touchpad to help with this but whenever you have a microwave over a range you are going to have issues with this. you have to make sure you use the vent on high whenever broiling anything to prevent the moisture from getting in the touch pad because all your touchpad consists of is two stickers and some flat wire so moisture can easily getting into it cause it to stop working for a period of time. but changing it is the best thing you can do
Jun 02, 2010 | GE JVM1860 Microwave Oven
I have a Sharp model R-1610 Microwave. The work/night light does not work. I"ve changed the bulbs.
Does it operate with a membrane-type touchpad?
These things seem to be problematic as the microwave ages.
They are usually replaceable, and the cost is not great. I just installed a new touchpad on an LG, and it cost $25.00 plus shipping.
Oct 12, 2009 | Sharp R-1610 Microwave Oven
Ge microwave HVM1540DN1BB button control pad stopped working
I am not familiar with the Whirlpool microwaves; however, I just had the same problem with an LG over the range microwave. Several of the positions on the touchpad quit responding to touch. In our case, it was the touchpad itself that was the problem.
The touchpad on our microwave was held in place with adhesive. We pulled it off and replaced it with a new touchpad. Everything works now. The only complication is getting to the connector which carries the signals from the touchpad to the microwave controls. We had to remove and dissassemble the door to get to that connector.
The touchpad cost about $26.00.
Oct 09, 2009 | Whirlpool MH7140XF Microwave Oven
Samsung 30" 1.6 cu. ft. Over-the-Range Microwave Oven SMH8165 Logo
59 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
