Question about Life Fitness 9500HR Treadmill
Motor controller error
When i click quick start its not start !!!
CE error displays
hello there and thank you for choosing fixya
CE Communications Error If there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
Jul 31, 2011 | Washing Machines
Washer clicks, but will not start and lid will not open.
Here is a link to the Servicemanual http://www.fixya.com/support/t4120327-op_lights_up_when_hit_start
If you need to raise the washer top rom the washes base to get your clothes out see page 33 to release the washer top. Did you have any error codes to the LED display FAV6800A machine correct?
You could have a Control Board failure or a Motor Control Board failure. If you want to dig deeper into the issue let me know. If there is no error code to the display the next step (DIY) would be to read the Control Board Diag codes stored error list and see what we have.
You would need to get into Service Mode and display the Diag code list. See page 17 of the Service Manual......Rich
Feb 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Error code CE When I turn the washer on it start then turn back off, then error code CE flashes on the display.
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 10, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
The washer hums, starts to fill with water, then
Dec 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
The washing machine displays error code CE for communication error
Hi, Well if there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
1.Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
2.Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
3.Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
4· Drive motor thermal protector has opened.
5·Motor controller is not powered or fuse has opened. Replace motor controller.
I hope it helps. Thanks! mannu_rakesh
Sep 02, 2009 | Kenmore Washing Machines
Not starting
when you start the cycle and does it beep once and then show "CE" .. There is a communication error between the machine control and motor control.
There may be some Conformal coating on serial communications pins between the machine controller and motor controller.
Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection. Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur. maybe the Drive motor thermal protector has opened.
Aug 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
CF code--It starts to spin and then stops. That's when the CF code flashes. What is the problem?
There is not a CE Error - I suspect it is CF.
Jun 12, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Starts filling than stops than start filling than stops and a code come up saying CE OR LD
Apr 12, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
CE code flashing and have hit the stop-cancel and everytime i go to start it goes right to CE flashing,,, which i hear is a communication problem do you know how to stop it or fix it
Feb 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Top Loader "CE" error code.
CE means communications error
If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
Dec 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Life Fitness 9500HR Treadmill Logo
Top Life Fitness Exercise & Fitness Experts
Howard
Howard
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
