Question about Car Audio & Video
I have no idea how to replace the speakers in my 2010 pontiac g3/wave SE (podium edition)
It's a 4 dr. with a trunk. it's also got 6.5" speakers in the rear deck. I am not sure whether I can replace them by taking out the plastic speaker cover or if I need to remove the whole deck/panel. if I do have to remove the panel/deck, how do i do that?
  • 356 Answers
They were installed in one of two ways, they were either dropped in from the top or secured from beneath. I would first take a look in the trunk and see how they were mounted. Another possibility is to go to the dealership and ask to see the exploded diagram of the read deck of your car. They may even give you copies of the diagram if you ask.
Posted on Mar 19, 2014
KaeZoo
  • 156 Answers
SOURCE: Blew my Nakamichi Car SPeakers
I don't think the problem was the metal basket touching the vehicle sheet metal. It's very, VERY common for speakers to be mounted directly to sheet metal. I think what you needed was a spacer, not so much an insulator. Usually when speakers are bottom-mounted, there's a thick gasket on the front that prevents the speaker cone from coming into contact with the mounting surface. Its only function is to increase the distance between the speaker cone and the metal. Your first speakers probably lacked the spacer, so the cone was pushed up against the metal and couldn't move. This is what ultimately caused the damage. Keep in mind that even with your cardboard insulators, there'd still be an electrical connection between the mounting deck and the speaker basket, because of the metal mounting screws.
Posted on Jul 30, 2007
MrScary66613
  • 1990 Answers
SOURCE: "speaker location"
Yes, You can fit these in the Doors with Modification. Your best Sytem Would be 2 in Front, 2 in Rear, and Sub. If you REALLY Wanna get into it, Go to Crutchfield.com and Purchase the Pioneer 7800 Series Equalizer and 3 Amplifiers. AWESOME SOUND!!!!!!!!! Please Rate My Response! Thanks!
Posted on Feb 05, 2009
SOURCE: Speaker Removal
the plastic piece should just come right off
Posted on Apr 12, 2009
  • 16 Answers
SOURCE: how do you install front speakers on a 1999 olds.
pop off speaker cover. there are screws you have to remove so you can replace your speakers....
Posted on Sep 08, 2009
diodeic
  • 1622 Answers
SOURCE: how do i remove the
The rear speakers in 2004 Nissan Sentra are mounted on the rear deck, rear seat head restraints. These speakers are secured to the deck steel metric nuts to the topic within the trunk. Cover it with plastic speaker grille of the speakers tweeters to prevent damage to delicate speaker cones. Several options are available aftermarket replacement auto shops and car electronics.
Try this, first thing you need to do is pop off the 3rd brake light, you push it toward the window and push it upward. Disconnect the wire from the 3rd brake light. Then fold all your seats down and pop out all the pins located around the area where the head rests usually sit. They go from one side of the car to the other, just get a flat head screw driver and use it as a lever to remove them, then you just simply lift the back panel off. There are clips and things that will pop as you take it off, so use some force in pulling it upward. but it will clip back on and wont break any thing when you put the cover back on. due to the seat belts you cant fully take that piece out of the car, i found that its easy just to pull the seat belts out to there fullest and put the cover where the trunk opening is. when your dont put the cover back on over the rear deck and just hit it a few times till you feel all the pins and clips go in. Replace all the pins you took out from lower part which you took out, and then replace and reconnect the third brake light. Its very easy ive dont it more then 3 times with installing speakers and wiring my spoiler bake light.
Posted on May 01, 2011
Temperature gauge on the dashboard falls to zero while while driving my Pontiac 2010 G3 wave yesterday. Can anyone help with the sensor location in the engine and some suggestions on how to fix this ?
The sensor for coolant temp. will be located in the thermostat housing or intake manifold close to the thermostat housing. It will have 1 wire plugged into it. Apply Teflon paste to threads of new sender before installing. Do not over tighten. Make sure coolant level in radiator is correct.
May 20, 2017 | Pontiac Cars & Trucks
Can you put a sunroof wind deflector on a 200 Pontiac G3 wave with the on star device
What is a 200 Pontiac? Where did you get the idea that Pontiacs were already in production in 200 AD?
May 15, 2017 | Pontiac Cars & Trucks
2009 pontiac g3 wave window noise front driver an passenger window. Is it a bad seal or rubber gasketl? What can i do to fix?
try purchasing a used rubber or window seal from a wrecking yard and replace it as its much cheaper than buying from a dealership
Mar 08, 2015 | Pontiac Cars & Trucks
I need parts for a 2007 Nissian Frontier. What other years are compatiable with a 2007?
Depending on the sub-model, 2005 - 2012 versions *can* fit. Look for yours in the list below:
  • Fit note: Crew Cab Pickup, Extended Cab Pickup
This product fits the following Nissan Frontier submodels
  • 2013-2013: Desert Runner; 6 Cyl 4.0L;
  • 2011-2013: S; 4 Cyl 2.5L;
  • 2011-2013: SL; 6 Cyl 4.0L;
  • 2011-2013: SV; 4 Cyl 2.5L;
  • 2011-2013: SV; 6 Cyl 4.0L;
  • 2009-2013: PRO-4X; 6 Cyl 4.0L;
  • 2011-2012: S; 6 Cyl 4.0L;
  • 2008-2010: SE; 4 Cyl 2.5L;
  • 2005-2010: LE; 6 Cyl 4.0L;
  • 2005-2010: SE; 6 Cyl 4.0L;
  • 2005-2010: XE; 4 Cyl 2.5L;
  • 2005-2008: Nismo Off-Road; 6 Cyl 4.0L;
When calling to inquire or order - tell them the year, make, model (S, SL, SV, LE, SE, XE, etc.) Cab type (crew, extended, etc.) before paying. Have a look at the link below.
2005 2012 Nissan Frontier Tail Light Replacement Driver Side...
May 13, 2014 | 2007 Nissan Frontier SE Crew Cab
Remove speakers
need remove rear shelf trim panel .open trunk use flash light locate rear speakers then disconnect electrical connector from rear speaker then squeeze the two mounting tabs and push them up through their mounting holes then push up on the speakers to disengage remove them.
Jun 11, 2013 | Pontiac Bonneville Cars & Trucks
My passanger side seat (manual) stuck on pontiac grand am car. I don't see anything broken underneat the seats. Do you have any ideas?
open the trunk and look up under the speaker area there r two straps located there pull on these straps one for each back seat then the seats will let down
Oct 09, 2012 | 2001 Pontiac Grand Am SE
Changing the two back speakers in the 2003 Pontiac Grand Am
Always a good idea to upgrade speakers...Your factory speakers are normally removed from the underside of the rear shelf located in your trunk...6X 9 common size some 4 X 10...4 mounting screws on each corner, and a 2 wire connector...switch out is easy...some rare models have the rear speakers installed from the inside of the rear shelf...first check in the trunk for the speakers, and screws...if not there, you will need to remove the rear seat...to get to the speakers to switch out...first the bottom cushions then the top...bottom cushions have a large bolt on each side near the floor...top seat back bolts are under the bottom cushions...Hope this helps.
Jan 27, 2011 | 2003 Pontiac Grand Am
Replace or fix burn hole in seat pontiac wave g3, where to get upholstry and fix?
HI check your local phone book there are moble repair companys that fix scartchs and burns. or call a local dealer there are companys they use to repair burn holes. Good luck
Aug 27, 2010 | 2009 Pontiac G3
I want to install a stereo in a 2001 grand am se but the wires were cut.
Here are the wires colors of the harness and what they do.
2001 Pontiac Grand Am Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Mounted behind trim in the left side of the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
May 30, 2009 | 2001 Pontiac Grand Am SE
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
