Toshiba MK5065GSXN - Hard Drive 500GB 2.5" SATA 5.4K Logo
Melissa Scott Posted on Mar 19, 2014
Toshiba satellite pxe-m0f
"For Atheros PCIE Ethernet Controller v2.0.1.9(12/15/09) Check Cable Connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key" will not reboot after reinstall with toshiba discs from factory. i tried re-sitting the drive and resetting the bios. nothing worked. what now?
  • Melissa Scott
    Melissa Scott Mar 19, 2014
    Files are not important. They are backed up on an external hd. I can try the freezer trick but if that doesn't work then what? Bios is set to default settings and LAN is enabled. I tried disabling it and it says "No boot device found". I re-enable the LAN and it says the previous error message. I've reset my bios to reboot from hdd/sdd, cd/dvd rom drive, and so on. nothing has worked even after choosing from the f12 menu.
4 Related Answers
Donald B Stoll
  • 597 Answers
  • Posted on Jun 02, 2009
SOURCE: Toshiba hard drive wont boot.
This could be the hard drive failure everyone doesn't want to see. If there are files on this drive that you have to have, I would quit trying to do anything with it till you can attempt to recover them. When a drive starts to fail there are some things you can do to get the files off before it melts down but the more you mess with it the less the chance that you can do that. You need someone with a 2.5 to 3.5 hard drive adapter that can boot up with this drive as a slave and get your files off of it that you need to save. Then you can put it back in the system and see if you can get it to work again. If the computer has trouble reading from the 2.5 in drive, shut it down and put it in the freezer for an hour and freeze the drive. this makes all the parts contract and become tighter and possibly help you read the drive again. If it reads then quits again then re-freeze it. Mean time you can go buy a new hard drive or get RMA numbers to send that one back on warranty. Hope this helps.
Ed Mac
  • 731 Answers
  • Posted on Jun 01, 2011
SOURCE: When I turn on my
Sounds like your hard drive has gone bad or your OS have gotten corrupted as it's trying to boot from a network connection.
If you have a bootable CD or floppy you can try at the command prompt
chkdsk c: /f if that doesn't work try
fixmbr
If neither of these help try reloading your OS but honestly it sounds like a defunct hard drive
Tony
  • 451 Answers
  • Posted on Mar 03, 2012
SOURCE: ETHERNET CONNECTION FAILURE TOSHIBA SATELLITE MK5076GSX HELPP HELP HELP!!!!!!!!
you need to go into the bios settings. When you first turn on your computer it will either say press f2 or del or some other key to enter bios or system setup.
from there you want to look for boot settings and change the boot order from either cd rom first or hd drive first instead of network boot.
Imanpal Singh
  • 44 Answers
  • Posted on Jun 07, 2013
SOURCE: no bootable device
when ur computer starts,start press the f8 key again again after that there will come so many option chose repair or restore option.
NOTE: it may delete your newly installet software. choice is urs then don't blame me
No bootable device
This is what mine says when I turn on Intel UNDI, PXE-2 . 1 (BUILD 082) Copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v1.0.0.5(01/22/09) Check cable connection..
You hard drive is missing from the system. Just does not recognize it.
Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Acer aspire one check cable connection pxe-m0f: Exiting intel PXE Rom. no bootable device
How old is this machine? Have you ever opened the chassis and blown out the dust with compressed air?
Built-up dust can cause electronic components to fail due to the loss of ability to dissipate heat properly.
1helpful
PCIE Ethernet Controller v2.0.0.9(05/08/09) Check cable connection! PXE-M0F: Exiting Intel PXE ROM. No
there is a pcie ethernet controller was cable connection problem means how we can solve problem
3helpful
Hi, I am using a toshiba satellite L645 which i got last December. I am now receiving the following error on boot... "Intel UNDI, PXE - 2.0 (build 083) Copyright (C) 1997-2000 Intel...
it seems that your harddisk is not dettect or may be your os has failed to boot.
turn on your laptop and press f2 to enter system setting
check on main field your hdd (ide configuration) is there any hdd installed? if there is no hdd instaled, it means that you need to replace your harddisk with a new one.
if there is any hdd now check your boot setting (boot priority), set your first boot in cd room and the second in hdd (in order to make easier instalation if the windows has broken) then save and exit.
When I turn on my laptop it goes to a black screen that tells me... Intel UNDI, PXE-2.0 (build 083) Copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller...
based the message that you encounter, it may pertain to boot priority or to BIOS configuration.
My recommendation is for you to access and reset the BIOS settings on your computer.
2answers
Pxe e61 check cable message
"Intel UNDI, PXE-2.1 (build 082)
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM
sounds like a driver issue try to go to toshiba's website and download the latest drivers for the NIC card.
1helpful
When booting up gives a message states "For Atheros AR8121/AR8113 PCIE Ethernet Controller v1.0.0.4, Client MAC Addr: 00 A0 D1 A6 50 99, Check cable connection!, PXE-M0F: Exiting INtel PXE ROM. Operating...
The message you are seeing is your system trying to boot off of a network source. The boot device order has either been changed in your BIOS or the system is not seeing the hard drive with your operating system on it and is not able to boot from it.
Robert from Blitware
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
