Question about Bose 3 2 1 GSX System
321 Bose won't change from PCM to Dolby Digital
Hi!
after moving my 321 Bose system to another part of the room, I now am unable to pick up dolby digital 5.0 on any channel that used to provide it in. I only get PCM. I am using a digital cable for sound and all the hookups seem ok. Any advice?
3 Suggested Answers
SOURCE: PCM 2.0
I have the Bose 3-2-1 GS Series II and initially could only get PCM audio. However, I now get Dolby Digital 2.0 and 5.1 audio through the following connections: 1) Connected a coaxial digital audio cable from Digital Audio Out (coaxial) on the HD cable box to CBL-SAT (D) on the Bose Media Center. 2) Connected a coaxial digital
audio cable from Digital Audio Out (coaxial) on my Toshiba DVD Recorder/Player to AUX (D) on the Bose Media Center. All video connections are from the cable box to the TV and from the Toshiba recorder/player to the TV. To receive Dolby Digital audio, I press either CBL-SAT or AUX on the Bose Remote Control. Good luck!
Posted on Jan 04, 2008
SOURCE: bose lifestyle 38 system, sound problems
Call Bose and get the latest software for your system. This will solve the problem.
Details:
I had the exact same problem with my Lifestyle 48 system connected to a Dish Networks satellite box (Vip622). The sound would continually switch between 'Dolby Digital 2.0', 'Dolby Digital' and 'Dolby Digital 5.1'.
I called Bose Tech Support and they had me reset all of the components. This helped for a short time but it was still happening. They told me that the problem was with the Satellite box, since the Bose system just output what it was receiving and didn't do anything else. We also determined that my system software was quite old. They said that the software wouldn't make any difference, but I got them to send it out anyway.
Well, when the new software update arrived, I installed it on my Bose system and have not had any audio switching problems. So the Bose system software update seemed to fix the problem.
Posted on Aug 20, 2009
Can I use a subwoofer from a lifestyle 12 Bose system with my yamaha htr 5940 receiver?
Yes, using digital coaxial cable.
Bose system supports only PCM DOLBY DIGITAL, no DTS.
Apr 18, 2014 | Audio Players & Recorders
Change from 2.0 to 5.0
Sounds like your Cable box audio settings are outputting two channels (stereo) instead of five channels (surround). It could be on an automatic setting, meaning whatever the digital audio stream coming from the TV channel is, your Bose system will play audio in that config. Hence why it changed from 5.0 to 2.0.
Go into your Cable box audio settings and change the output to Dolby Digital (or similar). You will also need to be connected via a digital optical cable from your cable box to your Bose 321 to output true digital audio.
If you post the make and model of your cable box I might be able to give you more direct instructions on how to do this if your still having trouble.
Oct 29, 2012 | Bose (321GS) System
I have a Sharp Aquos with a optical output, i conected it to the tv optical input of the panasonic sc ptx7 but it doesnt have audio via optical,on the contrary via rca works perfectly.
hi,
check the following on ur tv
1. Press MENU to display the MENU screen,
and then press c/d to select "Digital
Setup".
2. Press a/b to select "Audio Setup", and then
press ENTER.
3. Press a/b to select "PCM" or "Dolby
Digital", and then press ENTER.
4. Press MENU to exit.
PCM The optical output terminal output studio signal in PCM form. If your digital audio system does not support Dolby Digital, select "PCM".
Dolby Digital
The optical output terminal outputs audio signal in Dolby Digital form. it reproduces sound from surround program of digital.
also check the input assignment of ur dvd palyer's tv input. if it is selected as analog then change it to digital.
ok
Dec 20, 2010 | Panasonic SC-PTX7 Home Theater System With...
I have a Bose v20 when i use my Panasonic DVD hd recorder it doesn't sort through if it Dolby or 5.1 it stay on 2.0 i have connected it with hdmi & optical cable
Hi Peter,You will need to check the input menus of both the Panasonic and Bose System and tell each of the units that they can output and accept 5.1 channel Look for wording such as PCM(2 Channel),DTS (5.1), and Dolby digital (5.1) AC3 (5.1). Sometimes inputs can be set up as auto, or analogue. I reckon that one of the two is setup to be fixed on PCM
Good Luck
Hope this helps
Jan 17, 2010 | Bose Lifestyle V20 System - black Theater...
Bose PS 3-2-1 II speaker exspansion
Unfortunately this is impossible on the 321 series II systems. There also is no audio output on the media center to send to another amp either. As you may know, the 2 speakers are actually 4 speakers. Each small speaker array has 2 drivers. The 2 on the outside will project rear-channel audio to the sides, so placement of these speakers is important. Honestly, adding speakers would not make this sound very good. If the sound isn't too great as is, make sure you're using digital audio cables (optical or coax) from any external sources like a cable box or Blu-ray player. (if you don't see a Dolby Digital 5.1, DTS 5.1 or PCM 2.0 read-out on front of the media center, you'll know it's not digital. DVDs the exception)
Jun 18, 2009 | Bose 3·2·1 II System
Bose 321 is unable to read 6Channel AC3 Audio. Any way it can read the same?
This is true. The 321GSX will decode Dolby Digital 5.1, DTS 5.1 or PCM 2.0 digital signals from external sources (like most receivers) but will not decode any 6.1 content. AC3, mp3, mp4, wav, aiff all should work from a properly formated CD or DVD (must be -R or -RW format, or commercial), but not multi-channel AC3 content.
Jun 10, 2009 | Bose 3 2 1 GSX System
Dolby output is Pro Logic II, even though source is Dolby Digital
I know nothing about tivo but dvd player might need to be on bitstream to pick it up.I have to change mine when listening to music. hope this might help.
Mar 26, 2009 | Onkyo TX-SR304 Receiver
HK AVR35 Receiver - Dolby Digital not displaying or working
If the display is showing as optical/PCM, then the input signal is in 2 Ch Stereo.
Try to change the signal from the source i.e. the DVD player, On the remote, go to audio and press repatedly , the audio would change from audio1, audio 2 .... and so on, depending upon how may have been recorded on the DVD. If the DVD is recorded in Dolby Digital, it may show the audio as Dolby Digital 5.1 on you monitor. Once this setting has been done, your Receiver should automatically detect it and show as Optical/Dolby digital.
Please let me know if you you solve your problem.
Mar 12, 2009 | Harman Kardon AVR 35 Receiver
Bose lifestyle 38 system, sound problems
Details:
Mar 01, 2008 | Bose Lifestyle 38 System
PCM 2.0
I had the same problem with my 321 system. The fix is in the cable box settings. You want to change the Digital Out on the cable box..my choices were HDMI....Dolby Digital..and None. Choose Dolby Digital and it will show up on your Bose 321 display. I also have my cable box connected to my bose system via optical digital cable...and a digital coaxel cable from my dvr to my bose. Change that output setting on my cable box took care of the PCM 2.0 problem for me.
Dec 19, 2007 | Audio Players & Recorders
Bose 3 2 1 GSX System Logo
290 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
