Question about Ingersoll Rand Tools & Hardware - Others
At our plant compressor the Air Master S1 Controller is installed (Ingersoll Rand IR-S3, 23009848) . I want to access the factory settings of the controller so that i may increase the rated pressure of the compressor. Right now the rated pressure is set at 6.9 bar therefore the loading and unloading set points cannot be increased beyond 7.1 bar.
  • 98 Answers
SOURCE: what is the amt of oil ingersoll-rand 242-5n air compressor need
Fill to the top of fill spout
Posted on Jul 21, 2009
  • 205 Answers
SOURCE: i have a 5SR EP50SE
The blow down is a normally open valve so there will be no voltage when unloaded. When voltage is applied the blow down valve closes and the load solenoid opens allowing air to the inlet valve which should open. I suspect you have a bad load solenoid. If it leaks by it will keep the inlet valve open to some degree depending on how bad its leaking. If this is an older EP50SE you may have a spring in the bottom of the inlet valve that has broken. then there is not enough pressure to close the inlet valve. These are two common problems with this unit. Also if you look inside the controller panel there should be a wiring diagram. It should show 1SV and 3SV wired together. 1SV is the load solenoid and 3SV is the blow down valve. There is no unload solenoid. There is also a solenoid for line / sump pressure and a modulation solenoid.
Posted on Mar 12, 2011
  • 205 Answers
SOURCE: I HAVE AN INGERSOLL RAND
I know you have checked voltage. However please remove the fuses for control power and check,also check fu4 and 5 16volt fuses. next check power on the controller input. Don't remember terminal # but if you look in electrical cover removed to gain access, a wiring schematic will be affixed to it. I think it's on j5 terminal 36 110volts. But please check the schematic first. If you have power at the input terminal I suspect the controller is bad but continue with the following checks. If no power at terminal 36 check the hat (High Air Temperature) switch. Its located on the end of the airend and about 1/2 inch flex connected.If the hat switch is good check the emergency stop contacts. Note the power lite picks up voltage before the emergency stop and hat switch. So even though the lite is on one of these switches may be bad.
Posted on Mar 28, 2011
  • 205 Answers
SOURCE: Ingersoll Rand SSR EP60 60hp
OK, Compressor should be shut down and showing (ready to start) in display. Press load/unload button once then press hidden right button within 3 seconds. This will let you access the set point program. It will include language, temperature and pressure, rated pressure,etc. Make sure you look at the data tag affixed to the unit and see what the rated pressure is for your unit. You can endanger yourself and equipment by over pressurizing the components of the compressor.
Posted on May 22, 2011
nickwharton1
SOURCE: I installed a used Ingersoll-Rand
I've a ingersoll compressor ssr ep 20 which is shutting down on high airent temperature.
Posted on Jul 11, 2012
Where can i find motor fan part # 2mtr and 3mtr ingersoll rand compressor ssr-ep25
I would try Grainger (www.grainger.com)
They sell IR compressors and always have a large assortment of parts
Jul 16, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Tools & Hardware - Others Logo
110 people viewed this question
Top Ingersoll Rand Tools & Hardware - Others Experts
elunsford
Phil Walker
Phil Walker
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
