Question about Samsung Televison & Video
I want samsung CRT-TV MODEL NO- CS722ANT factory setting code
GREEN CLOUR PROBLEMS
    Top Expert:
  • Samsung Master
  • 74,468 Answers
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Service mode entry, adjust and exit procedure to many popular brand TVs are given.
Posted on Mar 19, 2014
Testimonial: "I already tried the above method. And I also tried the Display>Menu>Mute to open the Factory Settings from where I can reset the whole Tv settings. But this also not works. Could you please tell me the exact functions to open the Factory Settings Menu. May be it will be helpful."
High Green Color While Screening
If you can't adjust the green drive and cut-off even by using its service mode, just check all the related component/s at the green output section circuit [at the CRT] board. Replace the Green output transisor. If this do not help you, the main chroma IC might be faulty, Check all the voltages RGB out from it, and verify, if all of it are almost equal.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 21, 2014 | Samsung Televison & Video
High Green Color In Screen
Yes, if you have a chunghop universal remote or equivalent. Tell me the code, Have been through about 23 service mode factory methods on almost all television brands. So i can possibly help. Thanks for using Fixya.
5 times green light blinking problem
full format find code on web for samsung put in phone or soft problems is higher service reflash
Nov 04, 2012 | Samsung Cell Phones
My Samsung 20" CRT model # TX-P2036 has power
May be you should press the channel button on the set itself or there is a problem with the eeprom of the set circuit.
Jun 15, 2011 | Samsung TXP2036 20" TV
I have a GE Big Screen Tv with Guide plus. model number 46GW948. my son got into factory settings and set the tv in some sort fo 3D setting. the red, green and blue need to be adjusted. Can you help me...
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 12, 2011 | GE 46GW947 46" Rear Projection Television
No green color
Dears,
It happens due to either the PC settings or the monitor (hardware) settings. Would advise you to select menu from the monitor and do a factory setting do a quick check by using paint. The other option here is to access the color management in the control panel, there select the RGB values appropriately Hope this solution helps !!
Nov 09, 2009 | Samsung SyncMaster 700 (White) 17 in.CRT...
No color
Check for the clour settings from the TV or from the remote and reset it to full
Sep 18, 2009 | Samsung TX-R2735 27" TV
Need to unlock vchip passcode; factory reset?
v chip block just popped up on screen , and i never set the tv to v chip
Apr 27, 2009 | Samsung Televison & Video
Factory Settings for Picture
Reset by powering off and unplugging from the wall outlet. If green problem persists than your Green CRT tube could be bad and in need of repair - they go out all of a sudden.
Mar 23, 2008 | Insignia IS 20" TV040919 TV
TOSHIBA 21S3E
Your set needs demagnatizing if it hasn't been dropped. Only a tv repairman has a demgnatizing coil. However one try: unplug it and turn it back on because all standard tv's have an automatic demagnatizing coil circuit around the tube inside. but doesn't always demagnatize completely.
Jan 02, 2008 | Televison & Video
Televison & Video Logo
32 people viewed this question
Henry  Thomas
Henry Thomas
