Question about Refrigerators
Kelvinator Cyclic 330 not getting cold enough
I have a Kelvinator Cyclic 330 Fridge only that doesn't get cold enough anymore. The plate at inside back of fridge still gets a little icy where the thermo cable joins up and is cold to touch but fridge not cold enough and food going off. Any ideas?
  • 3 Answers
Empty the refigerator and freezer, unplug it for about 8 hours, leave freezer door open so it will completely defrost. Plug it back in for 4 hours and close doors before you fill it back up with food. If you have a thermometer, check the interior temperatures before you fill it back up. Refigerator should be around 42 degrees F.
Posted on Mar 19, 2014
  • gavfleur308 Mar 21, 2014
    Thanks for your advice. I gave that a go and it still seems the same except the cold plate at back inside fridge isn't icy anymore but is cool to touch, not cold. ANy other help/ideas?
SOURCE: frigidaire PLHS267ZDB2--Not cold enough
Replaced the fan and the damn thing works like a charm....Thanks alot for all your suggestions.This is a cool site and you guys are doing a great great job! Keep up the good work!
Posted on Oct 22, 2007
SOURCE: GE Fridge...no longer freezing or cooling food!!
Had to call in the experts...needed a defrost heater and 2 sensors.Hope this is helpful to anyone w/ a similar problem.
Posted on Jul 26, 2008
SOURCE: My fridge is too cold
I wrote under "guest" earlier on Aug 5th. I jave since discovered that the problem is a manufacturer problem. Apparently Liebherr had problems with their sensors, which they have since corrected, but they were put in all the earlier fridge/biofresh. I contacted the Liebherr agent in Melbourne Australia where mine came from (Andi-Co), and they have sent someone out to replace the sensor free of charge (mine has been out of warranty since March 2008). The sensor tells the compressor when to shut off, and when faulty does not do this so the compressor keeps running and freezes everything. I did have to make a bit of a fuss though and write them a letter before they came out. I printed out this page as evidence that it was clearly a manufacturing problem, which they have now confirmed. So I suggest you ask your supplier to fix the problem free of charge. Good Luck!
Posted on Aug 14, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Posted on Feb 12, 2009
  • 3 Answers
SOURCE: have Kelvinator Cyclic 500 Fridge, Does not seem to defrost prope
has the thermostat been replaced? if so it is probably the wrong 1
Posted on Mar 31, 2009
Kelvinator Cyclic 330, Model No: CS334A-R
Tonight, get a battery flash light, turn it on, put it in the fridge and close the fridge door. Then turn off all the lights in the room. If you can see any light escaping around the fridge door, the door seals aren't working properly, and need replacing.
This is the main reason why too much water is being condensed and causing your fridge drip tray to overflow.
May 25, 2014 | Refrigerators
Wiring diagram for a Kelvinator 330
There's only 2wires and it shouldn't matter which terminal on the cold control u connect it to. If there's 3wires one should b green and it's a ground wire
Nov 30, 2013 | Electrolux Kelvinator Cyclic Defrost...
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
Fidge is warm but freezer ok Kelvinator c 500 c r cyclic
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 07, 2011 | Refrigerators
How do you defrost the kelvinator cyclic 300 fridge?
hi,
a manual defrost? unplug and get a 9by11 cake pan and a bunch of towels and a hairdryer. put the hairdryer on LOW only and get it positioned in the freezer (door) compartment so its pointing towards the back. cake pan in the bottom towels below. and on the floor. leave the door open about 3 or 4 inches but NOT shut so you have some air circulation. and check it frequently. make sure the hair dryer isnt pointed at the plastics at all. takes a day. pull it from the wall, remove the rear access cover behind the fridge and blow it out with a vac or air compressor too. theres an access panel inside the freezer and if your handy, your ice blockage causing that problem lives behind there in the freezer. use caution if your going to attempt taking that plate off inside. use nothing sharp.
jm
Dec 08, 2010 | Kelvinator Freezers
Old Kelvinator Cyclic 340. Freezer is Ice cold
Read the below :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 16, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Where abouts is the thermostat inside the fridge there are white and yellow wires that go to either side of the fridge and the yeallow ones are broken what are these wires for it is a kelvinator C375vm
It sounds like you have a cyclic defrost fridge,Kelvinators were originally fitted with heat assist thermostats,so in order for the fridge to come back on a yellow wire heater was run around the cooling evaporator in the fridge compartment start running again at approx +4C so when the element fused the fridge did not start again until approx +12C.So instead of replacing heater a different thermo was used that came back on at +4c deg regardless.Kind Regards.
Jul 09, 2009 | Refrigerators
Temperature Setting Dial in Fridge
Hi. thanks for the question. # 9 is the high, 1 is low. and it will run for 24 hrs to get on track .thanks the appliance doc
Oct 05, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Fridge not working
sounds like the defrost system is defective, frozen. possibilities are fan in freezer wuit or defrost heater open or defrost timer bad. try these first, if not fixed call.
Mar 28, 2008 | Refrigerators
Refrigerators Logo
157 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
