Question about Refrigerators
Refrigerator and freezer turned off
We were out of town for the weekend and my son called and said the refrigerator and freezer died. The fridge was not that cold and things in the freezer were beginning to thaw. After unplugging and emptying the unit it sat for a day before I began to clean it out for removal. Just on a whim I decided to plug it back in and it began to work! Within 3 hours we had ice etc. The condenser coils were a mess so I cleaned those. I am currently running a defrost test to see if the auto defrost is working properly. Any idea as to what would make it just shut down like that? Should we start shopping for a new fridge because it's just a matter of time? One other oddity that I had noticed lately is the ice cube maker is developing small icicles, it never used to do that. Thanks
    Master:
  • 485 Answers
Check for loose connections in the compressor and the plug or socket. Your thermostat may also be at fault. It might be erratic now. Some ice developing on the thermostat may also cause this.
Posted on Mar 19, 2014
peyton32034
  • 410 Answers
SOURCE: GE TFX27PF refrigerator and freezer still not getting cold enough
the partial frost pattern is an indication of low refrigerant, restriction or bad compressor. if the unit is under 5 years old this repair will probably be under warranty thru GE. if out of warranty then you are looking in most cases between 200-500 dollars for repair. good luck Thanx peyton
Posted on Jan 30, 2009
farfield
  • 462 Answers
SOURCE: fridge condensation - freezer thawing
OK now I'm wondering are theses numbers your getting 4 -9 the actual temps of the refrigerator and the freezer? and do they feel this cold and correct to you? I know the refrigerator side shouldn't be below 34 or so and definitely not below 32. If this is correct and the numbers are not settings but temps. (Now if you have a touch pad its electronic. If it has knobs it has a separate defrost and thermostat and are electro-mechanical)
If electronic Your control board and possibly defrost control are out.
It would more likely be the sensors going to the board(s) It will both sensors have the possibility of causing your problem. 1 will control the run of the compressor (and this one could and probably is connected to the inside coil) and 1 will control the air damper tween the refdg and freezer compartments, and may turn on the inside fan operation too.
(this would be my first suspect if these are degrees numbers). Look at the thermostat control see if it is attached to the indoor coil (usually the tube leavign the indoor section. If its not attached its not sensing the coil temp and when goes into defrost wala its not senmsing temps like its designed to do. Look for a broken clip or possible a plastic wire tie that holds this sensor in place.
Please get back to me with what you see - find on this look up.
Posted on Mar 18, 2009
  • 531 Answers
SOURCE: WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH & KEEPS RUNNIN
remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
Posted on Mar 31, 2009
  • 11 Answers
SOURCE: Kenmore fridge not working, ice cubes wet, freezer frosting up
You may need a new defrost module. The coils ice up when it is not working. This makes the fridge and freezer only a little cold. About 150 to 250 bucks to fix if you call a service person. Under a hundred for the part.
Posted on Apr 18, 2009
woodchuck789
  • 4070 Answers
SOURCE: Freezer coils frost up within minutes after being turned back on
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Aug 31, 2009
Gfe28 fridge with a sa 66 code when plugged in
GE refrigerators and a lot of new appliances have a mode called sabbath mode or SA 66. it turns off your lights and advanced features for the weekend. To exit sabbath mode push and hold light and lock for 3 seconds, or for some models it's light and alarm for 3 seconds.
Jun 30, 2015 | GE Refrigerators
We came home from a weekend away and the freezer was slightly ajar. Everything had defrosted. Additionally, the refrigerator was warm. We closed the freezer and turned the temperature control to the...
There is a good chance that your refrigerator has frozen up from the door being left open.
The best and easiest thing to do is to unplug the refrigerator and prop the doors open for 24 hours to melt any ice build-up that may have occurred and then restart the refrigerator.
If the refrigerator still fails to pull down to proper temp, then you will need to dig deeper to find the problem.
Jun 07, 2010 | GE Profile PDS20SFSLSS Stainless Steel...
Motor is running but it is not cold fride and freezer are 60deg
Sounds to me like the compressor has become faulty. it is not able to start. After a while the clixon starts to burn which explains that smell. Suggest replacement.
Sep 16, 2009 | Jenn-Air JCD2389G Side by Side...
Freezer not maintaining temp
sounds like the evap thermistor took a ****. in the back of your freezer you have cover that sits over the refrigerator coil. under this coil sits a heater element that is turned on and off to defrost the refrigerator coil based on how long you've had the door open. the evap thermistor reads the temp inside the freezer.. close to the refrigerator coil.. and tells the heater element to turn off after it reaches a set temp where it can be sure that the ice has melted off the refrigeration coil which is about 60 deg. if your thermistor has taken a ****.. your heater element will only shut off based on the "fail safe" time (which is based on how long you've had your fridge door open) leading to a hot freezer.
i suspect your at home more on the weekend.. inside the fridge.. getting cold beers.. and that is why it ends up hotter on the weekend.
Cheers!
Jun 14, 2009 | GE Energy Star PDS22SIS Stainless Steel...
Apr 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
Nov 18, 2008 | Maytag Refrigerators
Whirlpoolpool side by side
The pattern of frost buildup would indicate to me that the freezer door may not be fully closing due to a product on the door or shelve. Frost only on the back wall would indicate a defrost system problem. Frost like snow on product packages indicates air leaking into the freezer in some way.
Nov 11, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
