Question about Pentax Cameras
Camera wont stay on
My camera wont stay on for more than 5 seconds. I have tried both the batteries that were fully charged and it still didn't stay on and also it shows that the batteries are fully charged on the camera as well
  • 20 Answers
If you have checked than ignore this. Some cameras have a time out setting and it may be the problem.
Posted on Mar 20, 2014
iwhitman2055
SOURCE: Olympus digital camera wont turn on
First: thank you, for suggesting battery terminals. It was failing to power on intermittently for some time; the problem became more-and-more frequent until it would not come on at all. Cleaning the terminals saved my camera! Second: for others, let me suggest plain old pencil erasers as a good way to clean electrical contacts (something I learned from HO model railroads as a kid). A vigorous rub with the brand new eraser on the end of a pencil cleaned the battery contacts inside the camera.
Posted on Jul 29, 2006
SOURCE: logitech pocket digital camera
Same happening to me. The solution is to try it in a different USB port, as it is a USB related issue.
Posted on Jul 21, 2008
darntoothysa
  • 489 Answers
SOURCE: Battery Fully Charged Camera Won't turn on
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD600 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
A couple solutions would be to either buy a defective camera online and make one good camera from the two if you can do that sort of thing yourself, or secondly have it repaired by somebody.
Don't bother trying to send the camera to Canon if it is out or warranty (though you can call them and verify what I'm about to say) because they will want $150+ to do the repair for you. Parts are not cheap to buy from them.
I know of one very affordable digital camera repair business... because I own it. The name is Darntoothysam, feel free to check us out, we are on that big auction website also (I don't plug their name for free), our seller ID is 'darntoothysam'. If you Google "darntoothysam" you will find us.
If we can help with your repair then please let us know.
Hope this helps,
Thomas
Posted on Nov 11, 2008
BillB-SA
  • 2761 Answers
SOURCE: kodak easyshare ls743
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
BillB-SA
  • 2761 Answers
SOURCE: Battery is fully charged but camera does not work
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
Posted on Dec 09, 2009
My Nikon D3100 will not turn on. Is there something wrong with the batteries/memory card? Or rather the camera body itself?
It could be either the battery or the camera.
If you have a second battery, try it. If it works with the second battery then the first battery is bad.
If you don't have a second battery, take your camera and battery to a good photo store. They should have a second battery to try. You might be able to test your battery with one of theirs. This will tell you whether the battery or the camera is bad.
Oct 04, 2016 | Nikon D3100 Digital Camera
Power switch not working
hello sir .. does your batteries are charged already??
if your batteries are fully charged and your camera didn`t turn on,
there`s a possibility that your camera has a problem. You can visit the store where you bought your camera and you can ask questions there why does your camera didn`t turn on whenever your batteries are ok .. :)
Feb 23, 2013 | Kodak EasyShare C142 Digital Camera
When I push the power button, the lens cap comes out and on the screen is a very brief shot of what the camera is aimed at. The camera stays engaged for one second and the lens cap goes retreats back into...
Try to remove the rechargeable battery and use a battery of the same type but an alkaline like the energizer. Sometime rechargeable battery malfunctions that it seems fully charged but actually is not. If the camera continue to power on when you replace the battery it simply means that your problem is in the battery.
Nov 26, 2010 | Kodak EasyShare M1093 IS Digital Camera
Wont stay on
I could not find the vpce890 digital camera referenced on sanyo.com.
But, I did find that the battery should be charged by placing in the charger until the light turns green.
Are they Li-ion batteries or other type?
Jul 16, 2010 | Sanyo VPCE890 Digital Camera
Loosing power randomly
how old are the batteries and how many times they were charged without being fully drained can cause a short life for the battery. Try a new battery-fully charging it properly, but dont charge it again till it goes off by itself completely. If you have a wall charger, plug your phone in. If it stays on that way, check your 'power save' settings. That can also make your camera shut off. Try these steps first and see if it changes the 'battery' from being empty to full and stays on. hope this helps
Aug 24, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Camera not staying on
Please use New rechargeable batteries now as old one has lost ability to store charge for longer time.
Nov 29, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Camera on for 5 seconds red flashing light then turns off
that definitely sounds like a battery problem.
when you charged the battery, did the light stay red, and then turn green when it was finished?
if it flashed red, try this:
MATERIALS: 9 volt battery, 2 pieces of wire the same length, casio battery
DIRECTIONS: connect the + sides of each battery with a wire, and the - sides of each battery with another wire. [I just held them there, but maybe you can tape them if you're having trouble.] Hold it for 30 seconds. Then try charging it. If it doesn't work keep trying it until it does. TRUST ME! It took me 5 times to do it effectively.
If your battery has gone too long without charging, sometimes it won't charge correctly any more. So do this.. IDK why it works, but it did for me!
Nov 19, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
SONY DSC-H9 WON'T STAY POWERED UP
I think that both your batteries are bad. Because the batteries have sat on a shelf not being used the batteries will only take a surface charge and not fully charge. Bum a battery from someone with a Sony that uses the same battery and see if that works.
Sep 20, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
Help
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
May 25, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Cameras Logo
75 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
