Question about Kitchen Ranges
Indesit Oven & Gas Cookware model KP59MS CG
How do I open the front panel? The LCD display fell over inside the opening behind the front panel.
  • 1314 Answers
SOURCE: Front panel off
a lot of theese ranges have whats called a thermal fuse or tco that will open when the oven goes into an over heat condition i don't have access to sharps data but if you call you local appliance parts store they can look it up for you and tell you where it is youll have to buy a new one any way
Posted on Jan 26, 2008
  • 2315 Answers
SOURCE: Kitchen Aid KGRA806PSS
Check HERE for more info.
Posted on Mar 03, 2008
SOURCE: Cannon Camberley 10305G (Double Oven)
trust you have set the clock as this turns the gas supply on to the ovens
Posted on Mar 18, 2008
  • 8 Answers
SOURCE: Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
Posted on Jul 30, 2009
TheMobilian
  • 8220 Answers
SOURCE: I used my oven a couple of days ago, and ever
Your pilot light must have blown out. Get a match and light it.I looked up your model number and your oven uses a standng pilot. It is attached near the rear of the burner. Check out these photos HERE
Posted on Feb 05, 2010
My microwave/convection oven (a GE unit model JES1290SK) started beeping every few seconds and displaying F6 on the control panel. I unplugged it and waited several minutes and when plugged in it displays...
The technical sheets in my files do not list F6 on the error code chart for GE microwaves.
Generally, these are the error codes possible on GE microwaves:
F1 open thermal sensor (convection models)
F2 shorted thermal sensor (convection models)
F3 key panel shorted for more than 60 seconds
F4 open humidity sensor
F5 shorted humidity sensor
There should be a "mini-manual" (technical sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Jan 15, 2011 | GE JES1290 Convection/Microwave Oven
I have an ES340 gas self cleaning oven. I smell gas when I open the oven door. I checked all the connections in the back and the ones behind the back panel, and none are leaking. Are there connections...
Hello tds. It is not uncommon to smell gas when you open an oven door. That said, if the amount of gas you smell is stronger than it used to be call your gas company. They will send out a technician, free of charge, to check your stove. Joe
Thanks for choosing Fixya!
Jan 13, 2011 | Frigidaire Ovens
Installation instructions for Indesit 90cm upright cooker dual fuel model number KP59MS
You can get the manual on the link below.
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Cooking/KP9508E(X)G_195046972-03.pdf
Good Luck please rate 4 thumbs up for the free answer and please leave a testimonial
Oct 06, 2010 | Ovens
My micro oven NN-C2000P No lcd light display even the 240 v suppy is going in the Power supply panel. the door is totally close.
IS GREEN LIGHT IS ON BEHIND LCD ? ANY LCD NEEDS BACKLIGHT TO DISPLAY. JUST LOOK OUT FOR FUSED BACKLIGHT. LET THE DOOR OPEN OR CLOSE THE DISPLAY SHOULD BE ON.
Apr 01, 2010 | Panasonic NN-T551 Microwave Oven
Replacing PB010036 Bake / Broil Thermostat Viking
you do not need to take apart any switches, all you need - unplug it from power, open front panel (2 screw on each side) remove all knobs, there is 3 more screws behind them). unscrew thermostat 2 screws behind knob. open top part of stove, remove grates and cover. you will see wires to thermostat unplug them and plug one by one to new thermostat. remove old thermostat from inside the oven (it has bracket inside). put the new one. close everything back.
appliancesrepairla.com - viking repair LA
Dec 12, 2009 | Viking VGIC485-6G Gas Kitchen Range
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
The display panel on my indesit wie147 is saying door??? I can't open the door and the display is frozen???
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 13, 2009 | Washing Machines
Display problem on Microwave/Convection Oven
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Aug 07, 2009 | Sharp R-1502 Microwave Oven
No display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
Apr 15, 2009 | Microwave Ovens
Thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Kitchen Ranges Logo
27 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
