Question about ViewSonic VG150 15" LCD Monitor
The cable connect bitwen cpu and the screen is cut I am trying to repair my Viewsonic e70f but I cant do it without color of the wire please help me I m waiting you
The cable connect bitween CPU and the screen is cut I am trying to repair my Viewsonic e70f but I cant do it without color of the wire please help me I m waiting you
  • ViewSonic Master
  • 2,013 Answers
If it is a VGA cable, the chart is here...
http://www.tomshardware.com/forum/291592-33-cable-color-code
Posted on May 28, 2014
  • 86 Answers
SOURCE: when i on the PC this message appears on the
To enable or disable the OSD lock feature, press and hold the 1 and the up arrow for 10 seconds.
Posted on Jun 03, 2009
SOURCE: I unlocked OSD Locked of CRT ViewSonic e70f by
monitor shows osd lock how to solve this problem
Posted on Aug 23, 2009
gripfitter
  • 557 Answers
SOURCE: ViewSonic VX2235WM turns on than screen goes blank
The problem is most likely the monitor itself. Hook up an old monitor (usually someone has an old monitor laying around) if the computer works with another monitor you'll know for sure.
Look at your monitor using a flash light at an angle, if you can see a picture in the background you have a bad inverter.
Posted on Nov 28, 2009
budmrtn
  • 11361 Answers
SOURCE: my ViewSonic VG1930WM (Black) LCD Monitor wont turn on
You need to open it up and the first place to look will be the power supply, look for bad caps with bulging top, post back what you find so we can guide you further. See example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Mar 01, 2010
  • 3 Answers
SOURCE: Monitor display stays for a few seconds only but has power always
I have the exact same issue with mine. Viewsonic VX2235WM turns on fine for about three seconds when asked to by my software attempts, but then shuts into sleep mode. I agree completely with BudMrtn. The issue is that your monitor has been through some stress and one if not multiple of the problems is due to part failure. In this case I would suggest a capacitor issue. First off make sure, for a fact, that you have the appropriate drivers. ( For Windows 7 I would suggest using the unsigned drivers from Viewsonic for this model. Now the reason that it is cutting off after a few seconds is because one of the capacitors is not sustaining a charge. It is showing as on for a sec because it is getting the appropriate power to operate but it is not receiving the appropriate level to maintain and is either shorting or free flowing the voltage inappropriately. Now the real question is... do you fix this issue. Well the monitor isn't the most expensive, but it is nice and would be worth the trouble. I would suggest you take a practice run on yours to learn a little something about repairing this level of issue. It is not a very hard fix but it is a very technical one. Understand that to you it is dead already, so what is the worst thing you can really do to it. Use absolute caution when handling these type of repairs. Make sure it is unplugged and use a muli-meter to find your short. I suggest you try and repair this because it is not as dangerous as a CRT. With a CRT you have to watch for residual charge... now you are looking for a busted capacitor which you must realize does retain a charge and electrocution can and more then likely will occur. Use a surge protector in case you screw up. Now if I am right the capacitor you are looking for is not holding a charge so residual charge is probably not going to be an issue... but you never know. Also always keep in mind that even though we have the exact same result, the issue may be varied to a degree of almost infinity. It smells like poo, it looks like poo, it even taste like poo, but it might be a ham sandwich, or a pigeon. My point to all of this is that you should not look at this as a downed monitor, instead you should view this as an opportunity to better get to know your electronics and how to repair them. Have fun and good luck.
Posted on May 27, 2010
Repair wire from signal cable is disconnected or broken (15 Pin D shape Connector)
Soldering usually. Some connnectors were prefabricated with rubber being injection moulded. Your best bet is to purchase a 15 pin D connector and change the old one by soldering.
Mar 19, 2014 | ViewSonic E70f 17" CRT Monitor
On my viewsonic moniter it is displayed as OSD LOCK
press in the three buttons on the monitor ( + , - , and menu) at the same time , connect the power cable, that will reset the monitor to the factory settings
if you see that is helpful please don't forget to vote me
best regards
Apr 23, 2011 | ViewSonic E70f 17" CRT Monitor
Viewsonic E70f monitor goes standby by message OFF MODE IN 5SEC
off mode in 5 sec,problem represents that the data cable is not properly connected or the monitor is unable to recognize the connection once check your key board lights above the num pad when you switch on the PC if the lights appear . Then the power supply is not provided to only the monitor unplug the data cable and plug it again properly,even if doesnt solve your problem just shake the data cable receiver pin located to the back of the monitor.
If the lights on the keyboard does not appear the problem is within the cabinet it may occur due to the dust too,so clean it properly , using a hair drier for blowing the dust is better.
Hope this would solve your problem.
Nov 03, 2010 | ViewSonic E70f 17" CRT Monitor
OSd lock keeps on poping up on my screen
check your vga/dvi cable connection at both ends, computer and monitor
Nov 01, 2009 | ViewSonic E70f 17" CRT Monitor
My monitor is displaying the contrast.... screen all the time!! I
Please check the display adjustments & cable connections of your monitor, if still the problem exists, then there's an internal electronic part/s of your monitor that are cold soldered / defective. I recommend to bring the unit to a service center to properly diagnose & fix the problem. best regards
May 22, 2009 | ViewSonic E70f 17" CRT Monitor
Viewsonic E70f 17
Check the horizondal out put transistor if it is short replace the transistoror or replace the flyback transformer.
May 01, 2009 | ViewSonic E70f 17" CRT Monitor
ViewSonic VG150 15" LCD Monitor Logo
50 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
