I have a gateway notebook model #mt6451 i turned it off last night and i turned it back on this morning and the screen wasnt coming on the power button lite up cd made noise fan working and hard drive running please help
    Master:
  • 397 Answers
First thing to try:
Remove your battery and charger, hold the power button for 10-15 seconds. Plug the laptop into mains ONLY leaving the battery out. Try powering it up.
If the laptop powers up ok, simply shut-down and re-insert your battery. You should find your laptop will continue to work fine for the foreseeable future, this kind of issue is a common occurrence on laptops.
If not I would then try re-seating your RAM/Memory, if that doesn't work and you have more than one stick remove one at a time to see if either one is causing the problem. If you have only one stick find a replacement to test your laptop with.
If you are still finding the same issues with the laptop I would then proceed to reseat all components of laptop, including the CPU.
If the issues continue I would then remove all non-essential components one by one, each time attempting to power the laptop. At worst you will eventually end up with just the mainboard, CPU, RAM and an external monitor plugged into the mainboard, that still doesn't function correctly. I would then conclude your mainboard needs replacing.
Posted on Mar 19, 2014
4 Suggested Answers
benwabnick
  • 2404 Answers
SOURCE: Toshiba Satellite L30-101, Black Screen??
Take out the memory and reseat each memory stick one stick at a time in each slot one at a time. Be sure to turn on the laptop after each stick reinsertion. If you don't get any video then go ahead and take out the battery completely and only have the AC Adapter hooked up and turn on the laptop, this will make sure that its not an overdrained battery causing the laptop to show no video.
If this doesn't work then go ahead and take out the hard drive and dvd drive, then try turning on the laptop. If you still don't get any video then the last thing to try is to change the output from monitor to LCD, you would do this by pressing the FN key + the function key that has a pic of a monitor or it will say crt/lcd.
If after this last step you can't get video then the motherboard is bad and would have to be replaced.
Posted on Aug 21, 2009
  • 60 Answers
SOURCE: Gateway MT6451 When I press
Does the light associated with the hard drive flicker, stay on and then fade sometimes? If so - then the hard drive is working and the likely problem is a faulty screen. You can also try the function key plus whatever F key would increase screen brightness. (i.e. Fn + F7 on my machine.)
Posted on Jan 11, 2011
SOURCE: Gateway MT6451 Does not turn on
Remove one stick of ram
Turn on if not working
Put ram back in remove other one
Turn on
Worked for me
Posted on Feb 22, 2013
The power button in my Gateway laptop MT6451 got pushed it can't be accessed from the top. How can it be accessed from the button?
Quite easily Sergio
The plastic Power On button you see, presses against a carbon button Power On switch, below it.
I suggest removing the Switch Cover, and then you can access the Power On switch's carbon button, and press it down to turn the laptop on.
You can also, then see about repairing the Power On button assembly, or replace the Switch Cover.
1) Remove ALL power. Remove the AC adapter {Charger}, and Battery.
2) Laptop closed, laid on it's top; Bottom side up.
Turn it so you are looking down in the Battery Compartment, where the Battery was......
Down in the Battery Compartment are 4 Philips head screws to remove. You need the smaller No.1 Philips screwdriver, or the equivalent Jewelers screwdriver.
Here is the Base Enclosure, (Bottom Cover), not installed on the laptop,
http://www.ebay.com/itm/39MA7BATA10-Gateway-MA3-MT6451-Bottom-Case-Cover-39MA7BATA10-Genuine-/321101430142?pt=LH_DefaultDomain_0&hash=item4ac322fd7e
There are 4 views. The page automatically opens, with a Bottom view, and the Battery Compartment at the top.
SET, your mouse cursor in the middle of the photo. This allows the Zoom In feature.
Go to the top where the Battery Compartment is, and view the 4 holes going along the Top.
This shows you where the 4 screws to be removed are.
Same design, different Gateway notebook,
http://www.insidemylaptop.com/remove-keyboard-from-gateway-mt6704-model-ma7/
Go to the third photo down. Has two screws circled in Red.
I just want you to look at the Battery Compartment. (Not the red circled screws)
Look under the whitish - www.InsideMyLaptop.com -
You can see the first two screws pretty visibly. Almost make out the 3rd one, no to the 4th screw.
Once these 4 screws are removed, turn the laptop over.
Open the laptop.
Now you are going to remove the Switch Cover.
In the above link scroll down to the 5th photo, and 6th photo.
This video also shows you,
http://www.youtube.com/watch?v=KjOVOLOW1Hc
From 0:45 to 0:47
Please use care when removing, it is plastic.
The video has been sped up.
This is a look at the Switch Cover removed,
http://www.ebay.com/itm/8015907R-Gateway-CENTER-COVER-MT6700-MT6451-MT6821-MT6828-MT6452-MT6705-GRADE-A-/321068043361?pt=US_Laptop_Housings_Touchpads&hash=item4ac1258c61
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 04, 2013 | Gateway MT6451 Notebook
My gateway laptop does not recognise its internal dvd player or any ofthe external usb connections.The dvd player does not appear when i click my computer
upon turning the computer on the GATEWAY logo will appear. Wheb that comes on be very quik and keep pressing the F8 key. The screen will show a job to repair your computer. Use any one except for to run windows normally. This should help for it helped mine whn my CD was not regonized by my computers program
Jul 04, 2010 | Gateway MT6451 Notebook
Problem loading OS on Gateway MT6451, Main File Error
This looks like a corrupted file in the boot section or a virus attack. the only solution is to reinstall the OS. there is no hardware error, if you had any hardware error the display will not be working fine. reinstall the Windows OS.
Please encourage us if this tip was helpful to you.
Apr 02, 2010 | Gateway MT6451 Notebook
I'M GETTING A RED LIGHT FLASHING WHEN I PRESS THE POWER BUTTON ON MY MT6451 GATEWAY LAPTOP. CAN ANYONE HELP ME? THANKS MATTHEW
red mean that there is some thing wrong with your hard drive try typing f8 f8 this should help you fine out what is wrong
Jan 13, 2010 | Gateway MT6451 Notebook
Hdd pasword for gateway mt6451
There is no way to get around a hard drive password as the password is not in the BIOS it is stored on the control board for the hard drive itself.
The only option is to send it off the a Data Recovery company.
Sep 16, 2009 | Gateway MT6451 Notebook
Gateway MT6451 Notebook won't boot.
try adjusting the screen lighting....
Sep 14, 2009 | Gateway MT6451 Notebook
New laptop lcd display not working
check the panel to make sure the panels are the same model number there are more then one part number for gateway lcds for your model and if your laptop uses the xga screen and your not replacing with the correct panel then you will get the problem you are seeing now.even thought the inverter and back light are the same the panel are very differant.
Feb 18, 2009 | Gateway MT6451 Notebook
leaving your unit in standby mode is not a problem as long as your ac adapter is plugged in to your ac outlet and to your pc. otherwise, you will have a drained battery. try removing your battery for a few minutes and then insert it back in then plug your ac adapter to your wall outlet and to your pc and leave it without starting your pc. notice the small pilot light at front edge of your laptop, it should be yellowish/orange. wait until this light turns green then you can try turning on your pc.
Oct 23, 2008 | Gateway MT6451 Notebook
MT6451
I have seen bad ram or loose ram cause the issue. Re-seat the ram.
G'luck
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
