Question about InFocus Office Equipment & Supplies
Geha 285 eca
Power supply bulb blinks but no further opperation
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
1, the lamp ballast is failing
2,the mother board is failing
3,check the fans, if every fan is running
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD
chip,color wheel,motherboard,powersupply,ballast... with high quality and
competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Posted on Mar 21, 2014
  • Lampdeng.com
    Lampdeng.com Mar 21, 2014
    sorry,I was make a mistake:my skype is not lampdeng. my skype is : lampdeng@hotmail.com
Status light blinks seven times
the lamp timer is failing
lamp timer chip is on the lamp housing,is a little chip
you need to reset the timer chip by using a Programmer
select a date of 0 hour..
Our company supply this chip with 0 hours USD15
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jan 31, 2014 | NEC MultiSync MT1065 Multimedia Projector
Sorry i wrote under comments in stead of here but i did forget to tell you that the car ran ( worked ) for 2 months after i replaced the cylinder and then died - sorry for not shareing that bit -
Hello, This is the same mechanic as you had earlier. The Ignition switch would still be a good place to look at. Just check to see what the Terminals on the switch are really doing when the Key is in different positions.
The turning of the Key initiates both the ECC and the ECA. The ECA will shut down first(times out) and then the ECC will shut down because it needs to sense the ECA is working. But on your car the fuelpump is continuing to run. This would mean it is getting continuous power.
Your ECC RELAY is probably toast and is continuing to supply power to your fuel pump. This would be a part that you would replace. Check your Ignition switch positions anyway.
Nov 25, 2010 | 1997 Ford Thunderbird LX
I need power supply for infocus 4805 screenplay
You shold buy 520-0143-00 ECA, POWER SUPPLY, X2 Use if S/N contains an A in the fifth from the right digit "AMMxxxxA0000" 520-0126-00 ECA, POWER SUPPLY, X2 Use if S/N contains a zero in the fifth from the right digit "AMMxxxx00000"
cost about $90
May 23, 2010 | InFocus ScreenPlay 4805 Multimedia...
Instructions manual seems to imply that two 24 Vac (10VA) transformers are required if the HUM or ECA terminal is used to power the automatic digital control. HUM or ECA terminals are 120 volts. The...
No, you do not need another one. Wire everything just as you see it in the wiring schematics and you will only need the transformer supplied with the unit.
Heatman101
Jan 25, 2010 | Aprilaire 700 Humidifier
LP70+ shutting down randomly and now not at all
there is a problem with the zero volt ground reference level. if you're good at soldering, try this:
1. Locate cap C105 on the power supply and then turn the board over to the solder side.
2. From the solder side, locate C105, pin 2.
3. Using Lead-free solder only, solder the 60mm length
of wire to C105, pin 2.
4. Fold the cable over the edge of the power supply and secure into place using RTV45, Loctite Tak Pak Instant Adhesive, or suitable substitute.
Connection to Main Controller ECA
1. Using Lead-free solder only, solder the 30mm length of cable assembly to C900, pin 1.
2. Fold the cable over the edge of the main controller ECA between the two connectors as shown then secure
into place using Loctite Tak Pak Instant Adhesive.
if this seems like too much, you can send it in to an infocus authorized service center. try AV Solutions ( www.avsolutionsny.com ). they're really good.
Sep 30, 2009 | InFocus LP70+ Multimedia Projector
Blinking Timer Light
Relay or capacitor on or by the power supply
Jul 08, 2009 | Pioneer DV-285-S DVD Player
Unit will not Power Up.
Terry, I had the same problem. Its a small capacitor on the power board labelled 'C16'(right in the middle of the board) its value is 16volt 100uf.
I also changed the biggest one on the board as well( 450volt 270uf @85deg). The big one was sourced through RS components @£5.14, the other I got through a maplins store for the grand sum of 13 pence.
Both are quite easy to change if your not adverse to taking the unit apart. (Just remember where all the leads plug in).
A torx T10 screwdriver, and soldering iron is all you need.
Jun 03, 2009 | InFocus ScreenPlay 5700 Multimedia...
Order main drive gear for geha paper shredder
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Feb 18, 2008 | Geha Primo 2600 Shredder
Screen has vertical lines in the display
either the power supply or the main board (eca).
Sep 21, 2006 | ASK Proxima Proxima DP2000X Multimedia...
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
