Question about Toro Lawn Mower With Toro Power Tools
Mower starts fine, however have to keep priming every minute to keep running, we had this same problem last year, and sent out for repair at retailer we purchased from, new gas, filter, gas and oil. please help
  • 1,041 Answers
You will need to check the fuel lines for cracks/breaks.
You will need to disassemble the carburetor and spraywith carb.cleaner. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals and/or jet in carb. These portals can become blocked. you may need to replace the diaphragm. Reassemble and start.
(NOTE:If the carburetor parts are more than four years old, and depending onthe use, you will need a new carb. kit if the cleaning doesn't work.)
If you need further assistance, just let me know.
Jim
Posted on Jun 19, 2009
  • Jim Parker
    Jim Parker Jun 22, 2009
    Did this solution solve the problem?
    Jim
Briggs and Stratton needs primed to start when hot
sounds like the carby needs another clean out and did you blowout fuel tank and make sure you put fresh fuel in it not stuff that has been in your tin for more than a month
Feb 14, 2013 | Garden
I can't start my mower I pull and pull and pull and nothing
if the gas is left from last year drain it and try fresh fuel gas is only good for 30 days in small engines
Mar 26, 2012 | Garden
May 4, 2011 I purchased a Yard Machine Mower Model 12A-A140029 with a Briggs & Stratton 158cc/5.50 engine from Home Depot. From day one it was very difficult to start. (I have used it about five...
I have the same model purchased last spring from Home Depot. I finally learned to prime it 6 times instead of 3 like it says on the mower. After pushing the primer 6 times mine starts fine. It usually requires priming even when the engine is warm to get it to re-start unlike any mower I have had in the past.
Aug 12, 2011 | Garden
What would cause mower to die after starting?
your carb. is gunked up. get a can of starter fluid and a helper. have the helper spray some starter fluid into the air intake to keep it running after it starts. Once it runs for a couple of minutes it will be ok. J.
Jun 27, 2010 | Craftsman 675 Torque 190cc 21" Briggs ...
MTD mower runs for 10 minutes then quits.
I have the same problem with mine. I have narrowed it down to a fuel problem through deductive reasoning. Try this test. Start the engine clamp the bar (keep away from the spinning blade) when the engine tries to die push the prime bulb to keep it running. This simulates a fuel pump by putting a pressure higher than atmosphere into the float bowl spraying fuel into the intake. If this is the case the line (on mine it is a black tube) connected to the engine is clogged or what it connects to in the engine is not working properly. I am looking for a diagram of the carb and the engine that is detailed but I have not found one yet.
Please get back to me with your results. Thanks
Jun 20, 2010 | Mtd 22" Yard Machine Push Mower
Wont continue to run after prime and start
often the last ounce of gas in the tank has some crud in it. Get a can of carbeurator cleaner spray. Remove the air filter and squirt three short bursts of the cleaner spray into the air port and then start it. Keep giving it short bursts of carb. cleaner until it runs smoothly again.
Aug 12, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Craftsman 7.0 HP Briggs & Stratton mower stalling
Check the muffler, if the muffler is clogged it could cause overheating of the engine, and could keep the engine from getting the necessary fuel-gas mixture.
Aug 09, 2009 | Garden
6 yr old mower starts, won't run
sounds like a plugged high speed jet in carb - you can attempt to prime again , push at least 7-8 times - once it fires continue to push primer to keep running - it may clear out the carb if this doesnt work the carb will need to be removed and cleaned
Sep 27, 2008 | Garden
Toro Lawn Mower With Toro Power Tools Logo
281 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
