Question about Pioneer VSX-2016 7.1 Channels Receiver
No surround sound
In spite of the fact that the MCACC test recognises my 4 speakers, I'm not getting any sound from the surround speakers when playing a disc. Even the front speakers only work if I switch off multi-channel and play in stereo. I guess I'm overlooking a certain setting somewhere...
    Top Expert:
  • Pioneer Master
  • 41,738 Answers
Review the speaker set up instructions to determine whether the correct sizes have been selected. In some speaker configurations, signals are mixed or redirected to compensate for size limitations and other factors.
Posted on Mar 19, 2014
Testimonial: "Found out surround volume was *extremely* low, but apparently still working."
5 Suggested Answers
  • 14 Answers
SOURCE: Overload
try turning the unit off in standby mode then hold down the enter button and then the power button for about 10m seconds that should reset the unit depending on how new the unit is it sometimes has a digital saftey setting but i doubt that would cause it to do what you are saying
Posted on Apr 02, 2008
  • 39 Answers
SOURCE: pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
Posted on Sep 13, 2009
smarthome2
  • 1114 Answers
SOURCE: Pioneer VSX 818V No Sound
First thing to check is the Speaker Select Switch. It will say, "A" "AB" or "Both" it will be displayed on the LCD screen as well. Second if that's ok, Check the "Direct" switch. If it's on, turn it off. Generally if it's on, you will see a blue light if it's on (most receiver's)
If you still have No audio, hook up your DVD to the "Direct" input and turn "Direct" on. If you have audio then. The DSP chip is probably bad and you should take it to a shop and have them bench it first to confirm. Hope this helps
Posted on Dec 05, 2009
Testimonial: "Got me on right path, but I'm still stuck."
  • 15 Answers
SOURCE: Pioneer vsx-819H: MCACC setup won't display on tv
Its because the pioneer does not display menu options through hdmi. You have to hook up basic yellow composite to monitor out.
Posted on May 03, 2010
Center speaker problem on pioneer vsx 40 .I hooked up the center speaker and I can’t get sound from it
Most problems are menu settings, because surround modes can be complex and confusing. Verify what surround input type you are using. FM tuner will not play center spkr unless put into a simulate or expand stereo mode. Do other surround speakers work other than normal L/R stereo mode? You can try redoing your auto surround setup (MCACC) or going to the manual speaker setup and verifying speaker is turned on in menu system. Rechech you listening mode setups at Pages 33,38,39 in your manual. Try another speaker and wiring on center output. Try Different surround inputs, some manufactuers have had problems with their DTS and HDMI boards. Otherwise take to repair.
Nov 22, 2017 | Pioneer Audio Players & Recorders
Pioneer troubleshooting
Have the pioneer vsx-1016txv-k - During MCACC setup It indicates an error with the rear right surround speaker. Yet during play in db mode - Neo & etc the RRS speaker works! RRS does not work during the MCACC set up. Can you help resolve. Thank You Joe
Jan 05, 2014 | Audio Players & Recorders
Panasonic TV does not play through surround speakers
so it is a connections problem I think. Check if video and audio cables are properly connected. Use color codes as your guide. Also from menu check if all settings are ok. Good luck
Dec 01, 2013 | Panasonic DMP-BDT220 DMP-BDT220
Vsx-815 sb. system
Check in your speaker setup menu. Sometimes you can select between using the surround back speaker jacks as "B" front speakers as well. You would have to tell the unit which one you want to use it as.
Feb 08, 2013 | Audio Players & Recorders
Only two of my speaker channel's work when I hook my speakers into it, and one of those two only powers some of the speakers in my Infinity Beta 50. The surround sound channels do not work either. only the...
You have to configure it first. Make sure you follow the instructions on page 5 of your manual to run Auto MCACC Setup which tests the acoustics of your room, speaker size, power level, etc. This is necessary before it will enable you to use surround sound.
Apr 13, 2011 | Pioneer VSX-72TXV Receiver
Auto MCACC Screen Appearing
It would appear the unit thinks your McAAC microphone is inserted. Is it?
Automatically setting up for surround
sound (Auto MCACC)
The Auto MCACC Setup measures the acoustic characteristics of your listening area, taking into account
ambient noise, speaker size and distance, and tests for both channel delay and channel level. After you have set
up the microphone provided with your system, the receiver uses the information from a series of test tones
to optimize the speaker settings and equalization for your particular room.
Make sure you do this before moving on to Playing a source on page 11.
Important
• Make sure the microphone and speakers are not moved during the Auto MCACC Setup.
• Using the Auto MCACC Setup will overwrite any existing settings for the MCACC preset you select.
• Before using the Auto MCACC Setup, the headphones should be disconnected and the iPod
USB, XM or SIRIUS Radio function should not be selected as an input source.
1 Switch on the receiver and your TV.
2 Connect the microphone to the MCACC SETUP MIC
jack on the front panel.
Place the microphone so that it's about ear level at your normal listening position (use a tripod if possible). Make
sure there are no obstacles between the speakers and the microphone.
The Auto MCACC display appears once the microphone is connected.1
Note
1 • You can't use the System Setup menu in either the main or sub zone when the iPod USB, XM or SIRIUS Radio input source is selected. When you set ZONE 2 to ON (page 61), you can't use the System Setup menu.
• If you cancel the Auto MCACC Setup, or leave an error message
etc.
It's all in the manual.
Some background on the process...
http://www.pioneer.eu/eur/products/42/98/tech/AVAmplifierReceiver/AF_MCACC.html
Jan 30, 2011 | Pioneer VSX-1019AHK A/V receiver
Reciever only allows 2 channels(speakers) at a time.
I had this problem too. Finally, after using the MCACC setup and making sure all the speakers worked, I found I had to set the source to FM, TV or whatever from the remote control and set the mode to advanced surround sound using the front panal button on the upper right. Had to fool with them a lot. Good luck.
Jan 03, 2009 | Pioneer VSX-818V-K Receiver
No Subwoofer playback
Sell this back to the cool guy who sold it to you for 250.00 and take the money and buy some new Vann's.
Dec 27, 2008 | Pioneer VSX-9110TXV-K
SB speakers error
I had the same problem but fixed it (no thanks to what I believe is an oversight by Pioneer!). The amp is a 7.1 system. What we are assuming is the rear surround (SB) is the default using a 5.1 setup. The amp uses the SR & SL as the default. So the solution is plug your rear speakers into the SR & SL & you should have your surround! (only took me 6 hours to figure this out, hope it saves you time!)
May 01, 2008 | Audio Players & Recorders
Pioneer VSX-2016 7.1 Channels Receiver Logo
53 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
