Question about Kenmore Dryers
Dryer turn on, heats up but doesn't get hot
Kenmore dryer does not get hot anymore just warm. I see the glow and then the flame from inside but it is like it is stuck on a low setting and takes longer to dry.
    Problem Solver:
  • 13 Answers
I just had the same problem with my electric dryer. Check your exhaust vent (dirty/clogged). I have seen brushes designed for cleaning the vents at many hardware stores. I replaced mine because it was pretty bad (it's was over 10yrs old). Hope this helps.
Posted on Jun 14, 2009
My kenmore gas dryer works for 5 minutes then control panel flashs and won't heat th cloths
GOD IS GOOD !!!!
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Sep 21, 2014 | Kenmore Sears Kenmore Clothes Dryer Flame...
I have a kenmore Dryer 110.76932690. Motor runs fine. Glow bar ignitor does not light. Flame doesn't come on. Changed Internal Bias Operating Thermostat still doesn't ignite. What could be other
Thermal Fuse
Air Flow and Heat
Warning
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
Aug 30, 2014 | Dryers
Why is my Kenmore 500 series gas dryer won't heat up, no flame.
Thermal Fuse
Air Flow and Heat
Warning
Aug 21, 2014 | Kenmore Dryers
Kenmore dryer 110 gas won't get hot only warm. I
more than Likely,, the thermostats are discs ,, located along the vent tube inside the back of the machine, one of yours is weak and allowing the switch to turn off to soon
Jun 29, 2011 | Kenmore Dryers
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
Heat runs ten minutes than heat shuts off continues to run
I'm thinking the thermostat has failed, it get's too hot and the emergency over temp sensor kills the flame before a fire is started.
Apr 07, 2009 | Kenmore 63942 Dryer
HE3 electric dryer only gets warm
your dryer igniter, and or coils are shot.. change the drop in coils first...
Jan 23, 2009 | Dryers
Kenmore 70 gas dryer will heat for 7 minutes then nothing
Change these:3d37aa7.jpgthey get hot and quit, then cool off and work some more.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 31, 2008 | Kenmore 73952 Gas Dryer
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Dryers Logo
66 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
