Question about Nvidia Tesla C2070 Computing Processor - 6GB GDDR5 RAM, PCI-Express 2 0, 448 Processing Cores, NVIDI Video Card
Hi, how can I know that my computer processer is affected?
The fan attached to the processor of not functioning normaly
  • 22 Answers
If any doubt about the fans in your computer (CPU, GPU, case...), you must monitor the TEMPERATURES, with a software, and with your fingers by gently touching surfaces : if it hurts (really HOT), stop the computer and fix the fan...
But your pbremains unclear : please add details !
Posted on Mar 21, 2014
Download slow browsing history ccleaner
Its probably getting too hot in the PC, and causing it to shut down.
When FVD starts to do heavy processing the PC draws more power and the processor gets hotter. If the heatsink and fans are dirty or loose the processor gets too hot and decides to shut down the PC to stop it burning up. Clean all dust from inside PC and fan areas, make sure heatsink is firmly attached to top of CPU inside PC.
Dec 15, 2013 | Freemake Video Downloader
Fan slow down and them high speed
change the fan ASAP, since the zooming noise and the slow performance will affect even the processor and you might end up replacing the processor as well if it persists. So get the fan ASAP and problem will be solved.
Sep 30, 2013 | Gateway GT5622 PC Desktop
Hi im running windows vista home premium, and ive noticed my fan has been running all the time for months now and it gets really hot, I also noticed that my processor runs between 60 & 100% now too. im...
With all the stuff running in the background of Vista, and Norton, you could very well be maxing out the computer. Memory, processor or both. I have a laptop, and I close down the HP total care advisor, and any periphial programs running that I am not going to use. like backup programs and printer standby stuff. Norton does use a lot of resources especially on updating an d processing the updates. I usually let my PC do it's thing until the HD activity light quiets down before I try to use it.
May 28, 2010 | HP Computers & Internet
Varying Fan Noise
cpu fans are smart fans it works according to processor's temprature. more processing of cpu makes fans speed faster...slowing down the speed of cpu fan may affect your cpu's performance
Sep 24, 2009 | E-Machines eMachines Desktop PC
Desk computer overheat
hi there,
the thermal over heating is functioning, press F4 to resume on normal function then once the windows appear go to all program,
accesories and system restore click restore point, select a date that your pc run normaly
it will restore your pc on normal function you ca experience restarting and that the point it will restore your system.If still syntom persist
reinstall your windows system.have a niceday
regards
Jul 10, 2009 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Hi I opened a work computer Dell GX260 to clean it out as a favour for my boss. I've removed the processor fan in the process. I then decided that I don't have the right equipment to properly clean it....
You confirm all the connectors are properly connected. Check the power supply connector and the power button connector. Remove the cpu fan connector and refix it properly. Ther is no other chance for failure.
May 05, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
My asus eee is not switching on, the screen is flickering on and off but nothing is being displayed on the screen and it isnt coming on...
That problem is from the processor fan not working in which will have affected your processor itself ok try and replaced the processor fan if its not working and if affected by the processor you will need to change that too for normal and adequate functioning of the system .ok
Rate this solution
Nov 27, 2008 | Computers & Internet
Computer turns on but no Video and doesn't go through POST.
Before you "fry it" try taking the CPU fan off of the processor, remove the processor, reinsert the processor and CPU fan and see what happens.
Nov 11, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Computer hangs up
You dont need those stress you will only be concern on your processor or do you use the pc with a network as in is it connected for browsing if itis connected try and always clear your cookies and again the processor fan may not be blowing well so it can cause it to be freezing all the time once the processor works too much without cooling fan ok try and do something about that your system will be ok
sure
Please rate this solution.
Oct 30, 2008 | Acer Aspire 3000 Notebook
Cooling fan stop working
It's normal for the fan to stop and start, as needed. However, it sounds as if the heat sink attached to the processor and fan may be clogged with dust/fuzz/hair, etc. If you can, vacuum or blow air back through the ventilation ports to clear the debris.
This usually causes the fan to run constantly. It's possible that you need to adjust the power management settings in control panel-toshiba power management.
Also,try keeping the laptop in a cool place and see if it makes a difference.
Let me know how it works.
Good luck
Nov 25, 2007 | Toshiba Satellite A135-S2276 Notebook
Nvidia Tesla C2070 Computing Processor - 6GB GDDR5 RAM, PCI-Express 2 0, 448 Processing Cores, NVIDI Video Card Logo
70 people viewed this question
Top Nvidia Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
