Question about Microsoft Xbox 360 Console
Xbox 360 DNS failure
IP is confirmed, but i fail at DNS test. I have ethernet cable connected to xbox {dont have modem} and nothing works
  • 161 Answers
Unless a 360 has a modem built into it, you're gonna need one. also, you may need to set up an Xboxlive account to do ANYTHING. check your settings on the console as well to make sure things are working.
Posted on Jun 14, 2009
Ip adress failed
u should try ringing ur internet server and u dont connect it to ur laptop u connect it to ur modem and router and btw for some reason xbox live doesnt work for everyone it weird but no one knows why
May 09, 2009 | Microsoft Xbox 360 Elite Console
Can't connect to Xbox 360
reset it...look at back side of modem.....
and if it not works then contact your isp ...
Aug 18, 2017 | 2wire HomePortal 1100 Router...
My Xbox 360 ADapter Cannot Aquire a IP Address from my Modem
can u please tell me which router it is? in most of the router there is a feature call DMZ. u need to enable the DMZ in the router & then u need to provide the static ip to Xbox 360 like 192.168.1.5 etc in the default getway u need to type the router IP address & on DNS u need to try three different settings 1st on primary DNS type the router ip address like 192.168.1.1, if it didn't work try with univeral DNS try on primary DNS as 4.2.2.2 & on secondary 4.2.2.1, if this didn't work either call ur ISP and ask for the DNS server address of ur ISP and try with that.
Jan 23, 2009 | Microsoft Wireless Network Adapter Xbox...
Xbox Live On Westell C90-610030-06 Isn't Working
if this is the original xbox you have to use a crossover cable especially if your router is the same as your modem (both the same box) (try google for the crossover cable instructions.) if this is the 360 it should just work, also how is your router plugged into your modem or are they the same thing. If that is the case go get a linksys router and set it up so that your modem-router combo plugs into the linksys router which plugs into your xbox (note that this is a fix for the original to.)
Jan 10, 2009 | Microsoft Xbox 360 Console
Ip address failed
In order to connect your XBOX 360 to your laptop (if the laptop is connected via dial-up), you'll need a cross-over ethernet cable. It's a special type of ethernet cable, which is typically the same price as a regular ethernet cable, but it allows two devices (in your case) to communicate with each other. Then, you'll need to configure your laptop to allow incoming connections via your Control Panel -> Internet Connections preferences.
Hope this help!
Robert W.
Jan 08, 2009 | Microsoft Xbox 360 Console
Xbox 360 Connection to internet
the IP address will fail when it is set on manual, rather than automatic. Be sure, once you enter it, it is set to automatic
Jan 03, 2009 | Microsoft Xbox 360 Console
Can't connect to Xbox Live
mtu is not working cant hook up xbox live
Nov 25, 2008 | Microsoft Xbox 360 Console
Xbox elite ip adress failure
From the question above I think you are saying that when you unplug your Ethernet cable from your Internet connection out of your E-BOX and try to use it in your laptop, it doesn't work. If this is correct, then it's probably that your ISP only allows for 1x active address to be used at any one time. To overcome the problem you'll need to also power recycle your Internet modem to clear out the MAC address of the X-BOX once you've unplugged it and before you make the laptop connection. You would have to do this each time you wanted to swap between the devices.
Alternatively, get yourself a Router to sit in between the Modem and end devices and then have an additional permanent cable / 2nd physical port to use.
Oct 25, 2008 | Microsoft Xbox 360 Elite Console
Xbox live
2 Solutions-----
Number 1 - If your ethernet cord is going from a modem straight to your 360, then get your modem replaced by your ISP.
This will probobly be free, but if your charged, it will be a small fee.
Number 2 - If you have it going to a routerfrom a modem, then go to your 360 main screen, scroll to the far right 'System' blade, select the 4th choice 'Network Settings', and test your Xbox LIVE Connection. It will ask you to sign out. Select yes.
Results should come up (for wired router)
Network Adapter - Wired
Wireless Network - (Left Blank)
IP Address - Confirmed
DNS - Confirmed
MTU - Confirmed
ICMP - Confirmed
XBOX LIVE - Confirmed
NAT - (either moderate, opened, or strict)
If all those are the same, the problem has nothing to do with the xbox itself and you need a new router, or modem.
If results come out to be
''Network Adapter - Disconnected''
After test is run (and your 360 is connected properly to your router AND modem then you have a hardware problem. Whether the problem is in the 360 or the router/modem is easy to test.
Connect the modem directly to the 360 via ethernet. If this fixes the problem, the router is fail.
If you can get on the internet wirelessly and grounded on a computer, the 360 is busted.
Sorry it took me so long to explain that, but i hope it helps you.
Best of luck
-Erk
Jun 18, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
50 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
