Question about Panasonic KX-T7730 Corded Phone
How can i check the numbers called and duration
I want to be able to check all dialed numbers and duration
    Master:
  • 485 Answers
There is a software you can buy and attach it to the ports but a computer must be always connected to it.
Posted on Mar 19, 2014
I need instructions of Melnor 304F timer for watering
From the Melnor 304f actual instructions:
Use 9V alkaline batter only! Flashing lighs indicate that the battery is low and needs to be replaced.
1) To start: Turn Dial to Off position and press ENTER
2) Set Time: set the current time and press ENTER
3) Start Time: set the time to start the first irrigation cycle and press ENTER.
4) Frequency: Set the frequency of the irrigation cycle e.g. twice a day = 12h and press entere.
5) Duration: Set the duration of the first irrigation cycle and press ENTER.
-- to change the duration
Turn the dial to the new duration and press ENTER
--to turn the water on manually
Turn dial to ON position.. The water will turn off automatically after 30 minutes.
-- to turn the water OFF
Turn the dial to the OFF position
Do NOT press ENTER when dial is in OFF position, otherwise the unit will clear the program, and you have to Reprogram the unit following the steps 2 through 5.
Jun 29, 2014 | Flotec Garden
Hi,i have nokia 5800 xpress music unable to view dialed ,received & missed calls. It says no dialed numbers
  • Increase the log duration option.
  • Also check whether the theme is blocking you from viewing the call logs.
Mar 19, 2013 | Nokia XpressMusic 5800
How to increase ring duration
First of all you need to know the number you dial for voicemail. Make a note of this.
Then, go to the dialpad and dial:
*#61#
and press Call.
A box will popup telling you what the redirect to voicemail delay is. On my handset the default was 15 seconds.
Now, dial:
**61******SECS#
and press Call
where *** is your voicemail number and SECS is the number of seconds you want it to ring for before diverting. For example, on Vodafone UK the voicemail number is 121 so to set the ring for 30 seconds before diverting, dial:
**61*121**30#
Once the box has come up saying it was successful you can use *#61# again to check the setting.
Oct 27, 2011 | HTC HD7 Cell Phone
My nokia N70 does not show any calls that i have receive or missed or dialed numbers, i can't see any calls that i have made or received? which setting do i make? please help me
just go to log (call log) in that go to options select settings you'll find log duration change it for 30days
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 18, 2011 | Nokia N70 Cellular Phone
Set number of rings before voicemail iphone
This procedure allows your iPhone to ring for longer or shorter periods than the default setting of 20 seconds before voicemail answers. *** Attempt at your own risk but if you pay attention to the keys you input and follow the directions you should have no problems.
1. On your phone, dial *#61# and click Call
The screen will display:
Setting Interrogation Succeeded
Voice Call Forwarding
When Unanswered
Forwards to +1xxxYYYzzzz
Enabled
2. Write down the xxxYYYzzz number (including +1) - this is the number to your voicemail.
3. In order to make the + appear on the keypad in the next step you'll have to hold Zero down for a few seconds, then it will become a Plus (+). Dial **61*+1xxxYYYzzzz**30# and hit Call. +1xxxYYYzzzz is the number you wrote down previously, 30 is the delay in seconds. The delay can be set in 5 second increments, 30 is maximum.
4. Dial *#61# to verify that the new settings are active.
5. Verify working voice mail.
If you find you or your contacts are not being forwarded to your voice mail you have incorrectly altered your voice mail forward number.
To find out what it is and try again:
Dial ##002# and send. This will reset that forward number to factory defaults.
By then Dialing *#61# you will again display the your current (default) voice mail forwarding number.
Return to step [2] and continue.
*** Use this tutorial at your own risk ***...and if you have the time you can always give AT&T a call to have them change the number of rings on an incoming call before Visual Voicemail kicks in. I was able to quickly change the duration on my own, using these diagnostic iPhone GSM codes. The default time duration before Visual Voicemail intercepts the call is set by AT&T to 20 seconds. You will be able to add another 10 seconds yourself, but if you want your callers to wait more than 30 seconds before voicemail picks up then you'll need to contact AT&T technical support - they can change the duration to 45 seconds upon request.
Dec 19, 2010 | Apple iPhone 3G
Im using n73 mobile,ijust want know information about call summery duration during call..
Please follow below steps
To check the call duration of your incoming
and outgoing calls, press Menu , and select Applications >
Log > Call duration
To set the display of the call timers while a call is active,
select Applications > Log > Options > Settings > Show
call duration > Yes or No.
Thank You
Aug 11, 2010 | Nokia N73 Cellular Phone
Lost directions to set timer Melnor 604 F
Melnor 604F Instructions (from Label on unit)All indicator light flashing - replace 9V battery inside unit
1. To Start - turn dial to Off and press Enter.
2. Set Time - set current time and press Enter (Yellow ring).
3. Set Start Time - Set time to start first irrigation cycle (Yellow ring) and press Enter.
4. Frequency - Set frequency of irrigation cycle; e.g., twice a day set 12 h. (red sector ring) and press Enter
5. Duration - Set duration of cycle (Green band) minutes and press Enter.
To change duration - turn dial to new duration and press enter.
To turn water on manually - Turn dial to ON position, water will turn off in 30 min.
Do not press enter in the OFF position as the unit will clear program. You will have to reprogram unit
via steps 2-5 above.
Jan 31, 2010 | GARDENA Melnor/Gardena 101 Flowmeter Water...
Call from pc with use of my nokia n70
Hello there! thanks for using Fixya.com!
Unfortunately, we cannot use that feature especially as I know with Nokia N70 phone. You can only use bluetooth devices head sets or other supported devices via bluetooth. However, you may use your mobile as a modem and access thru GPRS and you may browse directly from your pc, just connect your phone with USB cable to your pc.
Here some details of the specifications, Here is the detail for this user guide manual: Nokia N70 Help Tutorial Useful shortcuts Clock Clock settings World clock Volume and loudspeaker control File manager View memory consumption Memory low—free memory Memory card tool Format a memory card Make calls Voice calls Make a conference call Speed dial a phone number Voice dialing Video calls Video sharing Video sharing requirements Settings Share live video and video clips Accept an invitation Answer or reject a call Answer or reject a video call Call waiting (network service) Options during a voice call Options during a video call Log Recent calls Call duration Packet data Monitor all communication events Personalise your device Profiles—set tones Offline profile Transfer content from another device Change the look of your device Active standby mode Contacts (Phonebook) Save names and numbers Default numbers and addresses Copy contacts SIM directory and other SIM services Add ringing tones for contacts
for more info, check this site http://www.ebookmanual.net/nokia-n70-user-guide.html
Feb 15, 2009 | Nokia N70 Cellular Phone
Wizard wont create a dialup connection using vista i have updated the modem drivers and the modem is in my device manager
Hi
Follow these instructions to create a dial-up connection on your computer. Then you can get on the Internet to receive/send email and browse the web.
From the Start menu, click on Connect To
Click on Set up a connection or network
Click Set up a dial-up connection
Click Next. Enter the required information for the connection:
Dial-up phone number: 513-520-1135
User Name: (the NCF accountID that was assigned to you)
Password: (the password chosen by you when you registered)
Remember this password(check this box)
Connection Name:NCF Internet - Libertel
Allow other people to see this connection: Check this if you want this connection for all users on your computer (recommended)
Note: if you have Call Waiting, temporarily disable it for the duration of your NCF connection byusing *70,,613-520-1135 as the phone number.
*The NCF dialup phone number is in area code 613 in Ottawa. Please note that long distance charges may apply to modems outside of your local calling area.
Click Connect to create and save this connection.
You have successfully created a Dial-up Connection in Windows Vista.
To connect to the NCF using the connection you have now created, follow these steps:
  1. Click on Start, and then Connect To.
  2. Left click on the NCF Internet - Libertel dialup-up connection and select Connect at the bottom.
  3. The Dial-up windows will come up. Simply click on Dial and your computer will connect to the NCF
Jyothish
Jul 18, 2008 | Computers & Internet
Panasonic KX-T7730 Corded Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
