Question about Sanyo Plc-su50s Pro-x Multiverse Lcd Projector W/ Dvi,vga,usb
How to check for lamp life
What is a key combination to test remainimg lamp life
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
In menu you must find the "life time" for your lamp
Posted on Apr 04, 2014
Passager side tail light not working... But brake light does..changed bulb and then plug..still the same...05 ford escape
Do you know how to use a wiring diagram along with a DMM - digital mult-meter to test electrical circuits ? Do you know what a FORD smart junction box is ? It's a electronic control module an it supply's B+ voltage for the tail lights . Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info. year ,make , model an engine size. Under system click on lighting then under subsystem click on parking lamps .
Your first step should have been to take it to a qualified repair shop that has a scanner that can read DTC'S - diagnostic trouble codes out of the SJB
Smart Junction Box (SJB) Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU Is Defective SJB CLEAR the DTCs. RETRIEVE the DTCs. If DTC B1342 is retrieved again, INSTALL a new SJB. REFER to Section 419-10 . B1578 Park Lamp On/Off Switch/Circuit Short to Ground SJB Go To Pinpoint Test T . C1961 Park Lamps Relay Coil Circuit Failure SJB Go To Pinpoint Test S
Symptom Chart Condition Possible Sources Action
  • The exterior lamps are inoperative
  • Circuitry
  • Parking lamp relay
  • Multifunction switch
  • Smart junction box (SJB)
  • Go To Pinpoint Test R .
  • One or more parking, rear or license lamps is inoperative
  • Circuitry
  • SJB
  • Go To Pinpoint Test S .
  • The parking, rear or license lamps are on continuously
  • Circuitry
  • SJB
  • Go To Pinpoint Test T .
PINPOINT TEST S: ONE OR MORE PARKING, REAR OR LICENSE LAMPS IS INOPERATIVE Test Step Result / Action to Take S1 CHECK THE STOPLAMPS AND TURN LAMPS
  • Key in ON position.
  • Operate the turn signals and apply the brake pedal while observing the exterior lamps.
  • Do the stoplamps and turn lamps operate correctly?
Yes
GO to S2 .
No
REFER to Stoplamps or Turn Signal, Cornering and Hazard Lamps in this section to diagnose the stoplamps or turn lamps. S2 DETERMINE THE CONDITION
  • Place the multifunction switch to the parking lamps ON position.
  • Are all the parking lamps inoperative?
Yes
No
If all front parking lamps are inoperative, GO to S3 .
If all rear parking and license lamps are inoperative, GO to S4 .
If one parking or license lamp is inoperative, GO to S5 . S3 CHECK CIRCUIT 14 (BN) FOR AN OPEN (FRONT LAMPS)
  • Key in OFF position.
  • Turn the headlamp switch off.
  • Disconnect: Smart Junction Box (SJB) C2280b.
  • Measure the resistance between the SJB C2280b-8, circuit 14 (BN), harness side and ground
  • Is the resistance less than 5 ohms?
Yes
GO to S6 .
No
REPAIR the circuit. TEST the system for normal operation. S4 CHECK CIRCUIT 14 (BN) FOR AN OPEN (REAR LAMPS)
  • Disconnect: Smart Junction Box (SJB) C2280c.
  • Measure the resistance between the SJB C2280c-19, circuit 14 (BN), harness side and ground
Yes
GO to S6 .
No
REPAIR the circuit. TEST the system for normal operation. S5 CHECK THE GROUND CIRCUIT
  • Disconnect: Inoperative Lamp.
  • Measure the resistance between the inoperative lamp connector, harness side and ground as follows:
    Lamp Connector Circuit LH side marker lamp C156-2 RH side marker lamp C166-2 LH front lamp C1023-1 RH front lamp C1043-1 LH rear lamp C419-1 RH rear lamp C418-1 LH license lamp C454-2 RH license lamp C462-2
Yes
REPAIR circuit 14 (BN). TEST the system for normal operation.
No
REPAIR circuit 57 (BK). TEST the system for normal operation. S6 CHECK FOR CORRECT SJB OPERATION
  • Disconnect all the SJB connectors.
  • Check for:
    • corrosion
    • pushed-out pins
  • Connect all the SJB connectors and make sure they seat correctly.
  • Operate the system and verify the concern is still present.
  • Is the concern still present?
Yes
INSTALL a new SJB. REFER to Section 419-10 . TEST the system for normal operation.
No
The system is operating correctly at this time. The concern may have been caused by a loose or corroded connector. CLEAR any DTCs. REPEAT the self-test.
Feb 27, 2018 | Ford Cars & Trucks
I have a Kodak Ektagraphic with no model listed on it at all. How can I find a replacement bulb, all I can find look wrong.
Supplied with 82V, 300W EXR lamp Projection Lamps Quartz-halogen 82 V projection lamps- Here is service manual link http://resources.kodak.com/support/pdf/en/manuals/slideProj/manual/ektagraphic_sm.pdf Several different Models all say EXR 300W As CORRECT Bulb : EXR, 300 W (35-hour lamp life at full lamp/medium-brightness) Sampling of other lamps: EXY (200 hours/less brightness) EXW (15 hours/maximum brightness) FHS (70 hours/medium brightness) Use combinations of lamp brightness, plus half- and full-lamp settings to approximate image brightness in multi-projector presentations. Lamp Tips • Projector operation on line voltages above 125 volts greatly reduces the lamp life. • Unplug the projector before changing the lamp. • Allow for unrestricted flow of air to the exhaust vent to prolong lamp life. • Gently wipe off any fingerprints with a soft cloth moistened with rubbing alcohol.
Jun 27, 2016 | Kodak ATS Ektagraphic Slide Projector
How can i turn down contrast on my laptop
Acer Aspire one
Brightness is controlled by the Fn and arrow keys.
Contrast can be controlled from the software.
FN key, + left/right arrow key's
other Acers
Log on to your Acer laptop and click on the "Start" button. Choose "Control Panel" from the menu.
Double-click on the "Display" icon in "Control Panel" and select the "Settings" tab.
Check the "Color Quality" settings and make sure they are set to either medium or high.
The high setting will give you better color quality and contrast, but it will also use more system resources and shorten battery life.
If you are operating on battery power you may want to move the setting to medium.
Hold down the "Fn" key and press the right arrow at the same time.
This key combination will increase the brightness of your screen.
To decrease the brightness and contrast, hold the "Fn" key down and press the left arrow. Continue using these key combinations until you have found the optimal setting for your laptop display.
hope this helps
Oct 08, 2012 | Acer Aspire One D255E13438 Netbook
Reset service lamp 2001 cavalier
if the check engine lamp is on and the problem has been corrected, remove the black ground cable from the battery for 5 minutes and reconnect this will reset the ecu. if you are refering to the oil change, look in the manual there are a few proceders for the different models.
turn the ignition key to on not start and press the gas pedal all the way down and up 3 times in 5 seconds, turn the key to off then than start, the oil life reset will will show and everything will return to normal.
there is also a selection in the digital odometers to scroll trough using the trip reset button in the cluster, when you reach the reset oil life hold the button in until "oil life reset" has flashed.
Feb 19, 2011 | Chevrolet Cavalier Cars & Trucks
How to check the backlight life of my hp l1706
Claimed life for the lamp is 50,000 Hours, but in real life, no way to tell. You can look here what is failed in the backlight lamps, it can be from worn out (blacken ends is one sign of bad lamps, same as home fluorescent lamp), poor soldering works on the lamps. see pictures here: http://s807.photobucket.com/home/budm/allalbums
What is the problem with your monitor anyway?
Mar 30, 2010 | HP L1706 17" LCD Monitor
Need to know what size bulb goes in dome light
For 1991 TOYOTA Pickup replacement bulbs, review the list and check it in other brand with this model:
High & low beam headlamp
H6054
H6054ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H6054XV XtraVision Halogen - The Brighter Light
H6054CB Cool Blue Halogen - The Whiter Light
H6054LL Long Life Halogen Upgrade: Lasts 6x longer
Parking light
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
1156
1156ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear turn signal
1156
Tail light
1157
1157LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
1157
License plate
194
89
Back up light
1156
Front sidemarker
194
Glove box
161
161LL Long Life Upgrade: Up to twice the life of the standard lamp
Step/Courtesy light
DE3022
DE3175
DE3175LL Long Life Upgrade: Up to twice the life of the standard lamp
7443LL Long Life Upgrade: Up to twice the life of the standard lamp
Hope helped with this (remember rated this help). Good luck.
Nov 11, 2009 | 1991 Toyota Pickup
HP compaq 6710b - Hi I can't adjust the brigthness of my screen from my keyboard anymore. I used to be able to hold down the "fn" key and then press "f9" to decrease or "f10"to increase the brightness. Now...
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 30, 2009 | HP Compaq 6710b Notebook Pc
Toshiba a200 laptop Have black screen even tho laptop has booted up, going by the usual sounds.Took battery out and used ac adapter, but same problem.Switched power off several times, left off over night...
You could have a defective screen - follow this to determine the fault.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 19, 2009 | Toshiba Satellite A200-0ET00X Notebook
Lamp light coming on my wd52527 when lamp was just replaced tv saying lamp is about to exceded its life
There is a reset of thew lamp timer which should have been done at time of replacement. It is usually the combination of holding 2 or 3 buttons at the same time. The manufacturer usually has it posted on the web or the instructions with the lamp should have the procedure....
Last resort is call the manufacturer tech line
Apr 18, 2009 | Televison & Video
Can't get into test command mode
To enter the serviceman test command mode, press the keys as
follows:
[#] key → [*] key → [C] key → [*] key
To cancel the test command mode, press the [CA] key.
H4 00 Content Heat roller low temperature detection
Detail The fusing temperature does not reach 185°C
within 27 sec of turning on the power, or the
fusing temperature keeps at 140°C.
Cause Thermistor abnormality
Heater lamp abnormality
Thermostat abnormality
Control PWB abnormality
Check
and
remedy
Use TC 5-02 to check the heater lamp blinking
operation.
When the lamp blinks normally.
Check the thermistor and its harness.
Check the thermistor input circuit on the control
PWB.
When the lamp does not light up.
Check for disconnection of the heater lamp and
the thermostat. Check the interlock switch.
Check the power PWB and the lamp control
circuit on the MCU PWB.
Use TC 14 to clear the self diagnostic display.
Feb 03, 2009 | Sharp AR-168D Black and White Copier
Sanyo Plc-su50s Pro-x Multiverse Lcd Projector W/ Dvi,vga,usb Logo
43 people viewed this question
Top Sanyo Computers & Internet Experts
kj henriksen
kj henriksen
William Alequin
Are you a Sanyo Computer and Internet Expert? Answer questions, earn points and help others
