Question about Cell Phones
On my Huawei MyTouch Q phone the com dot huawei dot mytouchlauncher app keeps stopping unexpectedly whenever installing new apps
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 77 Answers
Resolution Steps App previously worked
If the app that is showing errors has previously worked and not been updated, follow these steps:
  1. Think about the pattern of what you were doing when the device froze, and what programs were open in the background. Use the answers to focus on device functions or apps that are not working correctly.
    Note: If the problem is related to more than one specific app, see: Device is slow / freezes / restarts / or displays memory errors: Android
  2. Check the docs for your device to see if there are any specific instructions for it
  3. If the problem is related to contacts or an 'android.process.acore', back up your contacts:
    1. From the Home screen, press the Menu key.
    2. Touch Settings.
    3. Touch Accounts & sync.
    4. Turn off all synchronization to Google accounts and T-Mobile Contacts Backup.
    5. Return to the Home screen.
    6. Open the App menu.
    7. Touch Contacts or People.
    8. If there are any contacts listed, they are stored on your phone (because you turned off the ones synced). From the menu, export them to the SD card to save them.
  4. Clear the app cache and data:
    2. Touch Settings.
    3. Touch Applications.
    4. Touch Manage Applications.
    5. Touch All.
    6. Select the application that is having issues.
      Note: For the following errors:
      • android.process.acore: Select Contacts storage.
      • android.process.mms: Select Messages.
      • com.google.process.gapps: Select Download Manager or Downloads (At the bottom of the list). Make sure the Downloads Manager is enabled. If it isn't, enable it before proceeding.
      • TWlauncher process com.sec.android.app: Select TWLauncher.
    7. Touch Clear data and Clear cache if they are available. This resets the app as if it was new, and may delete personal data stored in the app.
  5. If you turned off sync, return to Accounts & sync and turn it back on. If necessary, import any contacts you exported to the SD card.
  6. Uninstall all third-party party task managers, battery saver, or apps that close programs. For information, see Manage Applications: Manage memory on Android.
  7. Restart the device.
  8. Open the app to test if the problem happens again.
  9. If the problem recurs, uninstall the app (if possible).
  10. Wipe the cache partition to clear system memory.
    Note: To find steps for your device, search Support Community for: wipe cache [device name]
  11. Open Play Store, and re-install or update the app.
  12. Open the app to test if the problem happens again.
  13. If the problem recurs:
App never worked OR app received update and stopped working
If the app that is showing errors never worked OR was updated and then stopped working, then follow these steps:
  • If the error is with a pre-installed app, then look for more content in your device space or user manual.
  • If the error is with third-party apps, then contact the app developer. T-Mobile does not support third-party apps.
Posted on Mar 20, 2014
  • 50 Answers
SOURCE: I have a MyTouch 3G phone and for 9 months has
I think reseting your device will help.
Posted on Oct 30, 2010
inbarrose
  • 118 Answers
SOURCE: I'm getting the error message
if you have installed a rom, or rooted your phone, it may not work, there is nothing to be done.
have you tried calling your voicemail directly and not through an app?
Posted on Mar 30, 2011
ladybugocean
SOURCE: com.android.huawei.keypadprogramming (process.android.huawei.keypadprogramming) has stopped working unexpectedly
I had to call my phone provider to get the answer.
press up volume and hold while pressing power and hold until
it comes to a screen with choices on how to fix your phone. use the volume button to go up or down the choices. that's all i remember
good luck
Posted on Oct 14, 2012
guatemalt46
  • 33 Answers
SOURCE: can i download apps to my huawei ascend M860 from google play?
yes.
Posted on Dec 13, 2012
SOURCE: the application com.android.huawei.keypad programming (process com.android.huawei) has stopped unexpectedly
Had same issue. Done reset and it stopped. Make sure u back up your info (numbers, apps, all the stuff u wanna remember).
Posted on Mar 11, 2013
How do i recieve and make phone calls using huawei mediapad 10link?
For enabling your voice call on Huawei MediaPad 10 FHD follow this instructions :
1- First you should root your device follow the bellow instructions :
Root On ROM 4.1.2
Root On ROM 4.0.3
2- Download Root Explorer android app
3- Insert an empty microSD card to your tablet (100Mb is enough!)
4- Open Root Explorer app and go to this location :
cust/hw/normal/prob and local.prop
open it in edit mode then :
Search this content:
# ro.config.hw_phone_switch=0
And then change it to this (remove # and turn 0 to 1):
ro.config.hw_phone_switch=1
And then search this content :
# ro.config.hw_phone_ui_hide = false
Change it to this (remove only #)
if you don't see them write yourself on file at the end of file named local.prop :
and then save local.prop file .
5- Connect your tablet to Pc and download this phone patch and extract it
Download Phone Patch
Open (Run as administrator) the file with the name Huawei MediaPad FHD 10 3G_4.1.2 official version of the B002 a key ROOT.bat and it shows to you two messages ,on both of them click ok and during the run, your tablet reboots on fastboot mode.
7- After your tablet goes off and on PhonePatch2 app will be add to your apps open PhonePatch2 app , First press the gray button and wait for the message to be rooted to the access request and confirm , Second press the second button to install the phone app and then restart your tablet after installation.
8- Ok you can uninstall PhonePatch2 app and enjoy from your Huawei MediaPad 10 FHD !
Attention :
If Phone app is on apps list but you can't dial a number from PhonePath2 click on second bottom again to install the phone app again .
Enabling voice call have been tested successfully on this two firmware
Mediapad 10 FHD 3G with firmware S10-101L_FIRMWARE_Android4.1_C001B002SP01_General_Vers ion_05011GJG { LTE ROM}
Mediapad 10 FHD 3G with firmware S10-101u_FIRMWARE_Android4.1_C001B011SP15_3G_General_V ersion {Latest version Until Today 1/3/2015}
Jan 20, 2017 | Huawei Cell Phones
My battery drains very quickly, huawei g8. Which apps can i close from the huawei installed apps?
Facebook drains the battery. So i suggest you close that one. But to completely save your battery, you can get an app that completely does wonders. The app is called Greenify. Its very helpful.
Nov 12, 2016 | Huawei Cell Phones
To transfer photos from huawei to pc
To transfer photos from android device to computer, you can use an android file transfer app to help, there're many this kind of apps and they support all types of android device.
How to Transfer Photos Movies between Huawei and Computer
Oct 27, 2016 | Huawei Cell Phones
How do i download a whatsup application
I assume you have an Android phone. Just goto the Google or Huawei app store and purchase the app. The app will be free, but new users have to pay one dollar a year for usage.
Jan 08, 2015 | Huawei Ascend II battery 2200 mAh, White
Huawei device Huawei Ascend Y300 Mobile Phone
Close the app by long pressing the home button and then clicking the cross next to the camera window.
Jul 31, 2014 | Huawei Ascend Y300 Mobile Phone
Huawei com support
load the huawei pc suite to your laptop. sync your phone to your laptop then by using windows office or notepad you can cut and paste the message, or depending on the make of printer you have you can look on playstore for the printer app to install on your phone
Jul 24, 2014 | Huawei Vitria for MetroPCS Cell Phone
Com.android.huawei.keypadprogramming (process.android.huawei.keypadprogramming) has stopped working unexpectedly
good luck
Oct 01, 2012 | Huawei Wholesale Lot Of 10 Ascend Ii M865...
The application com.android.huawei.keypad programming (process com.android.huawei) has stopped unexpectedly
Aug 06, 2012 | Huawei Cell Phones
Cell Phones Logo
175 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
