Question about Toshiba Auklet CT Scanner
HV/INV for toshiba auklet ct scanner
When selection 120KV , it does not expose and shows this message below overlong exposure time error in the xc, Reset xc and execute the command again. [xc reset] [detail] [ok] when you click details you get the following details: bno code error 07 E13 abnormal arcing was detected in the high-volta 24 E0 XC error 27 E3 Exposure time error
  • 10 Answers
SOURCE: Toshiba E-Studio 160
When the message call for service is displayed
press the C key and the 8 key at the same time
an alpha numeric code will appear eg: C47 etc
Post the error code and I'll tell you what it means
Posted on Feb 06, 2008
  • 43 Answers
SOURCE: toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
Posted on May 08, 2008
jomz08
  • 3 Answers
SOURCE: toshiba power saver fatal error code 0x57
try to reinstall your operating system..or restore the system..go to control panel and click the back up or restore files so that all the errors in your computer will fixed..even a fatal error..hopefully this will help your problem..
Posted on Aug 28, 2008
  • 643 Answers
For error code C44, it indicates Heater abnormality.
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
If happen again, then u need to check the thermistor. Replace it if necessary. If themistor replaced but still happen again, then u need to proceed to check themostat--> heater-->Mainboard-->Switching regulator.
Posted on Mar 09, 2009
  • 643 Answers
SOURCE: Toshiba e-Studio 232 is showing error message CF60
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
Posted on Jun 10, 2009
Xc timeout error
Did you find the solution of Xc timeout error ?? if yes please guide me also cause i also confronted with the same problem
Sep 13, 2013 | Toshiba Auklet CT Scanner
Abnormal xc status
Dear this fault related to your xray generating system
Perform if and tell the next error
Sep 03, 2013 | Toshiba Asteion Super 4 CT Scanner
Minolta ep4000 error code c0400
C0400 -Exposure lamp failure to turn ON
C0410 -Exposure lamp turning on at abnormal timing
Turn OFF the copier,remove the glass,Work a screwdriver trough the hole in the frame at the left front side of the copier and remove the screw that secures the scanner unit.Move the scanner to rhe right hand side of the copier.Remove 3 screws to free the scanner.(To remove the scanner turn it counterclockwise).Remove 1 screw and the wire guide,remove 1 screw and the ground wire.Unplug the exposure lamp terminal connector,unplug the thermal fuse connector.Remove the scanner from the copier.Verify the continuity of the exposure lamp and thermal fuser.If is defective change.
Jan 02, 2013 | Minolta EP4000/5000 CS/PRO Copier
Toshiba auklet
toshiba auklet have no ae and port no only RJ45 can capture software millenmed and scandoc
May 09, 2012 | Toshiba Auklet CT Scanner
Our panasonic scanner has a error message that states " place paper in feeder" There is paper in the scanner to be scanned. How do we get rid of this error???
This error occur for some reason, please check each one:
1; ADF document feeder is not closed really and
2; You are put the documents into a wrong place
3; the sensor of the ADR is wrong or is dirty (in this case you need a mechanic)
Please read carefully the ducument below (be care of page 23)
http://office.manualsonline.com/regman/exit/ct?url=aHR0cDovL3NlcnZpY2UudXMucGFuYXNvbmljLmNvbS9PUEVSTUFOUERGL0tWUzEwMjVDLlBERg,,&target=productDoc&idDeviceType=2727&idMfg=1569&idProduct=191533
Rgd,
Sly
Nov 22, 2010 | Panasonic KV-S1025C
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
Copier not working shows a flashing L on display
Sharp AL-1553 code
E7 03 Scanner position error 04 Exposure lamp blown 05 CCD calibration error 12 White level calibration error 14 Main board malfunction 15 Exposure lamp blown L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up U2 01 Counter error 04 EPROM error CH blinking Dev unit is not properly installed
Nov 18, 2008 | Office Equipment & Supplies
ERROR CODE SC101
SC101 indicates and exposure lamp problem. To try and correct, turn OFF the copier and then unplug from the wall. Wait 10 seconds and plug it back into the wall, then turn on the copier. Watch to see if the exposure lamp comes on - lift the document handler if you want. If the exposure lamp is working correctly, the scanner will briefly move to the right and the light will turn on then off after it moves to the left.
Jul 09, 2008 | Ricoh Aficio 1013F Copier
Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Jun 03, 2008 | Office Equipment & Supplies
Can not load software for Pentax DSmobile scanner
This solution has helped a lot of people. The cause of the problem has
been known already and is explained clearly how to fix the issue on the
site link below.
'Invalid Drive during installation
Fixing Invalid Drive Error 1327
Sep 22, 2007 | Pentax DSmobile Path-Through Scanner
Toshiba Auklet CT Scanner Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
