Question about Ricoh Office Equipment & Supplies
Paper printing with creases
We have a Ricoh MP 3353 printer which is a bit more than a month old. the first issue we had was faded prints on one side of the pages but that was resolved. During this issue an engineer was being quite heavy handed with the unit. ever since this we've had 6 engineers come and look at a new issue which is that once in a while we get two creases along the left side of the print outs. Engineers have exhausted all possible solutions: "fixing springs in the fusing unit", testing the trays, changing the tray and driver settings to middle thick, taking everything apart and looking for faults, changing the pressure of the rollers, decreasing pressure on the side door which holds on to pages, we have even put in new paper because an engineer has said that the paper may already have had the creases. please can someone suggest any solutions or causes.
    Top Expert:
  • Ricoh Master
  • 22,085 Answers
Simple, get it replaced as it is obviously faulty and the "engineers" can't fix it. Go back to your supplier and if you paid by card, claim your money back, if they won't help, as it is faulty.
Posted on Mar 19, 2014
Testimonial: "this is a company printer and the engineer has advised that it wont be swapped out for "minor" faults"
FrankR1974
  • 8 Answers
SOURCE: Faded print on left hand side of paper
This type of printing defect is normally caused by 1 of a few problems - the easier one first:
1. Toner cartridges sometimes do not have the toner evenly distributed - close the toner cartridge and inspect the hopper right below it for even distribution of toner.
The harder ones:
2. This type of defect can also be caused by dirty charging section - for the drum to pick up the toner it must be charged electrically prior to exposure - if the charge grid is not clean then it will not give the drum an even charge - not sure were this is in this printer yet - looks like it comes as part of the drum kit so this should not be causing this issue.
3. The last and most difficult to check is paper alignment with the drum - is the paper contacting the drum evenly - look for possible problems in the paper path with the drum unit removed - look for something uneven around the area were the paper contacts the drum
Posted on Apr 12, 2008
SOURCE: Lexmark T644 MP Feeder STOP ASKING FOR MP FEEDER???!!!
Thanks mate, it worked for me too and my works printers (work in IT and this 'error' was driving us crazy)
Posted on Sep 18, 2008
SOURCE: hp laserjet 8100 8150 13.1.42
hp printers typically do not have an error message to cover every known condition, thus if the printer needs maintenance in an undefined area, it will invariably indicate a paper jam. The printer usually responds to the installation of a maintenance kit which will include transfer roller, pickup rollers, and fuser.
Posted on Oct 03, 2008
SOURCE: HP 6180 Printing Problems
Are you getting the paper mismatch error message?
If yes, see below...
I will ignore the normal solutions to a "paper mismatch" error such as your settings not matching your printing media. Obviously, check these first:
http://h10025.www1.hp.com
If your problem is not solved with the above steps, you have an issue with your "spot sensor" and it needs to be calibrated. Instructions:
1. Press * and # at the same time, and then release both keys.
The display reads "Enter Special Key Combo".
2. Press 3, 2, and then 9, releasing each key before pressing the next.
The display window should read "Service: R0622M" with a revision number.
3. Press the right arrow button once.
The display should read "System Configuration".
4. Press Enter or OK.
5. You will be prompted to enter serial number. Do not enter any information
on the unit.
Press the right arrow button until "media sense calibration" appears in the
display.
6. Load Paper into the unit and then press Enter or OK.
7. Media Sense Calibration process will take place.
Posted on May 04, 2009
  • 393 Answers
SOURCE: printer picking wrong tray for print
From the start menue to printers and faxes go to your printer right click and select properties label the 4 drawers as to paper type and select continue, or auto continue to off.
-Carl, please let me know if this helps.
Posted on Jun 26, 2009
How do I prevent envelopes from getting creased on a Ricoh MP c3500?
Hopefully you are using the bypass when printing them. Creasing is only caused by two things. Moisture in the paper and uneven fusing. Make sure when you are printing them you select thick 2 in the printer properties pull down menu. If the problem continues switch the feed direction and possibly the brand of envelopes. The same thing applies to printing labels (the thick 2 setting will provide the necessary heat to properly fuse the toner). But when copying, push the # key and select thick paper from the menu there.
Nov 21, 2014 | Ricoh Aficio MP C3501 Multifunction Color...
What could the Grinding noise be that is coming from Ricoh Aficio MP C2550 for each page copied/printed?
Check for:
-broken plastic gear on right side of copier
-paper or foreign object in paper path
-paper or foreign object near fuser
Oct 15, 2014 | Ricoh Aficio Mp C2550 Copier With Feed,...
Ricoh ap610n prints crooked. It's about 4 years old. Has been a great work horse but now prints come out crooked.
99% of the time its paper loaded with the side guides of th paper drawer open too wide. -Carl
May 13, 2010 | Ricoh Aficio AP610N Laser Printer
Black prints 1" either side of page. middle fades to nothing.
clean the paper path rollers. usually if toner cartridges are refilled type they are overfull and spill toner on paper path.
Please rate my help++++Thanks for using FIXYA
May 13, 2010 | Ricoh Aficio CL3500N Laser Printer
How to print envelopes aficio ricio mp c4500
On an MP-C4500, envelopes must be printed using the bypass tray (the fold-out tray on the right hand side). Put the envelope in face-down and tighten the two fences so the envelope is snug.
When printing the envelope, make sure the print driver is set for the correct envelope size. If envelopes tend to jam in the printer, try setting the bypass paper type for thick paper.
Nov 19, 2008 | Ricoh Aficio GX5050 GelSprinter InkJet
Printing faint lines with fine corresponding creases on drum
You probably can not repair it. I will say this though, be careful to get the right labels for it.
Mar 02, 2008 | Ricoh Aficio CL1000N Printer
Printer only prints on the left side and wrinkles up the paper on the left side
Hi there it could be that the fuser or the drum unit has some sticky labels attached to it check these units also check the paper feed path as there may also be some obstruction causing the paper to crease and crinkle.
Hope I could help
Thanks J
Jan 17, 2008 | Ricoh Aficio SP-C210SF Printer
Ricoh 1013f Paper creasing
1- you need to determine at what point it's creasing
a) when leaving the tray
b) when getting to drum
c) when exiting copier
2- after that you need to see what the problem is,
a) small paper that was torn off causing problem,
b) is the part worn
c) something out of place
3- remove paper or replace part
Nov 12, 2007 | Office Equipment & Supplies
77 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
