Question about NEC PABX SL1000
No ringing in one extention
When we called other extention is ringing one extention is bling only
How to set delay ring Panasonic KX-TA824
First assing the flexible ringing day, night, lunch in programs 408 to 410, the assign the delay ringing for the extensions you want in 411 to 413.
Jan 25, 2014 | Panasonic KX-TA824PK Phone
Turn off Ringer For External Calls Only
If you use strata emanager it would depend on how your system was set up. One way is to go to Advanced configuration tab Station tab, multiple call group tab, click on the group number (far right), then member tab and select extention and ringing option. Another way is to go again from the advance configuration tab, then assignment tab select the extention number on the right select key assignment tab, and on the incoming extention line double click it nd select no ring.
Jun 11, 2009 | Toshiba DKT3020SD Corded Phone
How do you do a call pickup on Nortel i2004 system?
Feature 75 if the phone is in your group (see administator), Feature 76 plus DN (extention) to use directed pickup (if you know which extention is receiving a call)
Mar 06, 2009 | Nortel i2004 IP Phone
My Phones only ring twice before it goes to VoiceMail
What you can do is go into the management console for your system and find the forwarding this is under extentions option 2 fwd/dnd select your extention number and on the bottom option FWD No Answer Time (s) set it to 10 or more and this will change the number of rings.
I use a KX - TDA600 PABX so I hope this helps
Jan 06, 2009 | Panasonic KX-T7630 Corded Phone
Incoming calls bypass greeting - no way to dial extentions
If this hasn't been solved, I am Vodavi certified. Give me a ring
Nov 21, 2008 | Vodavi Starplus SP7314-08 Corded Phone
Pick up handset to answer a call and NOT have to press a line
if your phone had set for ringging assignment, u no need to press any key to answer the call.
check the indicator light,
if green light turn on, u can direct answer the call
if red light turn on, u ned to press the line to answer the call
kindly ask the phone provider the set yr extention for incoming ring assignment
Nov 12, 2008 | Toshiba DKT-2020 Corded Phone
KX-T7730 programming manual
i have 10 extentions but my call ring to all extentions. but the ring to one extentions 101 only plz tell me
Aug 05, 2008 | Panasonic KX-T7730 Corded Phone
Forwarding calls between extensions
Yes, press Feature 4, then enter the extension of the line you wish to forward the ring to. You can also go into the phone configuration to forward after a set # of rings. To ring another extension at set times you will need admin access.
Jul 02, 2008 | Nortel Meridian M7208 Corded Phone
Direct line ring on my extention
CALL A QUALIFIED TECH TO COME OUT AND PROGRAM IT FOR YOU AS TURNING OFF DIRECT DIAL IS A SYSTEM PROGRAM NOT USER
May 11, 2008 | Panasonic KX-T7730 Corded Phone
Can not receive calls from the outside
Do you own that number from the telco? Is it in your DID range? Did you put it in the right call routing table?
Feb 05, 2008 | Inter-Tel Axxess Phone 5504400
NEC PABX SL1000 Logo
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
