Question about Craftsman 1 Hp, 4 Gal. Air Compressor
Have two knobs, one to show air pressure, the other is for what ?
I'm scraping ceramic tile from floor. My compressor runs out of air too quickly. I am going to drain the tanks. How should I adjust the second knob (smaller of the two, near air outlet) and what is it for? Do not have a manual.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
To save you a few headaches, I would look into renting an automatic scraper to remove the tile. They can be found at The Home Depot's tool rental center for a very reasonable price. Compaired to continuously adjusting the pressure on your compressor or damaging both tools due to the compressor and the stress of fighting with it, the tools that can be rented are very reasonable. Good Luck. It's a nasty and painful job no matter how it's approched.
Posted on Sep 30, 2009
  • 365 Answers
You have to "unlock" the adjustment knob by first pushing the outside lock ring...turning the center knob to the right will give you approx 110psi...I doubt you'll have enough, even at max, to run even the smallest tool...without frequent breaks.
Good Luck
Posted on Jun 14, 2009
What is the difference between Porcelain and Ceramic tiles?
I asked myself the same question after seeing both types of tiles in a few bathroom showrooms in Kent - they look very similar.
Despite appearances though, it seems that there are a few differences.
1. Porcelain tiles are more suitable for heavy-traffic areas, such as indoor and outdoor floors. This is because they are typically denser and more hardwearing than ceramic tiles.
2. Ceramics contain a lower amount of kaolin than porcelain tiles
3. Porcelain is more expensive to manufacture, and therefore buy, than ceramic tiles.
4. Ceramic tiles are lighter and easier to cut than porcelain tiles.
5. Ceramics need to be glazed in order to become impermeable, whereas porcelain tiles are impermeable without the need for glazing.
These are just a few of the differences. A good bathroom products supplier should be able to explain the differences to you in more detail.
May 16, 2018 | Saws
How do you drill through ceramic tile
Go to Lowes, Home Depot, Menards or reasonably good Hardware store. buy a ceramic bit. They are usually with the wood, steel and concrete bits. Small bits arent to pricy. If you need a larger hole like the on the shower pipe goes through, you will need a ceramic hole saw. Hole saws are coated with diamond chips and will probably cost $40 or more. good Luck
Oct 08, 2015 | Porcelanosa Ceramic Wall Tile: : Mosaico...
My Porter Cable pancake outlet regulator doesn't seem to work.
If your quick coupler is not jammed up, (remove & test) and assuming you are pulling the regulator knob out to adjust the pressure and it is not stripped, you will need a new manifold kit.
There are about 6 versions of this unit so you will need model and type to get the correct part. There are no individual regulator parts available for this unit.
Jul 02, 2013 | Porter Cable C2002 150 Psi 6 Gal...
Compressor runs and sounds ok, but it only manages to show 20 lbs. It will not build air pressure and continues to run.
check air tank drain valve located on bottom of tank, if it is not leaking try adjusting air pres regulator (large black knob close to air hose connection.) the knob when turned in will increase the tank air pressure, if knob wont turn check that lock ring on bottom of knob to make sure it is disengaged. also check for air leaks in all lines and connections
Apr 16, 2012 | Craftsman 1 hp Air Compressor, 4 gal. -...
I don't know what that adjustment knob is supposed to do or what the two dials mean.
The knob adjusts the outlet air pressure. One gauge shows tank pressure and the other is your outlet pressure. The pressure is changed by turning the knob (generally counter-clockwise to reduce pressure) Pressure requirements differ depending on the tools you are running. Most air tools will list a Maximum Operating Pressure on them or in the manual.
Mar 21, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Can ceramic tile be installed over old ceramic tile?
You can install tile over tile. However here are the risks. The new tiles will require at least 3/16" of tile adhesive UNDER the tiles when put in place after they have been pressed into position. Additionally the trim around the tiles willhave to be removed and elevated the distance of the tile thickness and the 3/16" grout distance. The tiles if on the second floor of a home will easily losen due to the expansion and contraction of the home and the difference in the 2 types of tiles expansion and contraction rates.
It is not difficult to remove old tiles. You use a flat bar type scraping tool and the old tiles usually will pop right up off the floor. You will have to break maybe 2 tiles to get started but after that they are easy to remove.
My experience in my own fully tiled in all rooms 2900 sq ft home in the tropics is that I have to remove the old tiles as over time the new tiles losen on top of the old tiles. I have tried it several times and have had at least 1 tile come loose each time.
Thanks for choosing FixYa,
Kelly
Oct 05, 2010 | Home
Craftsman 1 Hp, 4 Gal. Air Compressor Logo
138 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
