Question about NEC PABX SL1000
Incoming call not displayed
If we called, incoming call number was not displayed
How do I answer the Huawei Vision 2 phone?
Answering an Incoming Call When you receive a phone call, the incoming call screen opens. If you have previously saved the caller's number in People , the caller's name and number are displayed. If the caller's number is not saved in People , the caller's number is displayed.
Drag to round circle and phone icon to the right to answer the call.
When ending a call, drag the circle with the phone icon to the left to cancel or end a call.
Also attache is a manual, check page 25
https://www.consumercellular.com/Content/PDFs/Manuals/Huawei%20Vision%20Manual%20-%20Final.pdf
Mar 03, 2015 | Huawei Cell Phones
I have BT line and have call divert but can't remember how to divert calls, HELP please
Check which services are active [System X] *#001#
Charge advice (before call) *40* (Number)
Charge advice (All calls) *411#
Charge advice (During call) "R"(to hold call) *40#(Call will be reconnected)
Cancel all calls charge advice #411#
Reminder call *55*(Time in 24 hour format)#
Cancel reminder call #55#
Call Divert - all calls - activate *21*(Number to divert to)#
Call Divert - all calls - to check *#21#
Call Divert - all calls - to cancel #21#
Call Divert - on busy - to activate *67*(Number to divert to)#
Call Divert - on busy - to check *#67#
Call Divert - on busy - to cancel #67#
Call Divert - on no reply - to activate *61*(Number to divert to)#
Call Divert - on no reply - to check *#61#
Call Divert - on no reply - to cancel #61#
Call waiting on *43#
Call waiting off #43#
Call waiting - to check condition *#43#
Call waiting - to answer 2nd caller Recall + 2
Call waiting - remove beeps during call Recall + 0
"Ring back" (Camp on busy) 5
Cancel ring back #37#
Caller display on *234#
Caller display off #234#
BT call minder (voice mail) 1571
Check called number 1471
Release CLI 1470 + dialled number
Withhold CLI 141 + dialled number
Access "Choose to refuse" 14258
Call barring on (outgoing) *341 + option number #
(options are 1 = allows 999 and operator, 2 = allows 999 & local, 3 = allows 999 & STD, 4 = bars all operator calls, 5 = bars *, 6 = bars premium adult lines, 7 = bars premium information lines)
Call barring off (outgoing) #341*(PIN code)#
Incoming calls barred off [System X] #261#
Incoming calls barred on *261#
Incoming calls barred off #261*(PIN code)#
Feb 19, 2015 | BT Lands Phones
Dear Sir, I am using Samsung SJ700 mobile phone.And sometimes I get incoming call with no number displayed on the screen. It just shows incoming call. Can you pls help me in sorting out this...
This happens when two or more similar (saving one number with different names) contacts is saved on your phonebook, i.e. if you've saved my number on the sim card with a name and at the same time you have my number (same number) on your phone's memory, the caller id will not be displayed, you'll only see the "Incoming Call" or "Call". So I would suggest you to please check the phonebook and delete (keep only one per number) if there are multiple similar contacts saved on your phonebook.
You can also reset the phone to Factory default, in case there's no problem with your phonebook/contacts.
Good luck.
Thanks for using FixYa.
Aug 14, 2010 | Samsung Cell Phones
Comdial 7260 Incoming number displayed not the name.
Call your telephone company and explain the problem. They will give you a code to put on your phone.
May 21, 2009 | Comdial 8324S-PT Corded Phone
Remove message of the middle line of display
Pick a spare button and label it CALL LOG. Now press PROG that button and dial 54 STORE. Ooh, it should light up. Now press it and your display will show 3 of the 4 lines of CID info from the calls to your set. The navigator button will show the rest, just keep pressing the UP, DOWN, LEFT, RIGHT buttons. When you run out of items to display, the light and INCOMING CALL display will go out.
If you press 54 and the 3 digit number of your incoming call group (maybe 601 by default) it will follow the incoming calls to the entire call group.
Carl
Apr 24, 2009 | Panasonic KX-T7630 Corded Phone
How to do check my missed call log
A Panasonic TDx system has 2 types of call logs, one personal for the set, and one for the ICD group.
Pick a spare button, press PROG, the button, and dial 54 STORE.
If you had incoming: 00x on your display, that button will light and you can now press it to see who called. Your Navigator UP/DONW key will step you forward or backward through the log. The LEFT/RIGHT key will display the 4 lines of the display if you're not using a 7636 phone.
If you want to see incoming calls to a particular ICD group, pick another button, and dial 54 plus the ICD group number. For example, I used 100 as my ICD group (now 600 by default). I have 2 buttons, one logs my extension calls, one displays the system calls.
Carl
Mar 09, 2009 | Panasonic KX-T7630 Corded Phone
Display showing "Incoming Call :001"
Don't worry, if you ignore it will grow :-)
It's a count of the unanswered calls with CID. If you take a spare button and program it for Call Log, it will light up and you press it to start the call log display.
Try this press PROG 54 STORE
When you press it, your display will now reveal the numbers under incoming.
If you put a number after the 54, it will log calls for a particular group. I get my calls on incoming group 100, so I store 54 100 under a button and I can see all system calls. I have a second button for just my extension calls.
Carl
Jan 15, 2009 | Panasonic KX-T7630 Corded Phone
Caller ID
battery weak change ur battery
Sep 23, 2008 | Astra Meridian 9417 Corded Phone
Incoming calls
both parties need to have caller id active
so if they are in your conntacts but don't have caller id opperating then the number won't be displayed
Dec 11, 2007 | Motorola Mobility RAZR V3i Cellular Phone
NEC PABX SL1000 Logo
21 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
